Old Dec 12, 2012, 05:52 AM
rimshotcopter is online now
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
Originally Posted by kahloq View Post
In my case, the 5 gal buckets weight more then the motors do. I will have to use a decent amount of wood to brace the wings with the weight of the buckets/motors hanging way out at the edges.
I might be on a losing path, but somehow, someway...it will fly.
If I may make this suggestion, I understand you want to preserve the Terminator looking with the length of the buckets however, why not cut them down to minimum. Later, once you have a flying machine, you can use fiberglass or some other very light compound to accomplish the cosmetic appearance.
rimshotcopter is online now Find More Posts by rimshotcopter
Old Dec 12, 2012, 06:13 AM
Joined Aug 2009
P.S. Dollartree foam board would be a very good options to encase the plastic ring and to lengthen the appearance. It is very easy to roll and it is very strong as well.
Old Dec 12, 2012, 10:13 PM
kahloq is offline
Find More Posts by kahloq
kahloq's Avatar
Fort Collins, Colorado, USA
Joined Dec 2005
The buckets themselves don't weigh much. Cutting them down and then adding fiberglass or stiff foam won't save much if any weight when factoring in the glue to do it. I do understand weight is a premium concern. The whole point of what I'm doing is to make the vehicle as scale in appearance as possible, otherwise its pointless to me.
When all is said and done and if it won't lift off on three fan units, I have no problem adding in more fans just concealed in the wings. I am quite committed to making this thing fly while retaining the visual looks.
kahloq is offline Find More Posts by kahloq
Old Dec 14, 2012, 03:30 PM
kahloq is offline
kahloq's Avatar
Joined Dec 2005
Been thinking of total lift for the vehicle and Id rather have more then needed then not enough. After studying some of the photos I have of the movie versions of the HK heavy, there is a large area on the back spine of the craft that has a lot of louvers. This area is highlighted in red in the pic below.
This looks like a perfect place to hide a forth decent size fan unit. It wont be the same size as the 5 gal home depot buckets, but still a lot bigger then a 90 or 120mm ducted fan.
I was able to source a smaller bucket from work that is probably a 2.5 gal bucket. I can fit a 9" diameter prop in it so thats what Im planning on doing.
Might as well design the ship to have it from the start then mod it in afterwards
Old Dec 18, 2012, 12:51 PM
kahloq is offline
kahloq's Avatar
Joined Dec 2005
Ive got a thread going on for my terminator project. Please feel free to visit and comment.
http://www.rcgroups.com/forums/showthread.php?t=1766835
While this thread here is relevant to what Im doing, Im not sure I want to clutter this thread up with photos of my endeavor and overshadow anything the OP has been doing.
One last pic of my progress. Please feel free to subscribe to dedicated thread of the HK aerial. I will still visit here from time to time and may post a photo once and awile, but most updates and pics etc will be uploaded in the terminator thread.
Old Dec 21, 2012, 02:21 PM
Joined Aug 2009
In this test, I removed the ducts, figures I would get her flying first, then find the right ducts for her later. I am using 12x4.5 props and RTImer 750KV Motors in this test, she lifted off however, I did not want to run the risk of crashing, so I set her down. It appears, my favor motors of choice are best for this build also, that being the RCTimer 900KV with a 12" or 14" prop. I will need to work out ground clearance but it appears, I will have to model the transitioning upon the V-22. We have much to do before that time arrive.
Mollie VTOL-Test03 (0 min 50 sec)
Old Dec 21, 2012, 05:05 PM
KAMAX-T is offline
Find More Posts by KAMAX-T
KAMAX-T's Avatar
Powell TN
Hey Reverend , your gettin there ,..... keep us weak minded informed ......And ...merry Christmas to you , and the family ..
Terry
KAMAX-T is offline Find More Posts by KAMAX-T
Old Dec 26, 2012, 02:27 PM
Joined Aug 2009
Mollie VTOL-Test05 (1 min 17 sec)
She lifted off at about 50% Throttle and the usage of the RCTimer 3536-9 910KV Motors and Master Airscrews 12x6 props are the right combination. The video states APC for props, that is an error.
Old Dec 26, 2012, 08:44 PM
Joined Aug 2009
In addition to PID tuning, I need to make some adjustments to the linkage. She wants to YAW to the left.
Old Dec 27, 2012, 11:07 AM
KAMAX-T is offline
KAMAX-T's Avatar
Powell TN
lookin' good Rev. , your about to get there ....
Terry
Old Dec 27, 2012, 01:17 PM
Joined Aug 2009
Thank Terry,
Here is a quick progress report. Still require more PID tuning.
Mollie VTOL-Test06 (0 min 44 sec)
Old Dec 27, 2012, 07:44 PM
KAMAX-T is offline
KAMAX-T's Avatar
Powell TN
Yes Sir ......... Almost ready !
Terry
Old Dec 28, 2012, 06:03 PM
Joined Aug 2009
I remade the motor mounts to accommodate a larger ducts and Ordered new bearings. I have yet to drilled lighting holes and install the control horns.
Note: I now Aluminum Weld all joints and Rivets.
Old Dec 30, 2012, 03:39 PM
hklagges is offline
Find More Posts by hklagges
hklagges's Avatar
Munich
Joined Dec 2008
It sounds like a very angry bumblebee - pretty impressive results so far!
Cheers,
Henrik
hklagges is offline Find More Posts by hklagges
Old Dec 31, 2012, 10:48 AM
kahloq is offline
kahloq's Avatar
Joined Dec 2005
check this out.....Wish I had known about these earlier.....would have made the terminator project a LOT smaller and lighter..but much more expensive LOL
120mm alloy all metal 12 blade edf unit that can run up to 100,000 rpm's on anything from 10s-16s
http://easytigermodels.com/index.php...roducts_id=352
They have a 90mm version as well and with one that has a pod complete with extended ducting
For Sale HK Stinger ducted fan Vacaville CA ecoliburger Aircraft - Electric - Jets (FS/W) 0 Jun 11, 2012 02:20 PM
Question Are there any efficient ducted fan motors ? Dennis Everett Power Systems 13 Apr 20, 2010 05:26 AM
Discussion Efficiency of a ducted fan Texas Buzzard Electric Ducted Fan Jet Talk 19 Feb 02, 2008 12:32 PM
I am a bit confused about ducted fan efficiency der Oberflügel Electric Ducted Fan Jet Talk 8 Sep 03, 2005 12:56 PM
