Old Jul 03, 2012, 11:41 AM
Deadstick 8409 is offline
Find More Posts by Deadstick 8409
Deadstick 8409's Avatar
Joined May 2010
Do I need worry about inducted voltages when adding LED's to ESC battery?
So I just built an a/c to try my hand at dusk/night flying, and wired up a few feet of the "tape led's" all over the airplane. I just read this:
http://www.rcmf.co.uk/4um/index.php/...m87kstnbn2oee0
A great article on the voltage rise due to inductance of input currents to the esc. I have not extended the wires however, but added about 8 watts worth of leds.
I know lots of people do this, and I have not seen any reports of failures.
But it seems to me there must be times when the supply voltage is over 12 volts in this setup (3 cell) and perhaps putting the LED's at risk? I'm sure the risk grows non linear w/ respect to esc wire length, just wondering if anyone has had issues with this.
Deadstick 8409 is offline Find More Posts by Deadstick 8409
Old Jul 04, 2012, 03:05 AM
7oneWo1f is offline
Find More Posts by 7oneWo1f
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
See below
7oneWo1f is offline Find More Posts by 7oneWo1f
Old Jul 04, 2012, 09:02 AM
Wintr is offline
Find More Posts by Wintr
Wintr's Avatar
USA, MO, Florissant
Joined Nov 2010
If you connected the wires from the LEDs directly to the circuit board of the ESC, there will be a small ripple voltage; as noted, the quality of the capacitors on the ESC will determine how large the ripple is. This will create a corresponding ripple in the current through the LEDs, but will be insignificant to the life of the LEDs. The peak operating current of an LED is a few, to several, times the nominal, best efficiency value, and that ripple will be far below the peak.
Wintr is offline Find More Posts by Wintr
Old Sep 08, 2012, 09:15 PM
panther3001 is offline
Find More Posts by panther3001
Joined Dec 2010
Hi, I"m interested in reading this article, but don't want to open up an account with these guys to read it. Can you perhaps copy and past it here?
panther3001 is offline Find More Posts by panther3001
Discussion LadyBird Qr SMD Led's mod, even more led's to come! croyal918 Multirotor Talk 6 Jan 13, 2014 07:15 PM
Discussion Lipo Alarm to give Alarm when Battery voltage is low redconuser Batteries and Chargers 1 May 25, 2012 02:24 AM
Discussion how many C's LIPO BATTERY do I need Rhondas 3D Foamies 3 Apr 22, 2012 10:16 PM
Discussion High voltage servos, such as Hitec's do they work with 4.8V-6V voltage? liukku Radios 9 Mar 26, 2012 12:35 PM
Discussion If the GOP is so worried about Voter fraud, why no ID's for GOP primary? redhotpearl Life, The Universe, and Politics 55 Mar 12, 2012 09:34 PM
