Old Jul 03, 2012, 06:56 AM
WBFAir is offline
Find More Posts by WBFAir
United States, CT, Stamford
Joined Jan 2007
Will my PL8 charge a 2 cell pack that has no balance tap?
Hello all
Basically I was thinking of running out and getting one of the new Blade 130X helos and that comes with a 2 cell LiPo but has no balance tap.
As that is probably all I could get today for it (if they even have any extras), I was just wondering either for say the #6 preset, or some other way, if can I charge those (obviously thru the discharge lines of the pack alone) with my PL8?
Or even with just a 2 cell, do I need to have a balance tap so the charger can know it's a two cell and not some over-volted single cell?
Thanks for any help.
WBFAir is offline Find More Posts by WBFAir
Old Jul 03, 2012, 09:19 AM
Ohmic is offline
Find More Posts by Ohmic
USA
Joined Jan 2002
Yes, you can charge a 2s non-balanced pack with the PL8 using the special preset for this.
Ohmic is offline Find More Posts by Ohmic
Old Jul 03, 2012, 10:08 AM
WBFAir is offline
Joined Jan 2007
Thanks for the reply on this Pete
Just out of curiosity, do you know how it does this?
In other words, I would have to think with just the stuff I know, that a charger knows what cell count a pack has based on seeing voltage from the balance taps and based upon seeing that, count how many are being reported.
Again, don't know if that's true per say but the PL8 (or maybe they all do this) for this mode to work, must base this on total voltage?
Old Jul 03, 2012, 10:40 AM
Ohmic is offline
USA
Joined Jan 2002
Nothing magical about it. It only works on 1s/2s packs. It just looks a total pack voltage to determine whether it's 1s or 2s.
Old Jul 03, 2012, 12:00 PM
WBFAir is offline
Joined Jan 2007
Gottcha, thanks for the info Pete.
Old Jul 04, 2012, 04:02 AM
typeRA is online now
Find More Posts by typeRA
Zero Expo
typeRA's Avatar
San Diego, CA
Joined Mar 2009
The battery does have a balance tap, do not charge unbalanced!
You can make an adapter for your PL8 by soldering a B3B-PH-KL connector to a CPBP7 pigtail. You'll need to use the CellPro balance adapter that should have come with your PL8. This option utilizes the PL8 node-only charging.
You can also solder the B3B-PH-KL to a CPBP9P-10 pigtail (instead of the above pigtail) to plug the adapter directly into your PL8. This option utilizes the PL8 node-only charging.
The following two options eliminate the need to solder, but you'll need to buy the adapter that is compatible with your PL8 balance adapter (Thunder Power or JST-XH).
http://www.e-fliterc.com/Products/De...odID=EFLA700UM
http://www.e-fliterc.com/Products/De...dID=EFLA7001UM
There are also parallel adapters available, to charge multiple batteries at once.
typeRA is online now Find More Posts by typeRA
Old Jul 04, 2012, 01:19 PM
Gregor99 is offline
Find More Posts by Gregor99
Revolectrix Ambassador
Seattle
Joined Sep 2007
The ThunderPower G6 325mah 2s pack (TP325-2SPP65J) has a two wire discharge connector and no balance connecter. When I read the OPs question I assumed that was the pack he wanted to charge.
I also looked at this pack for my 130x. As I had intended on charging them on parallel, the unbalanced preset may not have been suitable as it has a 2 amp limit. Plus, I really don't like parallel charging without balance leads.
Luckily RCBabbel is modifying these packs to have balance connectors while reducing the pack weight http://www.rcgroups.com/forums/member.php?u=54990
This is the parallel board I'm using. I did modify the interconnect cable by cutting off the JST-XH 2s connector and replacing it with a 9 pin FMA pigtail. That configuration makes it compatible with both the Powerlab6 and the Powerlab8.
http://epbuddy.com/index.php?main_pa...roducts_id=348
Gregor99 is offline Find More Posts by Gregor99
Old Jul 04, 2012, 11:39 PM
Gregor99 is offline
Seattle
Joined Sep 2007
I finally got to test this board today. Though it does work quite well, it turns out that not all lines are fused. Only cell1-postive and cell2-positive. Negative is not fused. As a result the IR values are on cell #2 are incorrect. Yes, I am using FMA wiring mode and yes, the red wire is in pin 9 on the balance connector that goes into the charger.
Question Help Getting a Cellpro Multi4 to Charge a 3s LiPo Pack w/no Balance Tap JimHSoars Batteries and Chargers 9 Jun 19, 2011 01:51 PM
Sold A123 1100mAh - 2 cell receiver packs w/balance taps Dukester Aircraft - Electric - Batteries & Chargers (FS/W) 0 Jan 09, 2010 11:13 PM
Help! Will TP Retrofit My Gen 1 and 2 Packs with Balance Taps? wannabe Batteries and Chargers 2 Feb 05, 2006 06:08 AM
Will my 4-7 cell charger, charge my 8 cell 500AR pack??? AlexP Power Systems 4 Jul 25, 2001 03:48 AM
Will my 4-7 cell charger, charge my 8 cell 500AR pack??? AlexP Foamies (Kits) 1 Jul 23, 2001 07:23 PM
