Old Jan 11, 2013, 10:14 AM
skew is offline
Find More Posts by skew
United States, KY, Morehead
Joined Jan 2005
Dialfonzo, Looks Sweet!! Im building a reprap right now as we speak. That could be one of my first prints if you don't mind sharing your file when you finish your design.
skew is offline Find More Posts by skew
Old Jan 11, 2013, 10:38 AM
kinderkram is offline
Find More Posts by kinderkram
OS Sponsor
kinderkram's Avatar
Germany, NRW, Dusseldorf
Joined Jun 2010
Originally Posted by Dialfonzo View Post
Hi All,
This is not a final design.
Still more to add and remove to that model like light view and some sizing to fit better.
But i want you to give me some feedback
Eric Nantel
DiaLFonZo-Copter
Woohoo, that's stylish, Eric!
The antenna holder looks like a little crown.
I love the shape of it but I'm not quite sure if it comes handy if you need to press the reset button or if you can still see the LEDs. I was thinking of something more simple like a rather flat box with a transparent or milky cover.
I guess you'll do a 3D print, right? Then you could do a proto and test the mounting and accessebility - and show it off to us.
So far very very nice!
Norbert
kinderkram is offline Find More Posts by kinderkram
Old Jan 11, 2013, 10:46 AM
Dialfonzo is offline
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
It can't be printed on a standard extrusion type printer.
Too many curved and not supported parts.
For the lights i have an idea, Since the material is normaly white it will conduct light.
Will add channel of material to conduct to the top or side.
Square box could still be done.
Could have different lid option.
Still in working progress... haha
Do we have to press the reset often..?
Dialfonzo is offline Find More Posts by Dialfonzo
Old Jan 11, 2013, 12:43 PM
epyonxero is offline
Find More Posts by epyonxero
Joined Feb 2012
With that design will there be anywhere to mount a groundplane for the GPS?
epyonxero is offline Find More Posts by epyonxero
Old Jan 11, 2013, 12:48 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Still a work in progress.
The antenna on that prototype is mounted from the top.
Is it enough to put a ground plane under it or it need something bigger ?
Old Jan 12, 2013, 04:38 AM
DVE is offline
DVE
Find More Posts by DVE
DVE
Russian Federation, Sankt-Petersburg, SPB
Joined Jul 2011
Today I received Futaba invertor (it tooks 1 month to get it - post is slow in new year holidays) and tried to connect all.
Next fail - I cannot set connection of the board and PC.
I have USB-TTL adaptor from rctimer, use 3 wires: GND, RX and TX, settings used from wiki (115200, parity none, data bits8 - see screenshot-1). But when I press Connect, nothing happened, connection established but console is empty. Later I swapped RX-TX wires, and get lot of junk in console window (screenshot-2).
What I am doing wrong? I also have ftdi cable from 3DR modem, can I use it?
Thanks.
DVE is offline Find More Posts by DVE
Old Jan 12, 2013, 06:12 AM
skew is offline
Joined Jan 2005
The ftdi cable is what you need to use make sure its 3.3 volt if its 5v it may kill your AQ. Be sure and load the drivers for it and you should be good to go
Old Jan 12, 2013, 09:52 AM
OS Sponsor
kinderkram's Avatar
Joined Jun 2010
Look at this!
Tilman aka RoseWhite and a German company created the ultimate carrier board for the AutoQuad. I'm afraid it'll be damn expensive though.
Ain't she a beauty?
Old Jan 12, 2013, 11:09 AM
OS Sponsor
kinderkram's Avatar
Joined Jun 2010
Text-to-Speech for Windows GCS!
Peter aka sandmen has taken huge steps to bring TTS to the AQ Win version of the QGC.
http://forum.autoquad.org/viewtopic....start=20#p9756
To change the standard voice you need to select it from the Audio/Speech entry in the Win Control Panel!
Old Jan 12, 2013, 12:59 PM
DVE is offline
DVE
DVE
Joined Jul 2011
Of course, drivers are ok, I used this adapter with other devices (UBlox GPS, APC220 modem).
Did I need to upgrade firmware, if I see this error message, and lot of hex values in communication window?
Old Jan 12, 2013, 01:06 PM
OS Sponsor
kinderkram's Avatar
Joined Jun 2010
Which fw version do you use?
Please download r37 again and use the latest GCS 1.1.0:
http://autoquad.org/software-downloads/?category=3
http://autoquad.org/software-downloads/?category=2
btw: you'll certainly get more attention if you ask your Qs in our forum.
Old Jan 12, 2013, 01:17 PM
DVE is offline
DVE
DVE
Joined Jul 2011
I'm too lazy for registration on a lot of forums, sorry
How I can detect board revision? What version I need to download, r37v1 or r37v2?
I using version that was preloaded on board (it was sent to me in october). Are there some changes in mavlink version from this time?
Btw, its ok to see a lot of hex values in Communication Debug Console, or there must be text data?
Old Jan 12, 2013, 02:57 PM
OS Sponsor
kinderkram's Avatar
Joined Jun 2010
You don't need to be registered to search our Wiki and Forum.
Boards shipped in October should be v2 (did you order yours in Oct?)
You can check it yourself: Resistor R4 on the board should be 8,45k instead of 4.7k
The Communication Console in QGC displayes various values. You'll see a lot of hex values when connecting and then status messages once parameters were transmitted. Supervisor messages will be displayed there and now also spoken in all GCS versions.
Old Jan 12, 2013, 07:23 PM
skew is offline
Joined Jan 2005
My 3d printer is alive just started calibration prints. AQ case to come soon
Old Jan 13, 2013, 12:33 AM
richkphoto is offline
Find More Posts by richkphoto
United States, MN, St Cloud
Joined Jan 2012
What did that set you back?
richkphoto is offline Find More Posts by richkphoto
New Product Autoquad team proudly presents: Autoquad ESC32 JussiH Multirotor Electronics 301 Apr 16, 2016 09:05 PM
Discussion Naza dji sh gps - south hemisphere public beta testers results! Velociraptor73 Multirotor Talk 26 Nov 20, 2012 01:45 AM
Discussion How Bloomberg's Soft Drink Ban Will Backfire on NYC Public Health MtnGoat Life, The Universe, and Politics 1 Jun 26, 2012 11:19 PM
Discussion The AutoQuad! [ video ] kapteinkuk Multirotor Talk 5 Jun 10, 2012 11:19 AM
Download G-3 Public Beta (.426) is out. Includes Airplane Importer! L0stS0ul Simulators 37 Mar 03, 2006 05:28 PM
