Old Jul 03, 2012, 08:12 PM
James not bond
jy0933's Avatar
Joined May 2012
that'd be a fresh new program.. but i feel im totally in
jy0933 is offline Find More Posts by jy0933
Old Jul 03, 2012, 08:24 PM
Canada, QC, Montreal
Joined Feb 2007
Wouhou! Sky is the limit!!!
davidevo50 is offline Find More Posts by davidevo50
Old Jul 04, 2012, 05:54 AM
rimshotcopter's Avatar
Joined Aug 2009
Looks as someone bet us to the idea. Hmmmm.
Dualcopter (4 min 55 sec)
rimshotcopter is offline Find More Posts by rimshotcopter
Old Jul 04, 2012, 09:16 AM
Mortimer's Avatar
Joined Apr 2010
With a pilot on board you get the 1955 Hiller Pawnee.
Mortimer is offline Find More Posts by Mortimer
Old Jul 04, 2012, 09:25 AM
Joined Aug 2009
Yea, there is nothing new about this stuff.
http://www.youtube.com/watch?v=JAQIgdMLeHs
http://www.youtube.com/watch?v=P9i7WKdimPU
Old Jul 04, 2012, 11:46 AM
Mortimer's Avatar
Joined Apr 2010
The question is : Why don't we see today any real helicopter or airplane with ducted fans ?
There is a reason.
On the other hand, RC aircrafts can suffer a lack of efficiency, it's not really a problem.
Old Jul 04, 2012, 11:48 AM
James not bond
jy0933's Avatar
Joined May 2012
There is a reason.
you need space for loading crew.... for this type of aircraft.. you want the mass to be as center as possible to reduce the mass moment of inertia
Old Jul 04, 2012, 12:05 PM
Joined Aug 2009
another reason is, many people simply follow what they have been told and never venture beyond that point.
Old Jul 04, 2012, 12:10 PM
Mortimer's Avatar
Joined Apr 2010
Look at "Disadvantages" here : http://en.wikipedia.org/wiki/Ducted_fan
Maybe some of the reasons Boeing or Lockheed have not used it.
Old Jul 04, 2012, 12:12 PM
Joined Aug 2009
There are disadvantages to breathing air and even living... Hmmm.,
Old Jul 25, 2012, 09:33 PM
Joined Aug 2009
Here is an experiment made from an old computer power supply cooling fan. I had some 4mm motor shafts made when I was experimenting with direct drive variable pitch tail rotors for my Swepback copter that worked perfectly for this application after adding some threads to the end of the shaft. I did a preliminary test to make sure the motor was spinning in the right direction and just had to hit the throttle once to see what it will do. At present, it is very closely balanced but I want to do some very precision adjustments and do some stress testing to make sure this system does not self-destruct under continuous load and stress.
Oh, Did I mention, it was quiet? Now if this thing will produce enough thrust, I will be in heaven.
Old Jul 25, 2012, 09:40 PM
James not bond
jy0933's Avatar
Joined May 2012
it is quiet.. the original of this fan is designed to be quiet.. they use pretty good bearings and ac motor
Old Jul 25, 2012, 09:47 PM
Joined Aug 2009
Yea but I stripped out the original motor and bearings and replaced it with a 3700KV motor. So the bearings used are the ones in the motor.
Old Jul 27, 2012, 01:29 AM
Joined Mar 2010
Something like this:
Scarab Quad with Ducted Fans (2 min 23 sec)
or a military version (which is loud):
http://www.honeywell.com/sites/servl...E-A667BE2E41A8
Also, having built a tri-ducted fan out of 3 65mm DFs myself to less success:
Main reason DF's are not used is
a. they are loud, very loud 19dB or more. Ok for an R/C Park, but any place else...? not really.
b. Uses more power (since you're using smaller dia, and higher rpms).
c. Less efficient on descent: no autorotation effect
d. hovering issues: higher rpms, harder to control (thrust vectoring), more demanding on ESCs
e. horizontal motion issues, not like a fixed-pitched copter... need to tilt more to go forward, but it's harder to keep alt. Those flying saucers designs do bring a lot of sail-effect to the table, though the above open design is a good balance. Heck there's a reason they call it the ARDrone [i]indoor hull[/].
There are many advantages (safety, simplicity, more responsive, less yaw issues, etc..) but it's easier to construct a heli-based quad at this time, it's a more mature design, reliable and has a longer running time (for now). And quieter for the AP crowd, though my mind still likes the design of a DF-based quad as it does hasve some compelling advantages.
recharged95 is offline Find More Posts by recharged95
Old Jul 27, 2012, 08:00 AM
Joined Aug 2009
what makes the present DF inefficient is the diameter. So the solution is to increase the diameter and reduce the RPMs they spin at.
For Sale HK Stinger ducted fan Vacaville CA ecoliburger Aircraft - Electric - Jets (FS/W) 0 Jun 11, 2012 02:20 PM
Question Are there any efficient ducted fan motors ? Dennis Everett Power Systems 13 Apr 20, 2010 05:26 AM
Discussion Efficiency of a ducted fan Texas Buzzard Electric Ducted Fan Jet Talk 19 Feb 02, 2008 12:32 PM
I am a bit confused about ducted fan efficiency der Oberflügel Electric Ducted Fan Jet Talk 8 Sep 03, 2005 12:56 PM
