Old Mar 12, 2013, 02:09 PM
TayNinh68 is offline
Find More Posts by TayNinh68
Mosquito 6
Joined Jun 2012
Originally Posted by rimshotcopter View Post
I precisely drilled a toy gyro and attacked it to the shaft of the motors as shown in the picture below. As for the Variable pitch system, I would used two 450 Helicopter rotors rigged for Pitch only (KIS).
Ahhh .. I see now .. a picture's worth a thousand words. And the pellets are for balancing? LOL .. The only ammo still available .. almost. Your dish experiment .. was to increase rotational inertia? Or pehaps like the crank damper on an IC engine? Never seen that before .. just curious.
Yeah, the stock heli parts are reasonable and available, but I'm just a spectator on this thread .. I got my hands full with the sedecopter (wasp whacker) and an octo coming up with the MT4008's .. sweet
Cheers ..
TayNinh68 is offline Find More Posts by TayNinh68
Old Mar 12, 2013, 02:17 PM
rimshotcopter is offline
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
Gyroscopic Force Experiment
Here is a simple experiment that can be easily constructed from an old LP record, burshless motor and prop adapter. Spin up the LP using a string and move the motor forward and aft. Note the direction of the force.
Gyroscopic Force Experiment (0 min 53 sec)
rimshotcopter is offline Find More Posts by rimshotcopter
Old Mar 12, 2013, 02:23 PM
Joined Aug 2009
Cheers ..
Let me see if I can put this in its proper context, on an OAT bicopter, PART of the Pitch control is derived from the gyroscopic forces of the spinning props HOWEVER, the ROLL is controlled by thrust differential when using conventional airplane props. This I STRONGLY believe have an advert effect on the Pitch control. This is why I believe, in order for total control of the Pitch axis, will require the employment of a constant rotor rotational speed and a variable the Pitch of the of the Props to control the Roll axis.
Old Mar 12, 2013, 02:39 PM
Test Pilot Mafia is offline
Find More Posts by Test Pilot Mafia
CSU Chico, Flight Club
Test Pilot Mafia's Avatar
United States, CA, Chico
Joined Sep 2012
... on an OAT bicopter, PART of the Pitch control is derived from the gyroscopic forces of the spinning props HOWEVER, the ROLL is controlled by thrust differential when using conventional airplane props. This I STRONGLY believe have an advert effect on the Pitch control....
so the PID values for roll must also influence the pitch behavior !?
Test Pilot Mafia is offline Find More Posts by Test Pilot Mafia
Old Mar 12, 2013, 02:40 PM
Joined Aug 2009
I believe you are mixing Apples and Oranges. The electronics have nothing to do with this aspect of the build. If the Airframe is not right, no amount of electronics will make it fly.
Old Mar 12, 2013, 02:50 PM
Joined Sep 2012
I believe you are mixing Apples and Oranges. ...If the Airframe is not right, no amount of electronics will make it fly.
yes, i realize this point. But apparently i dont know how to build a useful airframe.
Even this one wont fly right:
Old Mar 12, 2013, 02:52 PM
Joined Aug 2009
Well, don't take this harshly but I told you from the onset, your tilting direction was wrong. Honestly, I don't understand how you did this complete rebuild and made the same mistake.
Old Mar 12, 2013, 02:57 PM
Joined Sep 2012
but how is it wrong? i specifically made sure i made the CG/CL and tilting like your proven machines...
Old Mar 12, 2013, 02:58 PM
Joined Aug 2009
Ok Sir.
Old Mar 12, 2013, 03:17 PM
Joined Sep 2012
RimShot, did you use D value in the pitch axis of your flymentor machine?
Old Mar 17, 2013, 02:00 PM
Joined Aug 2009
I was very nervous during this test flight for many reasons however, I think this test went well. She is still a little tail heavy but that is easily adjustable by moving the battery forward. I can also modify the weight sifting logic in the firmware to allow adjustment from the transmitter however, I want to keep it centered to allow maximum travel forward and aft during development. Thank you Bob for finding such a wonderful testing location.
Mollie-VTOL at Dominguez Hills (3 min 5 sec)
Old Mar 18, 2013, 08:10 AM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
It's looking good and stable Richard!
Cheers,
JIm
Quadrocopter and Tricopter Info Mega Link Index
http://youtu.be/ss1_VRE3pnY
jesolins is offline Find More Posts by jesolins
Old Mar 18, 2013, 08:24 AM
Joined Aug 2009
Cheers,
JIm
Thank you Jim, you of all people know of the Journey it took to get here and I really appreciate your support.
Old Mar 18, 2013, 03:05 PM
PilotAir is offline
Find More Posts by PilotAir
which way is up?
PilotAir's Avatar
United States, CA, Marina
Joined Jan 2012
Another fun idea to needlessly complicate things:
http://www.faqs.org/patents/app/20110147533
Morphing duct geometry to help with forward/windy flight.
PilotAir is offline Find More Posts by PilotAir
Old Mar 18, 2013, 04:45 PM
Joined Sep 2012
I wonder if Nitinol memory wire could be used for the morphing duct, as seen here...
For Sale HK Stinger ducted fan Vacaville CA ecoliburger Aircraft - Electric - Jets (FS/W) 0 Jun 11, 2012 03:20 PM
Question Are there any efficient ducted fan motors ? Dennis Everett Power Systems 13 Apr 20, 2010 06:26 AM
Discussion Efficiency of a ducted fan Texas Buzzard Electric Ducted Fan Jet Talk 19 Feb 02, 2008 01:32 PM
I am a bit confused about ducted fan efficiency der Oberflügel Electric Ducted Fan Jet Talk 8 Sep 03, 2005 01:56 PM
