Old Oct 08, 2012, 10:28 AM
oldtribefan
oldtribefan's Avatar
Walnut Creek, CA
Joined May 2007
Looking good! Perfect choice for the stain color.
oldtribefan is offline Find More Posts by oldtribefan
Old Oct 08, 2012, 10:50 AM
Woodfumbler......
Sharky1dk's Avatar
Copenhagen. Denmark
Joined Apr 2010
Yes glass it, i was a wimp when i did mine, but got at it at my CC Commander. Now i tried it i am sure i will glass everything, i love when the glass "magically" disappear in the epoxy.
Sharky1dk is offline Find More Posts by Sharky1dk
Old Oct 14, 2012, 05:46 PM
Joined Jul 2008
It is pretty magic when the cloth disappears and it makes you feel like your hull is now just short of bulletproof. Then the sanding begins yet again…
Kcal is offline Find More Posts by Kcal
Old Oct 15, 2012, 05:11 PM
time poor
the_11th_guest's Avatar
Australia, QLD, Brisbane
Joined Feb 2012
Well I chickened out on the glass and just followed the instructions in the kit. Only one coat of epoxy so far on the deck and the sides. It looks pretty rough but it has a hint of the shine that is to come.
Work on the hull will have to pause for a while as the next step requires the motor package from mack.
I have worked out how to make the water cooled manifolds for the scale engine so stay tuned for pics of that later.
the_11th_guest is offline Find More Posts by the_11th_guest
Old Nov 04, 2012, 04:49 PM
time poor
Joined Feb 2012
While I wait for the motor and ESC to arrive from Mack (posted 7 days before Sandy so I hope it’s not at the bottom of the ocean- my prayers are going out to all of you over there.)
I have been working on modifying the 427 ford V8.
I dropped the sump off so that it fits under the hatch, cut the fan off and scratch built some water cooled manifolds. Have a look at the photo descriptions for more info on the build of the manifolds.
Old Nov 04, 2012, 04:58 PM
mahoganyfan
californiakid's Avatar
United States, NJ, Atlantic City
Joined Nov 2010
Fantastic!
Looking great.You are definatley thinking outside the box on this build.
californiakid is offline Find More Posts by californiakid
Old Nov 05, 2012, 01:15 AM
Taking care of the pond.
MILLERTIME's Avatar
USA, CA, Fresno
Joined Apr 2004
Looks like a manifold to me.
MILLERTIME is online now Find More Posts by MILLERTIME
Old Nov 05, 2012, 07:51 AM
Rmay's Avatar
Louisiana
Joined Sep 2006
I love repurposed build items!
Absolutely beautiful job on the manifolds.
Rmay is offline Find More Posts by Rmay
Old Nov 05, 2012, 07:45 PM
Joined Jul 2008
Those are sharp.
Old Nov 05, 2012, 09:15 PM
time poor
Joined Feb 2012
Originally Posted by Kcal View Post
Those are sharp.
Well, they used to be but I didn't use those bits
Thanks guys, your praise is encouaging!
The motor and ESC arrived today so this Friday arvo I can start again on the hull, great timing I say!
Old Nov 07, 2012, 12:34 AM
Tygum Lagoon Terror
nick_75au's Avatar
Australia, QLD, Regents Park
Joined Mar 2007
Excellent work, My 427 remains manifoldless
Nick
nick_75au is offline Find More Posts by nick_75au
Old Nov 14, 2012, 04:16 PM
time poor
Joined Feb 2012
Parts! Yay. I now have everything I need but for the batteries,
I know some you you have had trouble with the Mack power pack for this boat but I figured that she is going to be a shelf queen most of the time and this way I don't have to think too hard.
The Proboat gear certainly looks good with a nice anodized blue/ stainless finish for both the ESC and the motor. Macks motor mount is nice to, in a anodized red that should blend well with the colour I'm planing for the inside of the hul.
The Mack ball joint universal is well made, however the female part did not fit onto the spindle of the motor and had to be redrilled, (a bit of a headache and I woke up the kids). Edit: I'm an idiot and didn't read the instructions right- It's not supposed to fit on the motor but on the prop shaft.
Another gift from my family was the radio, it's a Planet T5 2.4GHz 5 channel, I can't find any poor reports online about it and it only cost $80.
So to work,
Following the instructions I installed the stuffing tubes for the rudder and the prop shaft. I taped up where they come out of the hull in order to fill the stuffing boxs with epoxy, locking the shafts in place, but the tape failed
Long story short, big mess but the first go left enough of a seal to be able to fill up the stuffing box with a new batch of epoxy the next day.
For anyone doing this kit, something to be aware of is that the frame/bulkhead to the rear of the engine bay cuts into the the stuffing box, this leaves a gap for the epoxy to flow out of. If you run a bead of glue around where the frame meets the keel before you poor the epoxy you will stop the flow.
Old Nov 14, 2012, 06:22 PM
Joined Dec 2004
[FONT="Arial"][SIZE="3"]I checked out your photos of the problem you said you had with the harden ball joint universal for the brushless motor set up on the cracker box. By the looks of the picture I would have to say you put the wrong side of the universal on to the motor shaft which is 5mm (male ball end). The propeller shaft side (female end) is a 3/16” bore.
http://www.rcgroups.com/forums/attac...mentid=3141027
frankg is offline Find More Posts by frankg
Old Nov 15, 2012, 03:20 PM
time poor
Joined Feb 2012
Frankg, you are right of course, I withdraw my comment, I was so excited about getting going again that I miss read the instructions .
So I gave myself a smack on the back of the head Agent Gibbs style.
I'll leave it like that I think as it will take quite a bit of persuasion to get the female end off the motor again. If it's all bad news I'll swap it.
Old Nov 19, 2012, 03:38 PM
time poor
Joined Feb 2012
We had a very big weekend so boat time was limited. Epoxyed the bottom and painted the underside of the hatches.
The Bote Coat Epoxy system is going on really nicely and it brings out the colours of the mahogany well. I'll be painting the bottom white but it does seem a pity to cover those colours.
New Product LEGEND MODEL BOATS "California Cracker Box" frankg Scale Boats 215 Nov 11, 2012 02:14 PM
Yippee! HELP Nedd Help Finding A 1st Class Cracker Box Kit....Newbee ikke Dock Talk 4 Jun 15, 2009 08:08 AM
Is Ca glue safe to use in the building of a 1/4 SCALE cracker box kit? rceagle1a Dock Talk 1 Mar 24, 2005 08:37 PM
Help on all aspects of a Dumas 1/4 scale cracker box kit rceagle1a Dock Talk 0 Mar 13, 2005 07:18 AM
Alert Cracker box Leon Cruchelow Racing Boats - Internal Combustion 4 Sep 24, 2004 04:07 PM
