Espritmodel.com Heli Air
Old Jul 03, 2012, 12:18 PM
Machete don't text
motor12's Avatar
United States, TX, Austin
Joined Jan 2010
how do you protect the wings leading edge
On a sailplane that is constructed of balsa and covered with ultracote how or what do you use to protect the leading edge of the wing when landing in a grass field. I am now flying a RP and sometimes when landing i get bits of grass stuck in the foam wing.I would think if this were to happen to a ultracote wing it would a big problem. Thanks
motor12 is offline Find More Posts by motor12
Old Jul 03, 2012, 02:57 PM
RIP Ric
Andy W's Avatar
Marietta, GA
Joined Jun 1999
It's generally not a problem.
Anything you put on there is going to mess up the airfoil..
..a
Old Jul 03, 2012, 03:18 PM
AMA 7224 LSF 1832 SAM NFFS
Leadchucker's Avatar
Joined Sep 2008
Thousands of such landings on grass with little to no effect on leading edge. It's pretty much a no worries senario. Lamp posts,no parking signs, automobiles, trees,mailboxes,guy wires,buildings,idlely unaware standingby pilots and other aircraft do have an varying negative effect.
Leadchucker is offline Find More Posts by Leadchucker
Latest blog entry: 1940 Megow Models Super Quaker
Old Jul 03, 2012, 08:48 PM
Electric Glider Nut
timography's Avatar
Australia, WA, Perth
Joined Feb 2012
agree with leadchucker on this one. you would have to be landing your RP (Radian Pro??) v.e.r.y. hard into grass for anything to start sticking into your wing LE. I have a Radian and 2x Radian Pro's and i've never had any problem with LE's getting damaged. If it continues to be a problem, perhaps you should be seeking somewhere different to fly that has a more suitable landing area (read: soft green grass - not a wheat field lol)
timography is offline Find More Posts by timography
Old Jul 03, 2012, 09:56 PM
ozmo01's Avatar
USA, MO, Ozark
Joined Nov 2006
LE Protection
Hi,
The dry grass, weeds, stubble and brush are a bit harsh on LEs but usually grass slides off of the slick covered wings (monokote etc). Foam may tend to be cut a bit by sharp dry grasses. The Paul Naton soup up for Radians calls for taping the LE with THIN packing type tape ( thin cheap light stuff NOT Duck tape type ). This approach would help I think. Anything more would be dead weight and a PITA.
OzMo
ozmo01 is offline Find More Posts by ozmo01
Old Jul 05, 2012, 04:14 PM
Joined Feb 2009
Hand catch.
Bad scientist is offline Find More Posts by Bad scientist
Old Jul 10, 2012, 02:31 AM
Kilsyth, Victoria, Australia
Joined Oct 2003
If it is a real concern to you an extra layer of film over the leading edge will help. I've flown both on soft grass and stubble without real problem but one or even two layers of film are unlikely to change the characteristics of the airfoil.
David Hipperson is offline Find More Posts by David Hipperson
Old Jul 10, 2012, 12:20 PM
Zor
Zor's Avatar
Ontario,Canada
Joined Feb 2007
Just my 2 cents
If you cover the wings with woven fabric and have threads lengthwise along the leading edge there is little chance that those threads will break under tension.
Fabric having tyically 80 threads per inch will have many threads along the curve of the leading edge.
Just find how much tension you need to break a single thread of 40 gauge.
Zor
Zor is offline Find More Posts by Zor
Discussion Do you evaluate air before launching and how you do it ? FRIDAY_2008 Thermal 38 Aug 12, 2012 01:35 AM
Help! How do you determine wire size ? and other questions. StewieRC Electric Motor Design and Construction 8 Jun 13, 2012 03:41 PM
Question Where do you get your trim designs and how do you test them? dedStik The Builders Workshop 16 Mar 15, 2012 03:32 PM
How do you do it ? (wing transport protection) Lancair Electric Sailplanes 63 Sep 13, 2003 02:22 AM
Question How much do you have to shape a leading edge kit? Jim Poor Slope 8 Aug 26, 2003 01:03 PM
