Old Aug 29, 2012, 02:58 AM
roxyboby is offline
Find More Posts by roxyboby
Joined Jul 2007
Originally Posted by maximal View Post
Thanks Menno. Makes sense. Having used a MPX Evo for years, I forget that "typical" radios have the control-to-channel mappings pre-set.
And yea, to make my previous answer to roxyboby more specific... you need at least a 7 channel radio with 3-way switches on channels 6 & 7.
-Max
Thanks Max, The Futaba has only one 3-way-Switch on channel 5. Don't know if this can be changed to channel 6 or 7.
roxyboby is offline Find More Posts by roxyboby
Old Aug 29, 2012, 02:59 AM
roxyboby is offline
Joined Jul 2007
Will a Turnigy 9 channel Transmitter work?
Old Aug 29, 2012, 03:50 AM
joebarteam is online now
Find More Posts by joebarteam
J'ai remis la purée
Netherlands, ZH, Zoetermeer
Joined Mar 2011
For the moment you have to compile the source yourself to do that.
You can re-assign the channel numbers in the radio.c & radio.h file, or you can change the channels you use in the nav.c code.
Besides that you lose a tiny feature: set home pos.
With only 1 3 pos switch you need that one for manual-positionhold and mission.
The second would be needed for : return to home-manual-set home pos.
With the second being a 2 pos switch you can use that for return to home and the mandatory manual.
Maybe the third switch for set home, but as that is already done at the first position hold it is not that needed for you.
Menno
joebarteam is online now Find More Posts by joebarteam
Old Aug 29, 2012, 03:51 AM
J'ai remis la purée
Joined Mar 2011
Hmm, probably with ppm out and the test code for ppm support or with a pwm->ppm adapter.
But, you're the first to ask and thus the first to test
Menno
Old Aug 29, 2012, 04:52 AM
roxyboby is offline
Joined Jul 2007
Can someone, Anyone please tell me the difference between the PWM, PPM, SBus and all that hype. Is the Futaba T7C a PWM or a PPM Transmitter?? I know for sure it's not a S-Bus. If I know this difference, and I am sure there are hundreds if not thousansd like me wanting to know this before we get the Autoquad board, it would make things easier.
Old Aug 29, 2012, 05:15 AM
GoFaster is offline
Find More Posts by GoFaster
Live for speed
GoFaster's Avatar
USA, CT, Bethany
Joined Mar 2004
Hi -
It is actually more receiver than transmitter dependent. This might help give you a better idea of the differences.
http://wiki.openpilot.org/pages/view...ageId=19300506
There are also converters available.
Currently AQ expects Spektrum, S.BUS or PPM from the receiver.
GoFaster is offline Find More Posts by GoFaster
Old Aug 29, 2012, 05:26 AM
Frank.T is offline
Find More Posts by Frank.T
Frank.T's Avatar
Netherlands, ZH, Rotterdam
Joined Jul 2010
2 meter Orbit
Ok we go ahead with flying and testing.
6.6R19: Auto take-off and landing is not working
I noticed that if during the mission your throttle is not in the middle it will not go.
Waypoint flying is no problem
Orbit works fine:
Auto Quad 6 Orbit (0 min 58 sec)
//Frank
Frank.T is offline Find More Posts by Frank.T
Old Aug 29, 2012, 06:51 AM
roxyboby is offline
Joined Jul 2007
Originally Posted by GoFaster View Post
Hi -
Thanks @GoFaster, I think I understand it better now from your last sentence.
Old Aug 29, 2012, 09:06 AM
epyonxero is offline
Find More Posts by epyonxero
Joined Feb 2012
Default PIDs except for altitude hold.. Pretty good baseline in my opinion but I think there is still more tuning available to tighten it up in gusty conditions.
http://www.youtube.com/watch?v=LbCcUYPbCJ0
Very nice. I just ordered an AQ this week and am looking forward to playing with it, Im going to put it on a Y6.
Was your camera hardmounted or were you using a gimbal there?
epyonxero is offline Find More Posts by epyonxero
Old Aug 29, 2012, 10:19 AM
GoFaster is offline
Live for speed
GoFaster's Avatar
USA, CT, Bethany
Joined Mar 2004
Yes, I am very impressed by it.
In that video, the cam is on a gimbal. You can get an idea of the gimbal corrections by looking at the apparent movement of the motors in the upper corners.
Also, the shadow of the copter is visible on the tree in the lower center of the picture.
- Felix
Old Aug 29, 2012, 10:36 AM
Joined Feb 2012
- Felix
I assume the AQ was also controlling the gimbal?
Old Aug 29, 2012, 10:47 AM
kinderkram is offline
Find More Posts by kinderkram
OS Sponsor
kinderkram's Avatar
Germany, NRW, Dusseldorf
Joined Jun 2010
Yes, no extra electronix needed.
If you look at Felix' other vids you can watch his efforts on the gimbal:
http://www.youtube.com/user/gdekatt?feature=watch
On this one he added an onboard vid for comparison:
Gimbal + fixed mount views. Another flight. (9 min 14 sec)
These are the results with a rather cheap gimbal and cheap analog servos.
The speed of the corrections can either be improved by driving the servos with 6V or by using faster digital servos.
kinderkram is offline Find More Posts by kinderkram
Old Aug 29, 2012, 11:22 AM
GoFaster is offline
Live for speed
GoFaster's Avatar
USA, CT, Bethany
Joined Mar 2004
Right, I currently have slow $10 analog servos on the gimbal. They cause a bit of a lag in gimbal correction. I am going to try digital servos that are almost 2x faster with higher refresh rate too. That along with revising my jello mounting system should hopefully result in optimal video.
Old Sep 01, 2012, 01:08 AM
roxyboby is offline
Joined Jul 2007
wud really like to see the AQ fly with some the COG offset. Maybe hang some weights on one of the arms and fly.
Old Sep 01, 2012, 04:00 AM
OS Sponsor
kinderkram's Avatar
Joined Jun 2010
What about a Hexa with only 5 motors?
GOPR2468 (0 min 54 sec)
New Product Autoquad team proudly presents: Autoquad ESC32 JussiH Multirotor Electronics 301 Apr 16, 2016 09:05 PM
Discussion Naza dji sh gps - south hemisphere public beta testers results! Velociraptor73 Multirotor Talk 26 Nov 20, 2012 01:45 AM
Discussion How Bloomberg's Soft Drink Ban Will Backfire on NYC Public Health MtnGoat Life, The Universe, and Politics 1 Jun 26, 2012 11:19 PM
Discussion The AutoQuad! [ video ] kapteinkuk Multirotor Talk 5 Jun 10, 2012 11:19 AM
Download G-3 Public Beta (.426) is out. Includes Airplane Importer! L0stS0ul Simulators 37 Mar 03, 2006 05:28 PM
