Old Jan 30, 2013, 02:01 PM
rimshotcopter is online now
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
Thank for the above information, it surely will come in handle, very soon.
rimshotcopter is online now Find More Posts by rimshotcopter
Old Jan 30, 2013, 02:06 PM
Test Pilot Mafia is offline
Find More Posts by Test Pilot Mafia
CSU Chico, Flight Club
Test Pilot Mafia's Avatar
United States, CA, Chico
Joined Sep 2012
Originally Posted by rimshotcopter View Post
Thank for the above information, it surely will come in handle very soon.
i added the pic just now.
but remember, i think weve all had problems with ducts bending to meet the props and being obliterated. As we tighten the duct diameter, expect those occasions to worsen
the Embry riddel team was given many hours on Boeings 3D polycarbonate printer, which was why there ducts were so ridgid. i dont know how we will do the same...
Test Pilot Mafia is offline Find More Posts by Test Pilot Mafia
Old Jan 31, 2013, 07:50 AM
Joined Aug 2009
Not very much tip clearance! I will have to file down the tips of these props a very small amount hopefully maintaining 1/16" distant mentioned above. I opted not to use the salad bowls, after removing the base, they just did not have the structural strength I had hoped for however, I may still use the upper ring because of the radius. Instead, I opted for the cut down 12" concrete forums.
Old Jan 31, 2013, 01:21 PM
Joined Sep 2012
i have considered the same use of the forms... but how are they on wheight? my styrofoam are just too flimsy...
And how stiff is your 120 degree supports making the duct? will it survive minor bumps without bending into the prop?
do you reccomend turning the whole arm with motor? or using a hinge on the motor w servo? (for bicopter use i mean)
Old Jan 31, 2013, 01:42 PM
Joined Aug 2009
I am rotating the entire assembly, arms and Ducts as one unit. See the video posted here
As for the structural strength of the duct, all I can tell you is, MUCH better than foam. As for weight, I don't worry about weight until after it is flying (of course I make sure there is enough power), then I will go back over it looking for areas where I can reduce weight and make things more efficient.
Old Jan 31, 2013, 02:08 PM
Joined Sep 2012
I am rotating the entire assembly, arms and Ducts as one unit....
im doing the same, the ball links didnt seem to work well.
Old Jan 31, 2013, 04:02 PM
abletowinginc is offline
Find More Posts by abletowinginc
Lets make it remote control!!!
abletowinginc's Avatar
USA, FL, St Augustine
Joined Jun 2009
nice looking ducts...lookin good .......good luck fellas
abletowinginc is offline Find More Posts by abletowinginc
Old Jan 31, 2013, 04:15 PM
Joined Aug 2009
Thank you, here is a preview of what's to come. The Radius (made from a salad bowl) just sitting there drying, it is freshly painted.
Old Jan 31, 2013, 04:35 PM
Joined Aug 2009
I may leave that Radius off, I am undecided.
Old Jan 31, 2013, 05:14 PM
KAMAX-T is offline
Find More Posts by KAMAX-T
KAMAX-T's Avatar
Powell TN
looks good Rev. keep up the good work..
Terry
KAMAX-T is offline Find More Posts by KAMAX-T
Old Feb 02, 2013, 12:04 AM
Joined Sep 2012
i have bought a 10.375 ID x 48 long, cardboard cement tube, i plan to have 0.185 inch clearance for my 10" Dia MA tri-props...
This looks cheaper and easier than carbon fiber... and at 10.375 x 1.2 inches i can make many ducts quickly...
( on my table saw, i should get 35-ish ducts off a single 48 inch long tube )
Last edited by Test Pilot Mafia; Feb 02, 2013 at 01:06 AM. Reason: My terrible spelling...
Old Feb 02, 2013, 02:59 AM
TayNinh68 is offline
Find More Posts by TayNinh68
Mosquito 6
Joined Jun 2012
The Very first test of the new Weight Shifting/Transferring System.
http://youtu.be/iQ_N94XRM1Y
I have yet to place an order for the servo saver but I figured I could get some bench and hovering testing done.
subscribed. Clever application .. shifting weight dynamically to control flight attitude .. like a hang glider. I bought 3 Dunhaven gyro-servors for a future gimbal build .. perhaps a GS-1 would be helpful to "automate" that function .. servo input would just be for "trim".
http://www.dunehaven.com/gs1.htm .. If he's out of stock, try kapshop.com (Norway .. also had stock of GS-1 CR).
Cheers
TayNinh68 is offline Find More Posts by TayNinh68
Old Feb 02, 2013, 03:14 AM
Mosquito 6
Joined Jun 2012
Perhaps a candidate for a CF layup .. duct and shroud combo .. nice.
Old Feb 02, 2013, 05:18 AM
Joined Aug 2009
Yea, the cardboard tubing is not as light as I would like however, I have not found anything else at the local hardware store what would work in the diameters required for the prop sizes used. I would love to work with fiberglass but just have not ventured into that area yet.
I am cutting the tubes to 2.5" presently but I am going to try some 1.75-2.00" in an attempt to reduce weight.
Old Feb 02, 2013, 05:19 AM
Joined Aug 2009
Cheers
I love these servos and spent many nights dreaming about them. Just never made the investment. Then I came upon the Arduino with the MWC firmware, then there was no need for them.
For Sale HK Stinger ducted fan Vacaville CA ecoliburger Aircraft - Electric - Jets (FS/W) 0 Jun 11, 2012 02:20 PM
Question Are there any efficient ducted fan motors ? Dennis Everett Power Systems 13 Apr 20, 2010 05:26 AM
Discussion Efficiency of a ducted fan Texas Buzzard Electric Ducted Fan Jet Talk 19 Feb 02, 2008 12:32 PM
I am a bit confused about ducted fan efficiency der Oberflügel Electric Ducted Fan Jet Talk 8 Sep 03, 2005 12:56 PM
