Old Aug 26, 2012, 12:12 AM
GliderJim is offline
Find More Posts by GliderJim
GliderJim's Avatar
Michigan, USA
Joined Jul 2006
Lookin' good!
GliderJim is offline Find More Posts by GliderJim
Old Aug 26, 2012, 10:08 AM
osprey is offline
Find More Posts by osprey
United States, MI, Alpena
Joined May 2003
darn control line ( i miss it)
the fun of getting dizzy lol
osprey is offline Find More Posts by osprey
Old Aug 26, 2012, 12:41 PM
RknRusty is offline
Find More Posts by RknRusty
RknRusty's Avatar
United States, SC, Columbia
Joined May 2010
I love it, great fun on a fairly small budget. I only used a half full bladder yesterday, and that won't make me dizzy. The only time I really get dizzy is if I fly a bunch of inverted laps. Strange how the inner ear works, flying backwards is like when you first start learning to turn in the circle. I start feeling it after 3 or 4 laps.
RknRusty is offline Find More Posts by RknRusty
Old Aug 26, 2012, 02:07 PM
aspeed is online now
Find More Posts by aspeed
Canada, ON, Cottam
Joined Jan 2012
Get a pole trimmer for the tree and trim it. I think the prop is about right for the .051, about 18,500 rpm. It has a heavy steel piston, they don't stand up to the revs like the Norvels and the more modern stuff. Looks like a hoot.
aspeed is online now Find More Posts by aspeed
Old Aug 26, 2012, 04:24 PM
RknRusty is offline
RknRusty's Avatar
Joined May 2010
Definitely fun to fly. I had guessed it was faster than that. But I have an eager imagination. Especially with everyone claiming their Tee Dees turn twenty something grand.
Old Aug 26, 2012, 05:23 PM
Canada, ON, Cottam
Joined Jan 2012
Ya it is a D# on the pitch pipe. You could tell it was unloading a lot in the air. I can't check that without being inside the circle. The bigger, higher pitched props unload more in the air. Still, a 3" pitch would end up at maybe 55 mph. I didn't check your lap times, and wouldn't know without a speed chart. It looked pretty fast to me. Everyone that gets over 20,000 rpm has to reset the socket and don't go a whole lot faster. You need a stopwatch to see, but it isn't serious like Mouse Racing or anything?..
Old Aug 26, 2012, 07:59 PM
RknRusty is offline
RknRusty's Avatar
Joined May 2010
I used the video to time it for two flat laps, the only consecutive low flat laps I could find before it started fuel starving. From 1:24 to 1:30 I turned two flat laps, so 3 second laps at 40' plus about 26" of my arm ~ 42'. I'll try to do the geometry figure out the speed. Or find a chart. I'm just curious now.
EDIT: so over 6 seconds it traveled 527 feet(2 laps). If I did the math right, that comes out to 59.9mph. I'll try to double check that.
I think the plane's AUW is about 7.5 ounces, 8oz with fuel.
Old Aug 26, 2012, 09:57 PM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
Every video an improvement :-)
. IF space constrained .. Plant a Tube into the ground at the centre of your space and Keep your left hand on it.
~59mph is mediocre speed.. Although you are still on too short lines.
TD's can ..Easily... hit 25K on a 5x3 COX black rubber ducky prop and 30%.
Throw away the crap props.
They are useless millstones :-).
Bare is offline Find More Posts by Bare
Old Aug 27, 2012, 02:41 AM
surfer_kris is offline
Find More Posts by surfer_kris
surfer_kris's Avatar
Sweden
Well, then you won't have any problems with showing us a video of that, right?
surfer_kris is offline Find More Posts by surfer_kris
Old Aug 27, 2012, 11:44 AM
RknRusty is offline
RknRusty's Avatar
Joined May 2010
I'll take that as a vote of approval, thanks Bare.
I would fall over a pole in the ground and impale myself... on video, no doubt. I'll just try harder to keep an eye on my spot marker.
59 was comfortable for me, much less frantic than the previous flight on 35' lines. It's moving fast enough to be fun, so it'll do for now.
Master Airscrew props are crap? I have yet to break one. The 6x3 GF series is what I buy to cut down and round off the square tips, and they're a lot less work to balance than the Rubber Duckys. And they make my plane go. Works for me.
Old Aug 27, 2012, 12:08 PM
Bare is offline
Canada
Joined Nov 2000
OK.. it's your model :-).. but the rubber duckies have proven for a few decades as the best allrounder. Still are. Balancing those is a problem? wasn't in the past.
Being tough to break is No small advantage as well
Most props work acceptably well, no arguement, but some are markedly faster than others. A big deal if speed and power thru turns is important.
Try one? it 'should' tighten up those loops?
Never broken a TD crank? Can't be many left that haven't had that experience Mechanical limit is ~25k. ..God's own Tachometer Telltale :-)
PS: interesting 1/2A Combat piccies.. some. Sadly it's now only Old men and fewer each year. A Sunset sport.. sigh.
http://flyinglines.org/BG.2012.html
Old Aug 27, 2012, 02:19 PM
Jim Thomerson is offline
Find More Posts by Jim Thomerson
First, I an convinced that 1/2A size airplanes have to have a faster lap time than larger airplanes. Back when I was seriously flying 1/2A stunt, I would fly two or three patterns with my 1/2A and then fly the Fox 35 airplane. It was just so slow and easy to fly after flying the 1/2A. I found on flying my Jr Flite Streak on 55 ft eylet to eylet, that I was getting 3.8 sec laps. At that speed, i was doing a certain amount of herding the airplane rather than flying it. I went to 57 ft lines which got it up to 4 sec, and could fly it well enough to win at a small regional contest. Stunt guys like to talk about 5 second, more or less laps as being good.
Jim Thomerson is offline Find More Posts by Jim Thomerson
Old Aug 27, 2012, 03:53 PM
Sweden
So you've never actually tacked a TD doing 25000rpm on a 5x3 prop then?
Old Aug 28, 2012, 08:01 PM
OkiThumper is offline
Find More Posts by OkiThumper
Closed Account
Joined Feb 2006
I liked the OP's video. Interesting way of launching using a stooge. Never thought of that possibility for solo flying.
OkiThumper is offline Find More Posts by OkiThumper
Old Sep 06, 2012, 11:31 PM
RknRusty is offline
RknRusty's Avatar
Joined May 2010
I get a lot of comments on that. It's a folded $5 dollar bath mat with a rubber lined bottom, folded so the rubber holds the wing. Adjust the bungee across the top to fit the angle of the wing you're sticking in it. I lay the edge of the brick on the bungee for added grip, to keep it from twisting when you walk away to the control handle. But not so tight that you stress the bellcrank pulling it out. Use a cord and a stake in the ground so you don't tip it over pulling the plane free. For lighter planes, I don't bother putting the table on top of the bar stool.
Here it is without the barstool. The bungee isn't adjusted right in this picture. I usually align it along the TE of the wing. The cord and stake don't show up in this picture. It has proven to be very safe. Good to haul outside of the shop for test running engines on planes too.
Description: Stooge
Found Sky babies are ready for shipping. icharus Aircraft - General - Miscellaneous (FS/W) 3 Jun 30, 2012 09:34 PM
For Sale New 1/4 Scale Sky Baby kit with Ailerons, Cowl and More*** Joe Pierson Aircraft - Electric - Airplanes (FS/W) 2 Jan 23, 2011 10:26 PM
Video AEF 2008 EDF's tearing up the sky Quiet E. Flyer Electric Plane Talk 10 Feb 04, 2008 11:30 PM
Video MDC-F14 Tearing up the sky. cryhavoc38 Electric Plane Talk 2 Jan 27, 2008 08:08 AM
Another Walmart $2.99 special tears up the sky. NewbieX Foamies (Kits) 7 Jun 21, 2001 08:40 PM
