Old Feb 18, 2013, 07:33 AM
GoFaster is offline
Find More Posts by GoFaster
Live for speed
GoFaster's Avatar
USA, CT, Bethany
Joined Mar 2004
Originally Posted by joebarteam View Post
Manual: throttle = throttle, yes obviously when you throttle up, you probably go up
Not manual: throttle = change altitude
An example, say are flying in turbulent conditions with strong up and downdrafts.
In manual mode, you'd be constantly on the throttle to maintain altitude. It would also be difficult to perform a smooth ascent or descent.
In PH or DVH, if your throttle stick is at center, AQ will automatically maintain altitude in a down or updraft of wind. If you move your throttle up, the AQ will smoothly increase altitude while still compensating for the up/down conditions. Ditto for smooth descent if the throttle stick is decreased beyond mid-point.
The max rate of altitude change is a settable parameter.
Throttle can be on any channel you want.
GoFaster is offline Find More Posts by GoFaster
Old Feb 18, 2013, 02:57 PM
Panama TJ is offline
Find More Posts by Panama TJ
AD6-HL, MK3638, Pro Mount-200
Panama TJ's Avatar
Panama
Joined Oct 2011
Originally Posted by JussiH View Post
Send me an email!
20 cm should not be a problem, but I will probably need to get some pigtails to work with. I am not at the workshop PT, but I will check tomorrow if I have the needed pigtail to create an antenna for you right away, if not, there will be a little delay on the antenna, but it can be sent later as you wont need it for calibration and setup.
It's done, purchased, now Ill be a patient, or at least Ill try, many thanks!
Mark.
Panama TJ is offline Find More Posts by Panama TJ
Old Feb 18, 2013, 04:10 PM
Jdmagoo is offline
Find More Posts by Jdmagoo
Australia, SA, Adelaide
Joined Aug 2012
Excellent now makes sense thank you.
I have a few more questions please, my understanding for return to home is the home location and altiude must be first set after take off, now when RTH is activativated will the FC automatically climb to the pre recorded altitude before coming home? Or will it come home then climb to the predetermined altitude? If the FC is higher than the predetermined altitude when RTH is activated will it just come home at that higher altitude or will it descend first then come home?
Failsafe, I assume the RTH process once the stage 2 fail safe is activated is the same as manually switching RTH? If not could someone please explain?
Finally, I have a Graupner Hott MX 20 with a GR24 rx, the PPM output works fine however with the naza m FC failsafe is not recognised via the PPM signal. This seems to be only with the graupner radio as with other brands of radio the failsafe seems to work via PPM. Does the autoquad FC recognise failsafe via the PPM signal on the graupner Hott MX 20 radios?
Thanks again for your time to answer
James
Jdmagoo is offline Find More Posts by Jdmagoo
Old Feb 19, 2013, 05:21 AM
skew is offline
Find More Posts by skew
United States, KY, Morehead
Joined Jan 2005
The RTH will climb or descend along the route to meet the set home location alt. Basically just draw a imaginary line between the point you engage RTH & the set home point this will be the flight path.
skew is offline Find More Posts by skew
Old Feb 19, 2013, 05:41 AM
joebarteam is online now
Find More Posts by joebarteam
J'ai remis la purée
Netherlands, ZH, Zoetermeer
Joined Mar 2011
James
No, it will not ascend, that will require a mission and the rtl is just one command.
It is asked a lot, so maybe in future ?.
Yes it will recognize the hott fail safe, it will detect a lost signal and therefore the graupner version is actually perfect
joebarteam is online now Find More Posts by joebarteam
Old Feb 19, 2013, 06:59 AM
Jdmagoo is offline
Joined Aug 2012
Old Feb 19, 2013, 11:54 AM
JussiH is offline
Find More Posts by JussiH
Friend is a 4 letter word...
JussiH's Avatar
3rd stone from the sun
Joined May 2007
New video from one of our more determined and fearless Beta-testers:
AQ octo in a Blizzard (1 min 12 sec)
Thumbs up!
JussiH is offline Find More Posts by JussiH
Old Feb 19, 2013, 08:04 PM
chris24g is offline
Find More Posts by chris24g
United States, CA, Hayward
Joined Apr 2006
so that's why you make us put the AQ in the freezer lol
chris24g is offline Find More Posts by chris24g
Old Feb 20, 2013, 06:06 AM
kinderkram is offline
Find More Posts by kinderkram
OS Sponsor
kinderkram's Avatar
Germany, NRW, Dusseldorf
Joined Jun 2010
Wanna show your AQ6 adiction?
We have found someone producing T-Shirts and stickers with the AQ logos.
Find more info here: http://forum.autoquad.org/viewtopic.php?f=23&t=2111
kinderkram is offline Find More Posts by kinderkram
Old Feb 20, 2013, 08:56 PM
13brv3 is offline
Find More Posts by 13brv3
13brv3's Avatar
Navarre, FL
Joined Mar 2002
I'm thinking of doing the cal in the refrigerator, since I'm not going out when it gets any colder than that
Cheers,
Rusty (AQ has finally left the ground)
13brv3 is offline Find More Posts by 13brv3
Site Sponsor
Old Feb 20, 2013, 10:39 PM
richkphoto is offline
Find More Posts by richkphoto
United States, MN, St Cloud
Joined Jan 2012
Cheers,
You can just come and vis[t me in Minnesota, it's been colder outside than my freezer can get (-20F last night) so you could just stand outside with your board to freeze it or have the Postman carry along on his route
richkphoto is offline Find More Posts by richkphoto
Old Feb 21, 2013, 02:19 AM
JussiH is offline
JussiH's Avatar
Joined May 2007
Cheers,
Hey, good news. Congrats!
Old Feb 27, 2013, 12:38 PM
axelnied is offline
Find More Posts by axelnied
Axel N.
axelnied's Avatar
United States, CA, San Diego
Joined Feb 2011
Originally Posted by Dialfonzo View Post
Here is the first print of the case.
Will have to change some minor dimensions problem in it, but other than that it fit very nicely.
Pictures with the board in will come..
Dialfonzo,
Can you update us on the status of the enclosure?
Shapeays is listing it for US$ 33 (in sandstone color) which sound good to me.
Have you made the changes you were talking about?
axelnied is offline Find More Posts by axelnied
Old Feb 27, 2013, 12:47 PM
JussiH is offline
JussiH's Avatar
Joined May 2007
Originally Posted by axelnied View Post
Dialfonzo,
Well, maybe I can answer that.
Basically, no - the changes are not made yet. I have been totally busy, so I have not gotten around to make all the measurements yet. I will put it forward now!
Old Feb 27, 2013, 12:58 PM
axelnied is offline
Axel N.
axelnied's Avatar
Joined Feb 2011
Jussi,
Thanks for the response... Project management is one of the hardest things to do: In order to get one projects forward you have to put some other project on a lower priority - I do understand.
My point would be that more and more people are getting their AQ's off the ground and since it is an expensive piece of equipment, it would make sense to protect it.
This morning I experienced a crash out of 8 meter (~25 feet) . Good news is it fell on grass... Bad news is broken carbon arm, ripped wires and a number of bent pins on the AQ board. Have not yet time to fully evaluate the damage to the board, but it appears to be "okay". Since there are 14 outputs, even if all 6 outputs I used are screwed, I have plenty others to choose from!
I was flying a mission, and it execited 3 waypoint correctly when it just dropped out of the sky. When I find time I will post the LOGS on the AQ forum. Was using r76.
New Product Autoquad team proudly presents: Autoquad ESC32 JussiH Multirotor Electronics 301 Apr 16, 2016 09:05 PM
Discussion Naza dji sh gps - south hemisphere public beta testers results! Velociraptor73 Multirotor Talk 26 Nov 20, 2012 01:45 AM
Discussion How Bloomberg's Soft Drink Ban Will Backfire on NYC Public Health MtnGoat Life, The Universe, and Politics 1 Jun 26, 2012 11:19 PM
Discussion The AutoQuad! [ video ] kapteinkuk Multirotor Talk 5 Jun 10, 2012 11:19 AM
Download G-3 Public Beta (.426) is out. Includes Airplane Importer! L0stS0ul Simulators 37 Mar 03, 2006 05:28 PM
