yup I just wanted to make sure you did not get dooped by maytech's advertising BS
![]() Quote:
http://forum.autoquad.org/viewtopic.php?f=33&t=459 Cheapest version comes at ~18$: http://www.goodluckbuy.com/index.php...d=0&q=minimosd
United States, MN, St Cloud
Joined Jan 2012
Make sure to post your setup and especially some flight vids. ![]() @ richkphoto: the cheap ones use a linear voltage regulator, which tend to heat up. To be on the safe side you can use the other clones or go for the original: http://store.jdrones.com/jD_MiniOSD_p/jdminiosd10.htm |
Thanks for the answer. It's just that i custom designed a frame for "Jessestr" to be Y6 and HEXA and at the last minute he told me he want a Quad X ... Just asking cause i have see very nice setup on MultiWii for AP in that shape. Eric Nantel (DiaLFonZo) |
I don't see why not... with some tuning...
The motor mix table will be useful for getting the pitch/roll axis movement speed matched up, and then probably a generous dose of PID tuning will be necessary because like Norbert said it will be sensitive. But the 32-bit AQ goodness should be able to handle it. ![]() -Max |
België, Vlaams Gewest, Evergem
Joined Nov 2011
I saw in the documentation that you supported HoTT telemetry so probably I can also use the HoTT radio to fly.
But when searching on these forums I see lots of people having trouble with HoTT and PPM. Is it already fixed? How can I attach my MX12 & GR12 to the AutoQuad. Saw some people that needed to power the receiver with a BEC because of dropouts it the signal.. Anyone got more info on this? At last.. if it doesn't work.. is there a way to let it work? Convert to Spektrum Sattelite (never used spektrum.. don't know anything about it) Thanks Jesse |
We do support PPM sum recievers, but it might require changes in the code, since almost every manufactorer implements PPM in a different way. We are working on a way to make those adjustments from the GUI, but there is no such thing as a "universal" PPM implementation that will magically make every PPM sum RX work.
We have a team member that flies a Hott radio on PPM, so I am sure you can get some help. Several people have also successfully used the popular FrSky systems. Quote:
Latest blog entry: AutoQuad hexacopter with Alexmos...
| Thread Tools | |
| New Product Autoquad team proudly presents: Autoquad ESC32 Public Beta | JussiH | Multirotor Electronics | 260 | Jun 05, 2013 01:53 AM |
| Discussion Naza dji sh gps - south hemisphere public beta testers results! | Velociraptor73 | Multirotor Talk | 26 | Nov 20, 2012 01:45 AM |
| Discussion How Bloomberg's Soft Drink Ban Will Backfire on NYC Public Health | MtnGoat | Life, The Universe, and Politics | 1 | Jun 26, 2012 11:19 PM |
| Discussion The AutoQuad! [ video ] | kapteinkuk | Multirotor Talk | 5 | Jun 10, 2012 11:19 AM |
| Download G-3 Public Beta (.426) is out. Includes Airplane Importer! | L0stS0ul | Simulators | 37 | Mar 03, 2006 05:28 PM |
