Closed Thread
Old Jul 03, 2012, 01:41 PM
rimshotcopter's Avatar
Joined Aug 2009
I have not done this is sometime now, hope it does not bit me.
Here is my idea, using two motor/props, the one on the bottom a higher pitch. The props shown are just for illustration and will be replaced with an APC 8x3.8 on the top and an APC 8x6 on the bottom. Reason for the Pitch differences is, the second prop will accelerate the air produced by the first prop.
rimshotcopter is offline Find More Posts by rimshotcopter
Old Jul 03, 2012, 01:46 PM
James not bond
jy0933's Avatar
Joined May 2012
not a need for dual prop... the Dia-changing shroud will increase pressure on downstream.. if the d is constant... different pitch prop will create a vacuum like state in between.. either the lower prop cant get enough air.. or the top prop get dragging faster due to the demand of more air (cant think of how to explain more clearer)
jy0933 is offline Find More Posts by jy0933
Old Jul 03, 2012, 01:47 PM
United States, OR, Portland
Joined Aug 2011
Also ...
This reference is for flow measuring nozzles. But their shape useful because in flow measurement one wants to have a laminar flow in the device because unsteady or turbulent flow will mess up the readings. The reference has drawings with proportional dimensions of nozzles that could be used a shrouds.
http://edge.rit.edu/content/P12056/p...167-3-2003.pdf
Jim
Jem3 is offline Find More Posts by Jem3
Old Jul 03, 2012, 01:48 PM
Joined Aug 2009
Ok, I understand. We will start testing with just one prop/motor.
Thanks for the input.
Old Jul 03, 2012, 01:49 PM
Joined Aug 2009
Originally Posted by Jem3 View Post
Also ...
Jim
Thank you, have some reading to do.
Old Jul 03, 2012, 01:54 PM
Joined Aug 2009
Now this brings back memories.
I once worked for a company that made Turbochargers.
Old Jul 03, 2012, 01:59 PM
James not bond
jy0933's Avatar
Joined May 2012
i actually got an easier way to measure the thrust
compare the reading
calibration:
holding gauge upright. record the reading for motor&prop and motor&prop&shroud
Old Jul 03, 2012, 04:23 PM
rob10000's Avatar
there is alot of engineering that goes into optimizing the duct. Here's some light reading...
http://www.personal.psu.edu/cxc11/pa...CTED_FAN_1.pdf
regarding blade tip clearance, once it exceeds 5.17%, the ducting becomes much less efficient. Inlet lip and diffusion duct geometry also have serious influences.
rob10000 is offline Find More Posts by rob10000
Old Jul 03, 2012, 04:28 PM
Joined Aug 2009
Thanks Rob!
Old Jul 03, 2012, 06:50 PM
Canada, QC, Montreal
Joined Feb 2007
If I may, here is an interesting video that maybe could genarate some ideas.
Honeywell T Hawk Described (2 min 53 sec)
It's the Honeywell Hawk uav, some of you guys may have allready seen it here it is anyway!
davidevo50 is offline Find More Posts by davidevo50
Old Jul 03, 2012, 07:01 PM
James not bond
jy0933's Avatar
Joined May 2012
this is the one in BF3.
http://www.thawkmav.com/system_features.php
spec from HW
gas engine
48min flight time
Old Jul 03, 2012, 07:06 PM
Joined Aug 2009
Thank you David for sharing the video with us. Very interesting what I like the most is it all weather capability.
All Weather Day/Night Operation
Operates in rain, salt, fog, sand, and dust
Takes off and lands in winds up to 17 miles per hour
Old Jul 03, 2012, 07:38 PM
James not bond
jy0933's Avatar
Joined May 2012
i think that is due to it's gas engine... all the electronics are sealed in the case... which should be water proof
Old Jul 03, 2012, 07:57 PM
Joined Feb 2007
The gas engine produces 4hp, something that can be acheived with the brushless motors that we use for our 700 class e-helis today... Would be nice to see something like that. I know it wouldn't be a multi anymore but the "general idea" is still there. Just need to get a control board that could be used to control the servos for the vector surfaces...
Old Jul 03, 2012, 08:12 PM
Joined Aug 2009
Funny that you should mention control board, the WiiCopter just so happens to have a new addition. http://www.multiwii.com/forum/viewtopic.php?f=8&t=1882
keep in mind here, we are looking at the control system and not the aircraft itself.
MultiWii SingleCopter (0 min 29 sec)
Closed Thread
For Sale HK Stinger ducted fan Vacaville CA ecoliburger Aircraft - Electric - Jets (FS/W) 0 Jun 11, 2012 02:20 PM
Question Are there any efficient ducted fan motors ? Dennis Everett Power Systems 13 Apr 20, 2010 05:26 AM
Discussion Efficiency of a ducted fan Texas Buzzard Electric Ducted Fan Jet Talk 19 Feb 02, 2008 12:32 PM
I am a bit confused about ducted fan efficiency der Oberflügel Electric Ducted Fan Jet Talk 8 Sep 03, 2005 12:56 PM
