Old Dec 31, 2012, 12:50 PM
rimshotcopter is online now
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
Originally Posted by kahloq View Post
check this out.....Wish I had known about these earlier.....would have made the terminator project a LOT smaller and lighter..but much more expensive LOL
120mm alloy all metal 12 blade edf unit that can run up to 100,000 rpm's on anything from 10s-16s
http://easytigermodels.com/index.php...roducts_id=352
They have a 90mm version as well and with one that has a pod complete with extended ducting
Awe ya! @ $299.00
rimshotcopter is online now Find More Posts by rimshotcopter
Old Jan 02, 2013, 02:11 PM
Joined Aug 2009
Installed the new motor mount/arms today. I did not drill the lightening holes because I figured the weight savings would not amount to much at this stage. Once the concept is working, I will revisit weight reduction on the entire aircraft. Learned something new today, that being, when the flaps are down, the prop wash will cause the aircraft to move forward. Which in theory, should be great for the transition to airplane mode.
VTOL Test08 (1 min 12 sec)
Old Jan 02, 2013, 09:08 PM
Joined Aug 2009
After each test, I do a complete inspection to see what I need to modify or prays myself for a job well done. Well, I noticed from this last test, the servo horns are the weak link, so I order these puppies. Alumimun is becoming my building material of choice. Picked these Aluminum servo horns up on eBay for a really good price.
36mm CNC Servo Arm For Futaba 25T Horn
Old Jan 03, 2013, 02:51 PM
Joined Aug 2009
Old Jan 03, 2013, 08:17 PM
Joined Aug 2009
I wanted to find out why this VTOL have a tendency to creep forward and thought it was related to the flaps being extended. What I learned from this round of testing is, I need to head to the airfield where there is more room. She does not fly like my other copters and have a different set of flight characteristics. I will place testing on hold until receipt of the new Servo horns because that is the weak link in the control system.
Mollie VTOL-Test09 (1 min 30 sec)
Old Jan 03, 2013, 08:49 PM
goodhumormarc is offline
Find More Posts by goodhumormarc
figuring it out...sort of!
goodhumormarc's Avatar
USA, OR, Happy Valley
Joined Jul 2010
nice!
goodhumormarc is offline Find More Posts by goodhumormarc
Old Jan 08, 2013, 05:26 PM
Joined Aug 2009
Installed a new set of servo horns and adjusted the control linkage, she still required some PID tuning especially on the Yaw controls. After we have successfully had done a forward flight test, we will start the search for Ducts to encase the props.
Mollie VTOL-Test10 (1 min 33 sec)
Old Jan 08, 2013, 06:31 PM
Joined Jul 2010
looks a lot more stable! have you tried an HVAC place? Heating and air conditioning Or 5QT icecream containers for Duct material?
Old Jan 08, 2013, 06:40 PM
Joined Aug 2009
Interesting, No I have not but will have a look.
Thanks for the suggestion.
Old Jan 09, 2013, 01:31 PM
Joined Aug 2009
Made some adjustments to the PID Settings and minor adjustments to the mixing. Went to Home depot this morning looking for something to make the ducts from but came home empty handed. I will take time in search search for the right material, In the meantime, stay tune. This will be the last backyard test done, the next video will be from an airfield with the fan ducts installed.
Mollie VTOL-Test11 (2 min 2 sec)
Old Jan 09, 2013, 08:06 PM
Joined Jul 2010
sweet! congrats man! good luck on your field maiden.
Old Jan 09, 2013, 08:09 PM
Joined Aug 2009
Thank you.
Old Jan 10, 2013, 06:04 PM
KAMAX-T is offline
Find More Posts by KAMAX-T
KAMAX-T's Avatar
Powell TN
looks good Rev. Nice and stable hover... lookin' forward to transition..
Terry
KAMAX-T is offline Find More Posts by KAMAX-T
Old Jan 19, 2013, 04:14 AM
DengisKong is offline
Find More Posts by DengisKong
one man's trash
United States, TX, Dallas
Joined Dec 2011
maybe these fans would be good?
Just saw one of these fans at my buddy's place and thought maybe it'd be better than the smaller computer fans... I might order one for tests as I am in the process of building a tri and a quad of my own and want to fly safely with folks around.
http://store.antec.com/Product/cooli...5-75200-8.aspx
DengisKong is offline Find More Posts by DengisKong
Old Jan 19, 2013, 07:58 AM
Joined Aug 2009
thank you, 200mm is something to consider.
For Sale HK Stinger ducted fan Vacaville CA ecoliburger Aircraft - Electric - Jets (FS/W) 0 Jun 11, 2012 02:20 PM
Question Are there any efficient ducted fan motors ? Dennis Everett Power Systems 13 Apr 20, 2010 05:26 AM
Discussion Efficiency of a ducted fan Texas Buzzard Electric Ducted Fan Jet Talk 19 Feb 02, 2008 12:32 PM
I am a bit confused about ducted fan efficiency der Oberflügel Electric Ducted Fan Jet Talk 8 Sep 03, 2005 12:56 PM
