Old Feb 08, 2013, 01:04 PM
Joined Feb 2012
Originally Posted by GoneSilent View Post
Dialfonzo, looking forward to the case. Are you going to share the files for those who can print at home or?
Anyone Should I order Graupner MX-20? Or just use one of my Futaba 8fgs? I kind of am fearing the S-Bus stuff Ive seen on forum and wiki.
I as well as Max I believe, had problems using S.Bus converters. I dont know if the same problems came up using Futaba radios with normal S.Bus recievers. If you already have the equipment you can test it by hooking everything up through S.Bus and going through the S.Bus thread on the AQ forum and using the radio input combinations that caused the problems for us and then looking at your radio RSSI graph and looking for any point where its not 100%.
epyonxero is offline Find More Posts by epyonxero
Old Feb 08, 2013, 03:30 PM
AutoQuadder
maximal's Avatar
near Ithaca, NY, US
Joined Aug 2004
The problem with SBus is that Futaba has never published any protocol data and all we know, as far as I can tell, stems from one person's analysis of one SBus system a couple years ago. Even an official SBE-1 Sbus adapter didn't work correctly with the AQ for some reason. And now apparently Futaba has new Rxs with SBus2 and SBus, but the SBus output isn't the same as the original SBus (http://forum.autoquad.org/viewtopic.php?f=33&t=2068). At the same time, FrSky and Orange have their own SBus "compatible" systems, at least some of which don't seem to work right with AQ either. FrSky is adopting SBus for some upcoming new systems (16 channels!), so I'm curious to see what that actually means in practical terms.
SBus is a great idea, but without an official standard, it's a bit of a moving target at this point. But the older/original Futaba SBus Rxs have been known to work well with the AQ.
-Max
maximal is offline Find More Posts by maximal
Last edited by maximal; Feb 08, 2013 at 06:55 PM. Reason: FrSky is adopting SBus... (not "adapting")
Old Feb 08, 2013, 05:06 PM
bob4432's Avatar
United States, AZ
Joined May 2010
Futaba needs to get their sh)t together and understand that multis are here to stay and they may need to let the designers open to the protocol, or we will all be forced to frsky as they give use what futaba will not. You can't go wrong w/ a 9c+frsky module.
bob4432 is offline Find More Posts by bob4432
Old Feb 08, 2013, 05:53 PM
Aerhead
MN
Joined Mar 2009
Gone
Spektrum Tx and a Spekturm satellite is the easiest to setup.
Larry
Aerhead is offline Find More Posts by Aerhead
Old Feb 09, 2013, 03:29 AM
flitelab's Avatar
Canada, NS, Halifax
Joined Feb 2010
Originally Posted by Dialfonzo View Post
Eric - are you running an AQ setup?
This needs to be soon on my todo list.
flitelab is offline Find More Posts by flitelab
Site Sponsor
Old Feb 09, 2013, 04:59 AM
OS Sponsor
kinderkram's Avatar
Germany, NRW, Dusseldorf
Joined Jun 2010
Ladies & Gentlemen: We have a Release Candidate!
Our Chief Developer Bill tagged the latest r76 as v6.6.0 rc1 and Max uploaded new versions for both board revisions in the DL section.
http://autoquad.org/software-downloads/?category=3
Read Max' post about formalities here:
http://forum.autoquad.org/viewtopic....tart=10#p10501
As always you'll find info about the recent changes here:
http://autoquad.org/wiki/wiki/whats-...mware-changes/
Now let the fun begin! Feedback is highly appreciated - expect more to come soon.
Norbert
kinderkram is offline Find More Posts by kinderkram
Old Feb 09, 2013, 05:02 AM
Press play on tape..
JussiH's Avatar
3rd stone from the sun
Joined May 2007
Great, If reports are good, I would say that we should see the end of the Beta very soon.
Norbert
JussiH is offline Find More Posts by JussiH
Old Feb 09, 2013, 06:05 AM
(My english is Bad - Sorry)
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
I have not yet setup it.
Will probably go with the HUGE motors i got from you..
Did the case for Jussi, hopefully everything will work on it..
Dialfonzo is offline Find More Posts by Dialfonzo
Old Feb 09, 2013, 12:14 PM
San Marcos, TX
Joined Jan 2010
GRAUPNER mx-20 with AQ?
This was asked a few posts up and I see someone reporting no ppm glitches with a AQ 6.6 r75 v2?
Are others having success with Graupner mx-20 AQ?
Want try AQ but don't want to buy new radio equipment.
Mactadpole is offline Find More Posts by Mactadpole
Old Feb 09, 2013, 12:37 PM
France, Midi-Pyrénées, Cordes-sur-Ciel
Joined Oct 2011
I am using an MX20 Hott and GR 24. No problem. I am in SUM. One output towards the AQ.
pepere is offline Find More Posts by pepere
Old Feb 09, 2013, 12:40 PM
OS Sponsor
kinderkram's Avatar
Joined Jun 2010
Yes, it's working very well. In fact the MX20s have some advantages over other radios.
Mav2HoTT (4 min 25 sec)
Old Feb 09, 2013, 12:57 PM
San Marcos, TX
Joined Jan 2010
Thanks. I had read reports of some ppm glitches in previous GW but it sounds like all is good now. I do love graupner telemetry with MK so nice to see it on AQ.
Old Feb 10, 2013, 02:30 AM
OS Sponsor
kinderkram's Avatar
Joined Jun 2010
Another short video demonstration upcoming features like "follow me" and "click & go", this time using an XBee Pro unit connected via USB host to an Android tablet:
AQ6 FollowMe 1st try (2 min 31 sec)
Old Feb 11, 2013, 05:33 AM
sorry, my english is bad
teramax's Avatar
Austria, Wien, Vienna
Joined Apr 2011
certainly u also can have some fun whith the AutoQuad
AutoQuad FollowMe beta test (4 min 48 sec)
teramax is offline Find More Posts by teramax
Old Feb 13, 2013, 01:50 PM
France, RA, Caluire-et-Cuire
Joined Sep 2009
I use MX20 + GR24 + SUMPPM with autoquad and it's works fine.
I also have to add in the code r76 the possibility of connecting a receiver in mode SUMD
SUMD = serial connection use between the receiver and the AQ (available in the last HOTT version)
Furthermore with a MX20 you can use the addon Mav2Hott.
more detail in french http://autoquad6.free.fr/grhott-sumd...ad-grhott.html
fred_fr is offline Find More Posts by fred_fr
New Product Autoquad team proudly presents: Autoquad ESC32 Public Beta JussiH Multirotor Electronics 260 Jun 05, 2013 01:53 AM
Discussion Naza dji sh gps - south hemisphere public beta testers results! Velociraptor73 Multirotor Talk 26 Nov 20, 2012 01:45 AM
Discussion How Bloomberg's Soft Drink Ban Will Backfire on NYC Public Health MtnGoat Life, The Universe, and Politics 1 Jun 26, 2012 11:19 PM
Discussion The AutoQuad! [ video ] kapteinkuk Multirotor Talk 5 Jun 10, 2012 11:19 AM
Download G-3 Public Beta (.426) is out. Includes Airplane Importer! L0stS0ul Simulators 37 Mar 03, 2006 05:28 PM
