Old Jul 30, 2012, 03:30 PM
flypilot is offline
Find More Posts by flypilot
Everything RC
flypilot's Avatar
Norway
Joined Jun 2004
Latest test with my new Grauner 14x8e props
High speed video test of my new Graupner 14x8 e props (4 min 0 sec)
flypilot is offline Find More Posts by flypilot
Old Jul 31, 2012, 06:42 AM
feradi is offline
Find More Posts by feradi
Joined Jun 2010
Cool, looks like I'm ordering the 14x8e props... I'm still waiting for my frame and some extra parts... Thanks for all your help...
feradi is offline Find More Posts by feradi
Old Aug 14, 2012, 02:48 AM
devfor is offline
Find More Posts by devfor
O <- this a ground loop
Japan
Joined Nov 2010
Hi flypilot,
nice intro for this platform. Thanks for sharing.
Could you be so kind as to share at what lens zoom setting you find the landing gear come into the field of view?
That is my only concern.
I'll be using a hacked Lumix GH1 aka GH13 and the only lens I have for that now is a Nikon 50mm on an adapter so I know I will be fine.
But I would like to guestimate the widest lens I could get away with on the proper format.
thanks,
Ren
devfor is offline Find More Posts by devfor
Old Aug 14, 2012, 04:38 AM
flypilot is offline
Everything RC
flypilot's Avatar
Norway
Joined Jun 2004
Sure, I am using the kit lens at 18mm zoom. And only at extreme manouvering the gear comes into view. Smooth flying is no problem. Please post results and pictures of your setup when you test it.
Old Aug 16, 2012, 04:02 PM
sPiKes777 is offline
Find More Posts by sPiKes777
Joined Jun 2012
Thank you very much for this review ! I am also considering this setup to upgrade my current Gaui 500X quadcopter, to lift either my Canon T2i or my Sony Nex 5.
To make a few flight time computations I would like to know the total weight of the frame+gimbal+controller (excluding the battery and camera).
Thank you in advance !
sPiKes777 is offline Find More Posts by sPiKes777
Old Aug 17, 2012, 03:04 AM
flypilot is offline
Everything RC
flypilot's Avatar
Norway
Joined Jun 2004
Sorry I don't have that exact weight but would guestimate around 3-3,5 kg.
Old Aug 27, 2012, 01:29 PM
trunet is offline
Find More Posts by trunet
Brazil, São Paulo, Sao Paulo
Joined Nov 2011
Hi,
How did you manage to plug all 6 ESCs on the battery? Did you use some power distribution board?
trunet is offline Find More Posts by trunet
Old Aug 27, 2012, 01:32 PM
flypilot is offline
Everything RC
flypilot's Avatar
Norway
Joined Jun 2004
I just made my own distribution board, you can just use two rings of wire and solder on to that.
Old Sep 12, 2012, 05:09 AM
Joined Jun 2012
Did you fly the FH-H800 again recently ? Are you still pleased with its behavior ?
Old Sep 12, 2012, 09:40 AM
flypilot is offline
Everything RC
flypilot's Avatar
Norway
Joined Jun 2004
Hi, yes very pleased, the hexa has been in constant AP use the last three months and not one issue...very happy.
Using, W-KM 5.12a and Gains are 200,200,200,70,70.
Using Graupner 14x8 E props on DJI 30A ESC's and 4s batteries.
Old Sep 12, 2012, 02:20 PM
Joined Jun 2012
Good ! I am really interested in this frame. You mentioned that you obtain 12 min flight time with 2x4s5800mAh. Have you tried with only one 4s battery ? I suppose this would give about 9 minutes.
Old Sep 12, 2012, 02:23 PM
trunet is offline
Joined Nov 2011
I bought my FH-H800 yesterday, it should arrive in one month to me as I'm in Brazil.
But, I have a turnigy talon hexcopter from hobby king, with 6 x sunnysky 700kv and 6 x 40amp esc running CF 10x4.7 from rctimer. I'm getting 9 minutes on 4S 5000ma.
Old Sep 12, 2012, 02:43 PM
flypilot is offline
Everything RC
flypilot's Avatar
Norway
Joined Jun 2004
It all depends on the all up weight and props you are running, also if there is alot of wind and turbulence you will get shorter flighttimes...you should always time your flights and also havesome kind of voltage protection. I use JR so I have the DMSS telemtry module where I can read of voltage and MAH usage..which is very nice.
Old Sep 12, 2012, 02:44 PM
flypilot is offline
Everything RC
flypilot's Avatar
Norway
Joined Jun 2004
Congratulations on buying a new hexa, I think you will be happy.
Old Sep 12, 2012, 03:06 PM
Joined Jun 2012
This is indeed good advice! I have an aurora 9 with telemetry that shows the voltage, with an adjustable alarm, as well as the Wookong protections.
I will use the same setup as you do: EOS 550D+18-55mm, so I think the flight time will be the same.. Have you maybe estimated the power needed for stationary flight ?
Sold FH-10Z Camera 10x zoom rc controlled - Foxtech FPV beep684 FPV Equipment (FS/W) 1 Jun 28, 2012 06:35 PM
Discussion FH-X46 new quadcopter and hexacopter controller from FOXTECH glassfox Multirotor Talk 730 Apr 30, 2012 07:14 AM
Sold Foxtech 5.8 GHz RX w/power and A/V cables keok FPV Equipment (FS/W) 4 Feb 28, 2012 01:37 PM
Wanted Looking 4 gear compatible w/ Foxtech "AIO" 2.4/5.8Ghz goggles Medicineman76 FPV Equipment (FS/W) 2 Feb 25, 2012 07:35 PM
Discussion Foxtech FH-25HD 550tvl day/night mrleenagle FPV Talk 8 Aug 13, 2010 09:36 PM
