Old Jan 13, 2013, 03:36 AM
skew is offline
Find More Posts by skew
United States, KY, Morehead
Joined Jan 2005
I've got around $450-500+about 10 hours to assemble but my labor is dirt cheap
skew is offline Find More Posts by skew
Old Jan 13, 2013, 04:40 AM
kinderkram is offline
Find More Posts by kinderkram
OS Sponsor
kinderkram's Avatar
Germany, NRW, Dusseldorf
Joined Jun 2010
Originally Posted by skew View Post
My 3d printer is alive just started calibration prints. AQ case to come soon
Nice one!
kinderkram is offline Find More Posts by kinderkram
Old Jan 13, 2013, 07:21 AM
Dialfonzo is offline
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Nice build.
Those are fun to play with.
Here is mine.
Dialfonzo is offline Find More Posts by Dialfonzo
Old Jan 13, 2013, 07:36 AM
maximal is offline
Find More Posts by maximal
AutoQuad OS developer
maximal's Avatar
near Ithaca, NY, US
Joined Aug 2004
Originally Posted by kinderkram View Post
Peter aka sandmen has taken huge steps to bring TTS to the AQ Win version of the QGC.
Please use latest version found here: http://forum.autoquad.org/viewtopic....start=20#p9756
Also it is not necessary to install any additional software (the SDK or the VCC files). Text-to-speech has been included in Windows since at least XP.
Tilman aka RoseWhite and a German company created the ultimate carrier board for the AutoQuad.
Wow... that's stunning.
-Max
maximal is offline Find More Posts by maximal
Old Jan 13, 2013, 09:45 AM
joebarteam is offline
Find More Posts by joebarteam
J'ai remis la purée
Netherlands, ZH, Zoetermeer
Joined Mar 2011
Tilman aka RoseWhite and a German company created the ultimate carrier board for the AutoQuad. I'm afraid it'll be damn expensive though.
Ain't she a beauty?
Tilman ready outdone himself this time, wow this is looking absolutely amazing!. That would probably be the cleanest build ever when using this board.
Menno
joebarteam is offline Find More Posts by joebarteam
Old Jan 13, 2013, 11:02 PM
richkphoto is offline
Find More Posts by richkphoto
United States, MN, St Cloud
Joined Jan 2012
I have a dumb question, when flying a mission will it still fly if you go outside of your tx range?
richkphoto is offline Find More Posts by richkphoto
Old Jan 14, 2013, 01:14 AM
maximal is offline
maximal's Avatar
near Ithaca, NY, US
Joined Aug 2004
Rick, yes, it should continue the mission until finished. If it is still w/out radio reception at that point, it will then go into failsafe mode, but not before the mission is complete.
-Max
Old Jan 15, 2013, 05:56 AM
OS Sponsor
kinderkram's Avatar
Joined Jun 2010
Menno
The good thing is: I'll be getting a sample some day.
The bad thing: I need to save up for an Octo.
Old Jan 16, 2013, 12:12 AM
DVE is offline
DVE
Find More Posts by DVE
DVE
Russian Federation, Sankt-Petersburg, SPB
Joined Jul 2011
I launched my quad Thanks Kinderkram and others who helped me.
But... My 30$ Freeflight is flying better on this frame than this 400$ controller on default settings
Going down at the end... maybe battery was discharged.
Why altitude is not stable? I was flying in a manual mode, does it using baro in this mode? Can I use alt/pos.hold mode at home, or only outside when gps is available?
Tnx
DVE is offline Find More Posts by DVE
Old Jan 16, 2013, 01:31 AM
OS Sponsor
kinderkram's Avatar
Joined Jun 2010
In manual mode only gyro&acc are enabled, no baro.
To use alt hold indoors you need to use the latest firmware from the repo trunk, at least rev. 53
http://code.google.com/p/autoquad/source/list
Old Jan 16, 2013, 02:45 AM
maximal is offline
maximal's Avatar
near Ithaca, NY, US
Joined Aug 2004
DVE, we can't tell much from looking at the video, not knowing anything about your setup, and not seeing any logs. Come over to the AQ forums, post some logs, and we'll try to help you out. Just as a completely out-of-the-blue guess, I would say you have a lot of vibration issues.
-Max
Old Jan 16, 2013, 02:51 AM
DVE is offline
DVE
DVE
Joined Jul 2011
Thanks, I'll check more.
I think that if baro is not using, problem may be in incorrect ESC throttle range, I'll check it. Maybe signal is too low sometimes, and thus altitude unstable.
Btw, If I change motor settings in GUI, did I need to restart controller, or disarm/arm is enough?
Vibrations? Maybe, but all other controllers (Rabbit, APM 2.5, Freeflight) were flying well an this frame.
Old Jan 16, 2013, 03:19 AM
maximal is offline
maximal's Avatar
near Ithaca, NY, US
Joined Aug 2004
Motor settings take effect immediately (once sent to the AQ), no need to reboot. Vibration issues would be fairly obvious from looking at logs (I don't know about the others, but the Rabbit is much more forgiving of vibrations). Could be you just need some PID adjustments. On a small quad I built recently, I had to reduce the Tilt Rate D down to ~5100 before it would keep a steady altitude in manual mode. Get it flying stable in manual first (should be almost hands-off with no wind) before trying automatic modes.
-Max
Old Jan 16, 2013, 02:04 PM
r0sewhite is offline
Find More Posts by r0sewhite
It wasn't me
r0sewhite's Avatar
Augsburg, Germany
Joined Mar 2010
Hehe, I'm pretty sure that you don't even need to save money to buy 8 ESC32, unlike others have to do.
I wouldn't mind to offer you 8 Plettenberg motors but I think in this case Robert would kill me and as a headless man I could neather fly nor build new frames.
r0sewhite is offline Find More Posts by r0sewhite
Old Jan 16, 2013, 02:05 PM
DVE is offline
DVE
DVE
Joined Jul 2011
Thanks again. I recalibrate ESCs again, set min/max settings, and flying became smooth
The last problem, I cannot solve (I wrote in previous message "Going down at the end") - seems very strange. I checked battery voltage, its ok. But due to the log file, after some time of flight (usually less than minute) throttle level suddenly dropped down (I did not touched it!), thus quad go down too.
PS: Solved when I powered receiver with 5V, not 3.3
New Product Autoquad team proudly presents: Autoquad ESC32 JussiH Multirotor Electronics 301 Apr 16, 2016 09:05 PM
Discussion Naza dji sh gps - south hemisphere public beta testers results! Velociraptor73 Multirotor Talk 26 Nov 20, 2012 01:45 AM
Discussion How Bloomberg's Soft Drink Ban Will Backfire on NYC Public Health MtnGoat Life, The Universe, and Politics 1 Jun 26, 2012 11:19 PM
Discussion The AutoQuad! [ video ] kapteinkuk Multirotor Talk 5 Jun 10, 2012 11:19 AM
Download G-3 Public Beta (.426) is out. Includes Airplane Importer! L0stS0ul Simulators 37 Mar 03, 2006 05:28 PM
