Old Nov 18, 2012, 02:33 PM
DVE is offline
DVE
Find More Posts by DVE
DVE
Russian Federation, Sankt-Petersburg, SPB
Joined Jul 2011
Ok, thanks, I'll check results again.
Is it critical to freeze board to -18, if I'm not planning to fly at this temperatures? -10..+20 range for me may be enough, even -5...
DVE is offline Find More Posts by DVE
Old Nov 18, 2012, 02:39 PM
JussiH is offline
Find More Posts by JussiH
Friend is a 4 letter word...
JussiH's Avatar
3rd stone from the sun
Joined May 2007
Is it critical to freeze board to -18, if I'm not planning to fly at this temperatures? -10..+20 range for me may be enough.
If your card is very thin (<0,7mm) it can have problems making contact properly when inserted. If you put a piece of tape on the logo-side to make it 0.75-0.8mm thick, it will sit better in the slot and make better contact.
Sadly there is a lot of difference between the thickness of cards from different manufactorers. I have seen from 0.65 to 0.82 mm thickness.
There is also a small feathering spring on the slot itself that can be bent down to make the card make better contact:
http://autoquad.org/wiki/wiki/autoqu...c-calibration/
(scroll down, first note)
SD card specification states operating temp from -25C to 80C
JussiH is offline Find More Posts by JussiH
Old Nov 18, 2012, 02:46 PM
DVE is offline
DVE
DVE
Joined Jul 2011
Thanks, I've read it, but my board is from the last batch, not "early beta", so I ignored this note.
Btw it will be nice, if it will be possible to import logs directly via flight controller, without replacing card in the card reader.
Old Nov 18, 2012, 02:55 PM
JussiH is offline
JussiH's Avatar
Joined May 2007
We still use the same SD card slot, and its not a problem with the reader but with card manufactorer tolerances. It still applies.
Dont hold your breath waiting for us to make a feature to read cards directly from the FC, its just not practical to do over a serial connection...and we are busy improving the featureset and documentation....
Old Nov 19, 2012, 09:49 AM
noppita is offline
Find More Posts by noppita
noppita's Avatar
Joined Jul 2009
i just received my AQ completed set and going to install with my Octo frame.
new to this FC.
noppita is offline Find More Posts by noppita
Jessestr is offline
Find More Posts by Jessestr
BelgiŽ, Vlaams Gewest, Evergem
Joined Nov 2011
Good luck have fun calibrating!
Jessestr is offline Find More Posts by Jessestr
Old Nov 19, 2012, 09:51 AM
noppita is offline
noppita's Avatar
Joined Jul 2009
i have the gps antenna and gps shield, but still confuse how to attach the gps antenna to the gps shield.
do i tape it down or glue the antenna to the gps shield?
the instruction tell me to solder a wire from antenna to the gps shield? but there is only one wire to connect from antenna to the AQ FC. or i have to use extra small wire to solder one end from gps antenna aluminum cage to the gps shield on the other wire end?
thank you
Old Nov 19, 2012, 09:52 AM
noppita is offline
noppita's Avatar
Joined Jul 2009
what do you mean? this board has problem with calibrating?
what kind of problem? can you take time to explain.
Old Nov 19, 2012, 11:58 AM
skew is offline
Find More Posts by skew
United States, KY, Morehead
Joined Jan 2005
The AQ6 does not have a problem calibrating its just a lengthy process
http://autoquad.org/wiki/wiki/autoquad-calibrations/
If everything goes good be prepared to spend at least
6 Hours on static (freezing and thawing not much work involved just time)
5min to hours?? on “Calibso” Dance (you have to practice a few times to get the hang of it)
10-20 hours number crunching on computer calculations (really depends on speed of your computer)
Then your board is ready to upload the new parameters and hopefully there is not much more tweaking.
skew is offline Find More Posts by skew
Old Nov 19, 2012, 12:24 PM
Jessestr is offline
Joined Nov 2011
Thanks skew for catching up. Didn't want to scare you noppita. I think the calibration is "fun" it's just nice to see the data And you don't have to do anything ...
Build your frame when it's calibrating
Or learn the calibso dance.
Old Nov 19, 2012, 05:55 PM
gionag is offline
Find More Posts by gionag
Italy, Marche, Mondolfo
Joined Mar 2012
the main weakness of autoquad and also its main point of strength is the calibration itself...
if you get it right... then your platform is stable as nothing else
but before the happiness you have to spill some tears...
gionag is offline Find More Posts by gionag
Old Nov 19, 2012, 06:31 PM
saabguyspg is offline
Find More Posts by saabguyspg
saabguyspg's Avatar
Calgary Canada
Joined Jun 2006
stable like nothing else....
what would be your experiance to compare this to? Mikrokopter?
I would imagine it's possible to be as good as MK if running I2C es'cs... but just flashed pwm?.. no chance.
Steve
saabguyspg is offline Find More Posts by saabguyspg
Old Nov 19, 2012, 06:36 PM
gionag is offline
Joined Mar 2012
have you tested AQ ?
the esc is the top of the iceberg... there are many other things to put into account.
and in my experience, i don't go think i2c makes this huge difference... only a very critical point of failure.
now i'm flying with ESC32 and the Aq with r37 dev firmware... i don't think to put back the MK fc for now...
but this is only my two cents.
Old Nov 19, 2012, 07:27 PM
noppita is offline
noppita's Avatar
Joined Jul 2009
Steve
From my experienced, normal esc with simonk firmware is as good as i2c esc on both arducopter and MK.
Old Nov 20, 2012, 02:40 AM
kinderkram is offline
Find More Posts by kinderkram
OS Sponsor
kinderkram's Avatar
Germany, NRW, Dusseldorf
Joined Jun 2010
Yah, most users don't like the calibration process.
The positive outcome: you will learn a lot about your FC and the sensors - you'll know it inside out then.
There are plans to offer pre-calibrated boards and RTF/ARF setups. So the user only has to do some minor tuning to match his airframe.
kinderkram is offline Find More Posts by kinderkram
New Product Autoquad team proudly presents: Autoquad ESC32 JussiH Multirotor Electronics 301 Apr 16, 2016 09:05 PM
Discussion Naza dji sh gps - south hemisphere public beta testers results! Velociraptor73 Multirotor Talk 26 Nov 20, 2012 01:45 AM
Discussion How Bloomberg's Soft Drink Ban Will Backfire on NYC Public Health MtnGoat Life, The Universe, and Politics 1 Jun 26, 2012 11:19 PM
Discussion The AutoQuad! [ video ] kapteinkuk Multirotor Talk 5 Jun 10, 2012 11:19 AM
Download G-3 Public Beta (.426) is out. Includes Airplane Importer! L0stS0ul Simulators 37 Mar 03, 2006 05:28 PM
