Old Oct 16, 2012, 02:10 AM
bob4432 is online now
Find More Posts by bob4432
bob4432's Avatar
United States, AZ, Phoenix
Joined May 2010
Using different escs is possible, one of the team members/testers I am sure could let you know how much of a performance difference you could expect vs the esc32.
Out of curiosity what motors are you using? Or would this be for something other than a multirotor?
Originally Posted by saabguyspg View Post
wow... I was considering AQ... I guess I will wait and see how this all pans out.
the biggest reason I am not buying today is that the esc are not rated for 6S.... will that be available in the future?
thanks!
Steve
bob4432 is online now Find More Posts by bob4432
Old Oct 16, 2012, 02:57 AM
Mr_westie is offline
Find More Posts by Mr_westie
Down under under
New Zealand, Auckland
Joined Nov 2007
imo, It is all to do with documentation
It does not matter how complicated something is, if it is well documented it is easy.
As well documented as the Arducoptor/Multiwii is , it is still time consuming to do PID Tuning.
After using the YS, the standard is now quite high for me to be happy, performance wise.
I know a $100 bag of parts won't be the same, I will have to be happy with a 10m Position Hold circle until my YS is back from major surgery.
When I buy cheap china products it is always fun to read some of the translations.
Didn't think I would see it with a high end product. I though $1k+ was high end.
Of course it depends how accessible you want AQ to be.
I guess the Calibration procedure may put some people off no matter how well documented it is
I had better start reading as my AQ is on it way
Mr_westie is offline Find More Posts by Mr_westie
Old Oct 16, 2012, 03:36 AM
maximal is offline
Find More Posts by maximal
AutoQuad OS developer
maximal's Avatar
near Ithaca, NY, US
Joined Aug 2004
Ignore Joe, he's the only one with these kind of issues, and I think they're mostly personal.
You can use any 400Hz ESC with AQ. So flash your own with Simon K's firmware, or buy some pre-flashed. I'm flying with 30A HK Blue series.
@Andre, please inform yourself by reading before posting (PPM support is built in). And the AQ is definitely NOT for newbies. Certainly not at this stage. Again, this has been stated clearly in the original post.
-Max
maximal is offline Find More Posts by maximal
Old Oct 16, 2012, 09:45 AM
redridinghood is offline
Find More Posts by redridinghood
Joined Dec 2010
I find the AQ to be a nice complete product with good documentation behind it. It takes a few hours to get it calibrated and flying but once you do you are rewarded with a smooth flying machine. I am sure that when all the bugs are ironed out this will be the FC to compare others too.
You just need to read the wiki and decide if the effort required is too much for you.
redridinghood is offline Find More Posts by redridinghood
Old Oct 16, 2012, 10:49 AM
kinderkram is offline
Find More Posts by kinderkram
OS Sponsor
kinderkram's Avatar
Germany, NRW, Dusseldorf
Joined Jun 2010
The Docu & Wiki is constantly being worked on.
Our beta users helped us a lot finding gaps and missing info, uncover bugs and tinker with workarounds or finding solutions.
Almost all parts of the setup process are covered now. We'll add more illustrations, screenshots and videos on the run to make it easier for the end user.
kinderkram is offline Find More Posts by kinderkram
Old Oct 16, 2012, 10:55 AM
saabguyspg is offline
Find More Posts by saabguyspg
saabguyspg's Avatar
Calgary Canada
Joined Jun 2006
ok cool, sorry I guess I just assumed I had to use the AQ esc (my bad need more reading)
Ok I am gonna read more, and lurk here for a while to learn learn learn...
I don't mind putting time in as I am from the days of soldering MK boards and dealing with their arrogance
Thanks again.
Steve
-Max
saabguyspg is offline Find More Posts by saabguyspg
Site Sponsor
Old Oct 16, 2012, 11:21 AM
GoFaster is online now
Find More Posts by GoFaster
Live for speed
GoFaster's Avatar
USA, CT, Bethany
Joined Mar 2004
Steve, your ESC's will work great. They are still doing fine here (on a different quad).
The ESC32's are only required for some future functionality.
- Felix
Thanks again.
Steve
GoFaster is online now Find More Posts by GoFaster
Old Oct 16, 2012, 12:32 PM
blade strike is online now
Find More Posts by blade strike
DJI Testing / US Support
blade strike's Avatar
United States, CA, Big Bear
Joined Jan 2006
Just to be clear, I should not have an issue running 4s, or should I just use a bec to supply power?
blade strike is online now Find More Posts by blade strike
Site Sponsor
Latest blog entry: Mavic Tutorials
Old Oct 16, 2012, 12:42 PM
Andre6553 is offline
Find More Posts by Andre6553
Vulcan skyhook multirotor
Andre6553's Avatar
South Africa, GP, Pretoria
Joined Feb 2011
-Max
Then im very sorry about it my bad im was sure i was asking the question before and got an answer that it only support spectrum and fatuba sbus
Will do some more reading then
Edit:
This is taken from page1
Originally Posted by 1ste post
At the moment we only support Spektrum satellite and Futaba S-bus receivers. PPM is being worked on, but we cant promise that it will be done soon…we are however pretty sure it will happen soon, or that someone in the community will add it if we are too slow. The code is open source under GNU/GPL, so feel free to tinker and build on it yourself, or use it as inspiration for your own project.
Can someone explain how i will be able to have my hitec Aurora9 radio to work with autoquad
Andre6553 is offline Find More Posts by Andre6553
Old Oct 16, 2012, 01:30 PM
OS Sponsor
kinderkram's Avatar
Joined Jun 2010
Clear, no issues.
Using 5s requires a UBEC since the 18,5V are slightly over the Recomms' specs.
Old Oct 16, 2012, 01:38 PM
OS Sponsor
kinderkram's Avatar
Joined Jun 2010
@ Andre: Jussi doesn't update regularly.
Watch our Site/Wiki or search the forums. PPM is covered on most receivers.
And a PWM/PPM converter can be used to bridge both worlds. You're Aurora can do this.
My Aurora is equipped with a Spektrum module using the PPM out from the trainer port.
I can use any DSM2 satellite with it.
But I've also tested a cheap PPM converter and it works.
Old Oct 16, 2012, 02:10 PM
Andre6553's Avatar
Joined Feb 2011
Can you post more info on this setup with pictures and info where one can buy it from.
Or is all this on the autoquad forum.
Old Oct 16, 2012, 03:19 PM
Andre6553's Avatar
Joined Feb 2011
This might be an option for hitec and jr radios
http://www.rcgroups.com/forums/showthread.php?t=1725622
Old Oct 16, 2012, 07:03 PM
jcmonty is offline
Find More Posts by jcmonty
United States, CA, San Diego
Joined Apr 2012
Good find! That guy may be an option is the pwm-ppm converter doesn't work well.
Question for those using spektrum: Am i correct if reading that you do not need a "full" receiver, just the satellite?
jcmonty is offline Find More Posts by jcmonty
Old Oct 16, 2012, 08:31 PM
JussiH is offline
Find More Posts by JussiH
Friend is a 4 letter word...
JussiH's Avatar
3rd stone from the sun
Joined May 2007
Just the sat is needed.
I have just updated page 1:
Currently we support Spektrum satellite and CPPM stream receivers. Note that CCPM at the moment can require some minor adaptation in the source code depending on your exact receiver - it is reported to work well with FrSky and paparazzi-style PPM encoders. We are working on implementing all the CPPM parameters in the gui, but at the moment you can only change the channel assignments.
We also support S-bus, but we dont have enough data from users with genuine Sbus receivers to state if its working well and is free from glitches. We have had issues reported with Futaba SBE-1 converter and FrSky Sbus recievers. Until we have more data on Sbus, we recommend that żou use the CPPM option instead.
JussiH is offline Find More Posts by JussiH
New Product Autoquad team proudly presents: Autoquad ESC32 JussiH Multirotor Electronics 301 Apr 16, 2016 09:05 PM
Discussion Naza dji sh gps - south hemisphere public beta testers results! Velociraptor73 Multirotor Talk 26 Nov 20, 2012 01:45 AM
Discussion How Bloomberg's Soft Drink Ban Will Backfire on NYC Public Health MtnGoat Life, The Universe, and Politics 1 Jun 26, 2012 11:19 PM
Discussion The AutoQuad! [ video ] kapteinkuk Multirotor Talk 5 Jun 10, 2012 11:19 AM
Download G-3 Public Beta (.426) is out. Includes Airplane Importer! L0stS0ul Simulators 37 Mar 03, 2006 05:28 PM
