Old Nov 11, 2012, 07:01 PM
skew is offline
Find More Posts by skew
United States, KY, Morehead
Joined Jan 2005
Originally Posted by DVE View Post
I'm reading the manual and don't understand this phrase:
One S-bus receiver (or compatible) can be directly attached to the AutoQuad. As with most flightcontroller, you need to invert the signal from the S-bus.
I have Futaba 10ch with genuine R6108SB receiver. Can I directly attach it to Autoquad, or I need convertor to use it? And did I need to use 5V external pin to power it, or 3.3V is enough?
This is the adaptor I used. I am using 5v from one of the motor connectors just to be on the safe side. My 6203sb powered and seemed to work fine with just the adaptor but I didn't feel safe with the 3.3v.
http://helidirect.com/skookum-sk720-...er-p-21799.hdx
I got to put over a hour of flight time on mine today even did a few missions If I can figure out the mission landing I will make a video and post. I am very happy with my AQ6 its flying stock settings and the wind was 10-15mph gust and she flew around like it was dead calm.
skew is offline Find More Posts by skew
Old Nov 11, 2012, 08:41 PM
kd4wen is offline
Find More Posts by kd4wen
Just a yard bird
kd4wen's Avatar
United States, TN, Springfield
Joined Mar 2007
Originally Posted by JussiH View Post
VN100 is not a plug and play solution - it still requires on-frame calibration and generation of a custom file for your specific board.
As far as I know there is no code support for VN200, only for VN100. (VN200 is 3200 dollars for a thermal calibrated unit, so I doubt many will find it interesting, anyway)
It will still use the onboard GPS unit. And you will have to make a daughter board for the VN100 or remove the onboard analog IMU and its support components.
If you do the calibration properly, you wont get a better result with a VN100 - at least that is what I am told...but you may want to post the question on the forum, where Steve or Bill will see it - they are the only persons I know that have used the VN100.
Thank you Jussi
If you are looking for a precalibrated unit, I can build a complete ARTF (no radio) hexacopter for you for less than 3200 dollars....
I need to get with you I am working all the time on the road but really wanting to build something out side the box and yes I know the price on these units yet they are commercial grade. Send my a PM and lets talk about a setup calibrated deal money at this point is not the show stopper.
Freddie G
kd4wen is offline Find More Posts by kd4wen
Old Nov 12, 2012, 01:06 AM
Frank.T is offline
Find More Posts by Frank.T
Frank.T's Avatar
Netherlands, ZH, Rotterdam
Joined Jul 2010
Hmm, compass and board near power lines? And its working normal?
Originally Posted by Frank.T View Post
http://www.rcgroups.com/forums/showp...&postcount=358
yes , Spot on, no problems at all.
AutoQuad 6 Descending Loiter (2 min 10 sec)
AutoQuad 6 1Km waypont (0 min 39 sec)
Frank.T is offline Find More Posts by Frank.T
Old Nov 12, 2012, 01:28 AM
DVE is offline
DVE
Find More Posts by DVE
DVE
Russian Federation, Sankt-Petersburg, SPB
Joined Jul 2011
So, this adaptor needed with all Futaba receivers?
Its interesting, why link on it is not displayed on the product page... I didn't knew that I need it when making the order, and now need to wait another 2 weeks
DVE is offline Find More Posts by DVE
Old Nov 12, 2012, 01:37 AM
Mr_westie is offline
Find More Posts by Mr_westie
Down under under
New Zealand, Auckland
Joined Nov 2007
No, you dont have to attach the GPS - if calibrated properly the craft will fly good without GPS attached.
You will still have to do the Calibso, since that is a integral part of the whole calibration and vital for getting the scale and bias corrected for your particular board.
All sensors are fused in the UKF, so you cant "turn off" individual components of the IMU.
As of firmware v6.6 r37 , Alt hold will not work reliably without gps lock.
DVE, hang in there
It will be worth it.
Got to another milestone today
Auto take off
Now to test waypoint navigation.
Mr_westie is offline Find More Posts by Mr_westie
Old Nov 12, 2012, 04:14 AM
Jessestr is offline
Find More Posts by Jessestr
BelgiŽ, Vlaams Gewest, Evergem
Joined Nov 2011
Just received my AQ and new frame.. Since there is a lack of photo's of the AQ.. I'll post some
Jessestr is offline Find More Posts by Jessestr
Old Nov 12, 2012, 04:29 AM
Jessestr is offline
Joined Nov 2011
By the way.. I didn't receive any power cable for the AutoQuad in my package? Is this normal?
Old Nov 12, 2012, 04:32 AM
JussiH is offline
Find More Posts by JussiH
Friend is a 4 letter word...
JussiH's Avatar
3rd stone from the sun
Joined May 2007
No, you should have gotten a power cable. Please contact your reseller.
JussiH is offline Find More Posts by JussiH
Old Nov 12, 2012, 04:34 AM
Jessestr is offline
Joined Nov 2011
I see. Just mailed Paul about this. This sucks wanted to do calibrations today
Old Nov 12, 2012, 04:45 AM
skew is offline
Joined Jan 2005
The signal invert cable is required for all sbus receivers. I found a post on the AQ forum where someone tried it. I thought I would take a chance because its alot easier to purchase the skookum in the U.S. plus it also has the spectrum end that I would have had to purchase somewhere else.
Old Nov 12, 2012, 05:25 AM
Jessestr is offline
Joined Nov 2011
Do I need to use the power connector delivered with the AQ or can I just solder a normal JST connector?
Can't wait...
Old Nov 12, 2012, 05:38 AM
gionag is offline
Find More Posts by gionag
Italy, Marche, Mondolfo
Joined Mar 2012
AFAIK you can use everything you want. be sure to respect polarities...
for example... i don't use the supplied connector
gionag is offline Find More Posts by gionag
Old Nov 12, 2012, 05:42 AM
Jessestr is offline
Joined Nov 2011
Thanks. Have any picture?
Old Nov 12, 2012, 05:44 AM
gionag is offline
Joined Mar 2012
i'm sorry... no
Old Nov 12, 2012, 07:34 AM
DVE is offline
DVE
DVE
Joined Jul 2011
Thank you.
It must be displayed on the product page in the shop with red letters, anyway
Btw, Naza or Wookong don't require any hardware converters.
New Product Autoquad team proudly presents: Autoquad ESC32 JussiH Multirotor Electronics 301 Apr 16, 2016 09:05 PM
Discussion Naza dji sh gps - south hemisphere public beta testers results! Velociraptor73 Multirotor Talk 26 Nov 20, 2012 01:45 AM
Discussion How Bloomberg's Soft Drink Ban Will Backfire on NYC Public Health MtnGoat Life, The Universe, and Politics 1 Jun 26, 2012 11:19 PM
Discussion The AutoQuad! [ video ] kapteinkuk Multirotor Talk 5 Jun 10, 2012 11:19 AM
Download G-3 Public Beta (.426) is out. Includes Airplane Importer! L0stS0ul Simulators 37 Mar 03, 2006 05:28 PM
