Old Oct 22, 2012, 07:52 PM
blade strike is offline
Find More Posts by blade strike
DJI Testing / US Support
blade strike's Avatar
United States, CA, Big Bear
Joined Jan 2006
Wow that didnt take to long Hoping to get started in the next few days.. If work allows!
blade strike is offline Find More Posts by blade strike
Site Sponsor
Latest blog entry: Dji m600
Old Oct 22, 2012, 10:26 PM
Mr_westie is online now
Find More Posts by Mr_westie
Down under under
New Zealand, Auckland
Joined Nov 2007
Does a RX have to be connected for it to stat logging?
The board came with firmware loaded that allowed me to do static calibration.
After re loading firmware it now does nothing.
Only a solid red light after power up.
I did remove J4 after flashing.
I will get the PWM>PPM converter going while I wait.
edit:
Back in business.
The uSD card that worked before now does not after the firmware update.
It boots with no card installed.
The card works fine the PC
Fortunately I had a few cards around so got another that the AQ was happy with.
Mr_westie is online now Find More Posts by Mr_westie
Old Oct 23, 2012, 02:48 AM
kinderkram is offline
Find More Posts by kinderkram
OS Sponsor
kinderkram's Avatar
Germany, NRW, Dusseldorf
Joined Jun 2010
Good to see some progress. Now that the FCs are shipped I'm expecting to see more testers getting airborne.
Wiki overhaul will be finished soon. There's new firmware and the next version of the ground stations to be released.
That should get you guys going.
kinderkram is offline Find More Posts by kinderkram
Old Oct 23, 2012, 05:19 AM
gionag is offline
Find More Posts by gionag
Italy, Marche, Mondolfo
Joined Mar 2012
also the serial radio modem is arrived...
buyed @ eforchina and arrived in perfect working state. suggested
look on the wiki for more information
gionag is offline Find More Posts by gionag
Old Oct 23, 2012, 09:37 PM
r0sewhite is offline
Find More Posts by r0sewhite
It wasn't me
r0sewhite's Avatar
Augsburg, Germany
Joined Mar 2010
I'm just curious: When putting the AQ into a box, how much higher will the temperature be inside, compared to the outside temperature?
The reason I'm asking is that the only (hopefully) vibration-free room is the basement and that's anything but a warm room. Would a lipo heating box set to room temperature be a good idea?
r0sewhite is offline Find More Posts by r0sewhite
Old Oct 23, 2012, 10:50 PM
maximal is offline
Find More Posts by maximal
AutoQuad OS developer
maximal's Avatar
near Ithaca, NY, US
Joined Aug 2004
Basements are often a perfect place for the static logging. How cold is yours? I would probably first try it with just an insulated container (open cell foam works great). You actually don't want the temperature to rise too quickly. The components on the AQ (especially the MCU) should heat up a small insulated container quite well. Leave it logging for at least 90 minutes the first time and then graph the temperatures from the log. If you see it is not getting warm enough, then you could try the battery heater or something like that. My concern with a heater would be a) electrical currents introducing magnetic disturbances (especially as it turns on/off), and b) heating up the board too quickly. You pretty much want it to heat up during the course of an hour or so, but longer is OK too. Quicker is not ideal.
-Max
maximal is offline Find More Posts by maximal
Old Oct 23, 2012, 11:19 PM
It wasn't me
r0sewhite's Avatar
Augsburg, Germany
Joined Mar 2010
Hi Max,
it wasn't my intention to speed up the warm-up phase with the box. The basement is probably not more than 10-12 C at the moment and I doubt that the temperature will rise within the next weeks or months. I just don't see an option because you can feel the whole house shaking when a truck passes by and crosses the tram rails. Our rooms are anything but ideal for the logging.
If I don't reach an appropriate temperature in the basement, I will try it inside the pre-heated lipo box at 20-25C. The insulation of the box should be good enough to hold the temperature for a while after disconnecting it from power source.
Tilman
Old Oct 24, 2012, 05:14 AM
JussiH is offline
Find More Posts by JussiH
Friend is a 4 letter word...
JussiH's Avatar
3rd stone from the sun
Joined May 2007
I have done calibration in my garden-shed at 5-8C. So 10-12C wont be a problem. The key is to insulate the box properly and make sure its more or less airtight. If you dont reach the intended temperature, a Ziplock bag (preferably a anti-ESD bag with metal lining) will help you keep the heat around the board.
It can be a good idea to place the box on a soft pillow or matress if you are worried about vibrations.
Jussi
Originally Posted by r0sewhite View Post
Hi Max,
Tilman
JussiH is offline Find More Posts by JussiH
Old Oct 24, 2012, 11:41 AM
skew is offline
Find More Posts by skew
United States, KY, Morehead
Joined Jan 2005
Rant! USPS!!!! Still no AQ6 board Its been sitting in sitting in Chicago since wed of last week no movement. The funny thing is I had a package from HK go through the exact same processing center on the same day 4hrs after my AQ6 package and I received it last Saturday. I am starting to think its lost or damaged at this point.
skew is offline Find More Posts by skew
Old Oct 24, 2012, 12:04 PM
OS Sponsor
kinderkram's Avatar
Joined Jun 2010
Can't you try to call the center and ask what's going on?
Does it have to clear customs?
Old Oct 24, 2012, 06:48 PM
richkphoto is offline
Find More Posts by richkphoto
United States, MN, St Cloud
Joined Jan 2012
Another way to warm things up if yu have to is the hand warming packets that you rub together to activate the chemicals and they'll stay warm for a couple of hours. I know we can get them at Walmart in the Staes and they don't cost very much
richkphoto is offline Find More Posts by richkphoto
Old Oct 24, 2012, 07:09 PM
Joined Jan 2006
I have a question.. Should I flash r33 f/w before doing calibration or do I use the shipped test f/w?
Site Sponsor
Old Oct 24, 2012, 08:23 PM
maximal is offline
maximal's Avatar
near Ithaca, NY, US
Joined Aug 2004
Yes, flash firmware first. http://test.autoquad.org/wiki/wiki/getting-started/ and http://autoquad.org/wiki/wiki/gettin...ware-flashing/ . Be sure to grab the right fw file for your board revision # (Oct. '12 and later use rev. 2).
Good luck with the cals! I'm about to freeze my 2nd AQ board...
-Max
Old Oct 24, 2012, 08:36 PM
jcmonty is offline
Find More Posts by jcmonty
United States, CA, San Diego
Joined Apr 2012
Mah.. mine is at the post office. Gotta go friday to pick it up. I find it silly that the PO opens at 830 and closes at 5. How the heck am I supposed to get there during working hours.. sigh
Still deciding on what to do with this board.. build a new frame, put it on my existing frame.. hmm
jcmonty is offline Find More Posts by jcmonty
Old Oct 24, 2012, 08:44 PM
Joined Jan 2006
-Max
I was reading all about the calibrations and must have over looked this..
Thank you
Site Sponsor
New Product Autoquad team proudly presents: Autoquad ESC32 JussiH Multirotor Electronics 301 Apr 16, 2016 09:05 PM
Discussion Naza dji sh gps - south hemisphere public beta testers results! Velociraptor73 Multirotor Talk 26 Nov 20, 2012 01:45 AM
Discussion How Bloomberg's Soft Drink Ban Will Backfire on NYC Public Health MtnGoat Life, The Universe, and Politics 1 Jun 26, 2012 11:19 PM
Discussion The AutoQuad! [ video ] kapteinkuk Multirotor Talk 5 Jun 10, 2012 11:19 AM
Download G-3 Public Beta (.426) is out. Includes Airplane Importer! L0stS0ul Simulators 37 Mar 03, 2006 05:28 PM
