Old Jul 02, 2012, 09:41 PM
chuenwe is offline
Find More Posts by chuenwe
chuenwe's Avatar
United States, NY, Huntington Station
Joined May 2012
Question
How to increase flight time?
I built a Talon Hexa and it went through a few revisions. The build thread is here.
I did a few test using different batteries but seems to be hitting the copter/motor's limit. What can I do to increase the flight time with minimal changes? I'm thinking I could try a set of higher power motor, but I'm hopping to see if anyone have any experience in this aspect.
Here are some detail/spec:
Spec:
Flight Controller: DJI NAZA
Motors: AC2836-358, 880Kv
Props: GemFan 10x4.5
ESC: 6 x Turnigy dlux 30A (2s~6s)
BEC: Castle Creations' CC BEC
Here are some flight time numbers:
Take Off Weight: 2.4Kg
Batteries: 2x 2250mAh
Flight Time: 7 minutes
Weight: 3.02Kg (carrying a FPV camera)
Batteries: 2x 5000mAh
Flight Time: 14 minutes (but the battery was completely exhausted. The battery warning was set too long)
Weight: 3.48Kg (carrying a FPV camera)
Flight Time:15 minutes (this time I have the Battery Warning set at 11.2V)
Actual Power used: 12403mA (measured from the battery charger)
Batteries: 2x 8400mAH
Motors were hot, but it's not hot enough that I can't hold on to it.
ESC was warm
Weight: 4.202Kg (carrying a Canon T2i that I would not normally use)
Flight Time: 5m 42 seconds
Actual Power used: 5619mA (measured from the battery charger)
LiPo voltage after landed: 11.4V
Motors: Hot. I could hold it for 3 seconds and I had to let it go.
ESC: warm.
Batteries: slight warm
chuenwe is offline Find More Posts by chuenwe
Old Jul 02, 2012, 09:51 PM
nicnaimless is offline
Find More Posts by nicnaimless
nicnaimless's Avatar
United States, MI, Jenison
Joined Jun 2008
Fly more often
nicnaimless is offline Find More Posts by nicnaimless
Old Jul 02, 2012, 09:55 PM
Joined Jun 2008
Have you been using http://www.ecalc.ch/xcoptercalc_e.htm?ecalc to help benchmark your setups?
Old Jul 02, 2012, 09:56 PM
chuenwe is offline
chuenwe's Avatar
Joined May 2012
Yea, the ecalc told me I could not even take off at 3.3Kg. And it apparently was wrong.
Old Jul 02, 2012, 10:05 PM
Joined Jun 2008
What C rating are your Lipos
Old Jul 02, 2012, 10:07 PM
chuenwe is offline
chuenwe's Avatar
Joined May 2012
The 5000mAh ones are the Zippy 40C and the 8400mAh ones are the Turnagy nanotech 40C. I run them in pair in parallel, so essentially, they are 80C.
Old Jul 02, 2012, 11:13 PM
sirbow2 is offline
Find More Posts by sirbow2
Emress
Joined Nov 2011
put a 4s lipo on there with some 11x4.5 props(since 3s uses 12x4.5).
20A motors for that much weight isn very big; get some bigger motors. 30Amp draw maybe?
sirbow2 is offline Find More Posts by sirbow2
Old Jul 02, 2012, 11:15 PM
chuenwe is offline
chuenwe's Avatar
Joined May 2012
I'm only using 10x4.5 thou with my 3s.
Old Jul 02, 2012, 11:28 PM
sirbow2 is offline
Emress
Joined Nov 2011
yeah that's too much load on those motors cause it getting hot even with 10x4.5 when its meant for 12x4.5 on 3s
Old Jul 02, 2012, 11:32 PM
jy0933 is offline
Find More Posts by jy0933
James not bond
jy0933's Avatar
Joined May 2012
use better motor.. and lower the current load...
jy0933 is offline Find More Posts by jy0933
Old Jul 02, 2012, 11:33 PM
chuenwe is offline
chuenwe's Avatar
Joined May 2012
I'll try some 12x4.5 then. Thx.
Old Jul 02, 2012, 11:34 PM
chuenwe is offline
chuenwe's Avatar
Joined May 2012
What would you recommend?
My current motor seems pretty good:
Power out put from ESC, 3S LiPo, 12x45 Propeller
25% 50% 75% 100%
Amp
Wattage
Thrust 1.5 A
17.5W
230gr 6.1 A
70W
650gr 14.2 A
160W
1290gr 20A A
210W
1380gr
Old Jul 02, 2012, 11:36 PM
sirbow2 is offline
Emress
Joined Nov 2011
what i meant is that you have so much weight that it is even making the motors hot on 10x4.5, it will be worse on 12in props.
not for this weight
Old Jul 02, 2012, 11:40 PM
jy0933 is offline
James not bond
jy0933's Avatar
Joined May 2012
honestly... sell the 3s... use 4s(even 5s if you get high grade motor) pack
pretty simple physics.... V*I=P.... at same power... higher volt >> lower current....>>> lower current>>> longer flight time (count resistance which goes motor/esc heating up..) the final time will be about.. 5~10% less... theoretically
Old Jul 02, 2012, 11:41 PM
chuenwe is offline
chuenwe's Avatar
Joined May 2012
So what would you recommend?
But anyway, the 4KG test was just to see how much weight it COULD carry. I've never planned to carry a hefty 1.1Kg Canon T2i. So the actual flight weight is much lighter. I just want longer flight time.
Discussion How to extend flight time on hexacopter skyeyeproject Multirotor Talk 40 Aug 09, 2015 03:43 AM
Discussion Improving flight times. lassjus Multirotor Talk 38 Jun 16, 2012 10:20 AM
Question Theoretical flight-time -vs.- practical Flight-time vineet_p Multirotor Talk 16 May 26, 2012 12:49 PM
Mini-HowTo S107 Extended Flight Times - How To HaMm3r Coaxial Helicopters 17 Mar 07, 2012 10:16 AM
Logo 10 - How to increas flight time? test3 Electric Heli Talk 5 Jul 11, 2003 01:28 AM
