Old Aug 14, 2012, 01:59 PM
Aerhead is offline
Find More Posts by Aerhead
Aerhead
MN
Joined Mar 2009
Hat cam
Originally Posted by GoFaster View Post
Small steps, small steps
I made a hat cam that helps with the alignment problem you were having with your last video. My wife says to not let neighbors see it but it works great. Use a base ball type cap and hot glue some cardboard on the bill to hold a camera. Then connect to a TV to see that the camera is seeing as use hot glue some stiff wire to the bottom of the cap's bill, way out on the tip of the bill. With one eye looking though the rectangle of wire that you carefully make, you can tell that the camera is able to see. Works great and doesn't look too bad, IMHO.
Larry
Aerhead is offline Find More Posts by Aerhead
Old Aug 15, 2012, 02:11 AM
kinderkram is offline
Find More Posts by kinderkram
OS Sponsor
kinderkram's Avatar
Germany, NRW, Dusseldorf
Joined Jun 2010
Interesting idea on that "target device" on the cap, Larry!
Do you have a photo of it?
The reason I suggested an onboard video: you can see much easier if there's strange behaviour of the craft especially if you fly it farther away, i.e. on missions. You see if it wobbles or shakes on certain moves, if it turns in the right direction etc.
Things you don't see from a distance when the craft is only a small dot in the sky.
btw: the remaing batch is nearly sold out!
There are only a few boards left in Jussi's store:
http://viacopter.eu/index.php?page=s...mart&Itemid=53
kinderkram is offline Find More Posts by kinderkram
Old Aug 15, 2012, 05:20 AM
GoFaster is offline
Find More Posts by GoFaster
Live for speed
GoFaster's Avatar
USA, CT, Bethany
Joined Mar 2004
Larry, thanks for the sighting device idea. I'll have to rig something up.
kinderkram, good point! Though I've been careful so not to let this one become a small dot (yet).
GoFaster is offline Find More Posts by GoFaster
Old Aug 15, 2012, 05:33 AM
roxyboby is offline
Find More Posts by roxyboby
Joined Jul 2007
Hi Everybody. I have a Futaba T7C. Would love to fly the Autoquad. Will this converter help me use my Existing Futaba T7C. If not which one will??
http://www.frsky-rc.com/ShowProducts.asp?id=95
roxyboby is offline Find More Posts by roxyboby
Old Aug 15, 2012, 10:56 AM
AlexnderH is offline
Find More Posts by AlexnderH
AlexnderH's Avatar
Joined Dec 2006
Does the Autoquad have to be used with the Autoquad ESC's or can standard turnigy ESC's be used also?
AlexnderH is offline Find More Posts by AlexnderH
Old Aug 15, 2012, 11:05 AM
OS Sponsor
kinderkram's Avatar
Joined Jun 2010
@ roxyboby: we use a cheaper converter cable (~15$):
http://autoquad.org/wiki/wiki/autoqu...io-connections
@ AlexnderH: you can use any ESC that supports 400Hz or more.
Old Aug 15, 2012, 02:36 PM
Lyagukh is offline
Find More Posts by Lyagukh
Green slimy creature
Lyagukh's Avatar
Kyiv, Ukraine
Joined Jun 2010
I'm flying AutoQuad with reflashed Turnigy Plush ESC
Igor
Lyagukh is offline Find More Posts by Lyagukh
Old Aug 15, 2012, 03:38 PM
Andre6553 is offline
Find More Posts by Andre6553
Vulcan skyhook multirotor
Andre6553's Avatar
South Africa, GP, Pretoria
Joined Feb 2011
How long will this board be in beta? And will the updated board suport all radio types. Not bind to s-bus and spectrum radios?
Norf can you post a pic of your radio aurora9 with the cable from the trainer port and how you connect it.
Andre6553 is offline Find More Posts by Andre6553
Old Aug 15, 2012, 06:31 PM
JussiH is offline
Find More Posts by JussiH
Friend is a 4 letter word...
JussiH's Avatar
3rd stone from the sun
Joined May 2007
There is no imminent plans for a HW revision (there is a reason the board is at version 6 before beeing made publicly available). Even though some parts are EOL, we have stock that will secure we wont have to consider a HW revision anytime soon - focus for now is adding to the featureset, building expansions and improving the support tools.
We will add more radio options via PWM, PPM and Sbus, but binding is not gonna happen on the current HW revision.
In my opinion Autoquad is already highly mature, and offers unrivaled performance for those willing to invest time and effort into calibration, tuning and setup. The purpose of this "Public beta" is make sure that the code, HW and support tools are working satifactory for a wider audience and known issues have been solved. But there is no deadline on that process and due to the highly advanced and developmental nature of Autoquad, there will probably always be some part of it that is beta
JussiH is offline Find More Posts by JussiH
Old Aug 16, 2012, 03:07 AM
OS Sponsor
kinderkram's Avatar
Joined Jun 2010
Jussi: I think some guys who've entered the ArduCopter project are skeptical since the AC is in "Beta" for years now.
The AQ team can assure everybody that
- the AQ6 hardware is mature (changes will only be made on the peripheral side)
- the firmware is pretty mature (a few bugs need to be ironed out)
- the software (Windows and Android GC) has most features working. Some more need to be added to make them complete and some bug hunting needs to be done
Same for the ESC32...
Old Aug 16, 2012, 03:16 AM
Andre6553's Avatar
Joined Feb 2011
thanks for the answer no problem if the hw works all is fine.
i have a Aurora9 radio and i would like to use it with this board can someone point me in the direction of exactly what i need to fly this board with my a9 radio.
Kinderkram mention about a module that can work but i dont understand so well.
Old Aug 16, 2012, 05:20 AM
OS Sponsor
kinderkram's Avatar
Joined Jun 2010
Here's what I'm using:
http://www.rcgroups.com/forums/showt...3#post22087647
You could look for an old HP6DSM radio on Ebay or elsewhere.
Alternatively you could get a PWM/PPM converter and use you Hitec receiver. PPM isn't working 100% yet but it's on a good way and some users are already flying a PPM solution.
Old Aug 16, 2012, 10:17 AM
epyonxero is offline
Find More Posts by epyonxero
Joined Feb 2012
I also use an Aurora 9 radio, has anyone tried using a Hitec Rx with an S.Bus converter like this one. It seems like it wouldnt matter where the PWM signal was coming from but Im not sure.
http://shop.rc-electronic.com/e-vend...&c=2406&p=2406
epyonxero is offline Find More Posts by epyonxero
Old Aug 16, 2012, 10:51 AM
Andre6553's Avatar
Joined Feb 2011
thanks for that link if this can work it will be great
Description:
Description:
here are the specs
FEATURES: Makes almost any receiver instantly compatible with S.Bus
programmable servos as well as the CGY750 gyro and other S.Bus
capable equipment
Converts input from up to 10 PWM channels into a single S.Bus output
One year limited warranty through Hobby Services beginning at date of
purchase
INCLUDES: Futaba SBE-1 S.Bus PWM Adapter with ten Servo Connectors, S.Bus
Output Connector and Instruction Manual
SPECS: PWM Input: Max 10chs
Input Pulse Width: 805-2235uS
Input Frame Rate: 3-27.3ms
Output Signal: S.BUS
S.BUS Data Rate: 100kbps
Output Frame Rate: Approx. 7mS
Operating Voltage Range (rated): 4.8 - 7.4V
Dimensions: 0.92 x 1.3 x 0.37" (23.5 x 33.5 x 9.5mm) excluding cable
Weight: 0.53oz (15g) including cables
Operating Temperature Range: -10 - +45C
Storage Temperature Range: -20 - +60C
read on this forum that it work on the A9 radio or any radio
Here is a guy selling a radio with the s-bus converter
here is the manual
sbe-1-manual
Old Aug 16, 2012, 01:09 PM
GoFaster is offline
Live for speed
GoFaster's Avatar
USA, CT, Bethany
Joined Mar 2004
Remember you will need a signal inverter with that to use with the AQ board.
http://www.quadrocopter.com/Futaba-S...ter_p_544.html
New Product Autoquad team proudly presents: Autoquad ESC32 JussiH Multirotor Electronics 301 Apr 16, 2016 09:05 PM
Discussion Naza dji sh gps - south hemisphere public beta testers results! Velociraptor73 Multirotor Talk 26 Nov 20, 2012 01:45 AM
Discussion How Bloomberg's Soft Drink Ban Will Backfire on NYC Public Health MtnGoat Life, The Universe, and Politics 1 Jun 26, 2012 11:19 PM
Discussion The AutoQuad! [ video ] kapteinkuk Multirotor Talk 5 Jun 10, 2012 11:19 AM
Download G-3 Public Beta (.426) is out. Includes Airplane Importer! L0stS0ul Simulators 37 Mar 03, 2006 05:28 PM
