Old Dec 07, 2012, 07:43 PM
KAMAX-T is offline
Find More Posts by KAMAX-T
KAMAX-T's Avatar
Powell TN
Terry
KAMAX-T is offline Find More Posts by KAMAX-T
Old Dec 07, 2012, 09:02 PM
kahloq is offline
Find More Posts by kahloq
kahloq's Avatar
Fort Collins, Colorado, USA
Joined Dec 2005
So....had ordered 3 HS 775MG mega scale servos through local hobbyshop 3 weeks ago.....only one came in and I was told they werent sure why the other two hadnt shown up. So...I waited a week and was told the other two should arrive any day.
Well...now Im told they didnt even order 3 and only the initial first one. GRRRRRRR. ARGGGGHHHHH!!!!!
So...now Ive got to wait yet another week for the next 2 to show up. These servos are crucial to the build as they are what I have to build the wings and tail section around. I can tdo that without them in hand.
I know I could have ordered them myself online, but, I only have to pay 15% above dealer cost with this shop, so it ends up a decent savings.
kahloq is offline Find More Posts by kahloq
Old Dec 10, 2012, 11:57 AM
kahloq is offline
kahloq's Avatar
Joined Dec 2005
Quick video showing a home depot bucket with rimfire .60 650kv installed and running. 11x7x3 MAS prop on 25c 6s 5000 turnigy. Its just an initial test but is encouraging. Bucket lifted off the ground at a tad over 1/3 throttle and held steady a few inches off the ground at 1/2. My hands are only making sure it doesnt topple over...I am not holding it up and you can see the bucket slowly spinning while I have it steady.
I never went over 1/2.....kinda made me nervous...didnt want it to shoot up to the ceiling or lose my fingers LOL.
With better batteries...it'll surely prodice even more thrust at same throttle settings. At least I know that Ive got some room for weight of the vehicle with 3 of these running. Probab ly will still have to add additional motors or extra ducted fan units within the frame...but this is a good start.
FILE0004 (0 min 56 sec)
Old Dec 10, 2012, 12:02 PM
rimshotcopter is online now
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
Very inspiring!!!
rimshotcopter is online now Find More Posts by rimshotcopter
Old Dec 10, 2012, 02:57 PM
Joined Aug 2009
Another in-process test video while we wait delivery of the new 1700kv motors. 750kv is not enough for this build. I ordered the wrong size wire for rewiring the existing motors, so I took the easy way out and ordered new ones. On all of my builds after the initial Tricopter, I have used 900kv, 1100kv, 1300kv and now 1700kv motors. I know at one time, the 750kv motors were and still is the standard by which all other motors for multi-rotor copters are compared against, but I just do not understand why.
In this test, I am working out the mixing requirement for the servos and motors to be able to taxing on the ground and in close quarters.
Mollie VTOL-Test02 (1 min 48 sec)
Old Dec 10, 2012, 03:13 PM
kahloq is offline
kahloq's Avatar
Joined Dec 2005
Why are the 1700's required? Just curious.
Didnt seem you were any where close to full throttle in your tests in the video?
Old Dec 10, 2012, 03:21 PM
Joined Aug 2009
No, just my thrust calculations to lift this copter, requires 1500kv with the props used due to the limited duct size. 1700kv is a luxury.
Here is a link the ones or similar I will end up with.
http://www.rctimer.com/index.php?gOo...4&productname=
Here is a basic static thrust calculator: http://personal.osi.hu/fuzesisz/strc_eng/
Old Dec 10, 2012, 03:52 PM
Joined Aug 2009
Just for reference: http://www.ecalc.ch/xcoptercalc_e.htm?ecalc will give the entire picture but I like KIS.
Old Dec 10, 2012, 03:54 PM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
Hi Richard,
The 750Kv motors using 10-12" 38-45 pitch props recommended for about the 1-2kg quadcopter is still a working formula. However today there is now much more build size, weight and variety now since that was a very common build as you note along with your experimentation. You are trying to use some ducting with higher RPM motors and comparatively smaller props on a bi-copter setup, so it does in fact make sense that you need higher Kv motors. Other examples are the sport multicopters that use 7-8" props and 1800-2300kv motors. The mini and micro sized quads that Gents are building and flying typically use about 2" props and 16,000-20,000Kv+ motors. There are very efficient multicopters now flying that use 360Kv motors and 1645 props and are getting up to an hour of flight time with 8k 4s lipos. It is all in the design and requirements and we have learned much about those in the last 10 years of experimentation.
Congrats and keep up the great work!
Cheers,
Jim
Quadrocopter and Tricopter Info Mega Link Index
Originally Posted by rimshotcopter View Post
... I know at one time, the 750kv motors were and still is the standard by which all other motors for multi-rotor copters are compared against, but I just do not understand why.
jesolins is offline Find More Posts by jesolins
Old Dec 10, 2012, 03:57 PM
Joined Aug 2009
Thank you Jim! Glad to see ya about. Merry Xmax.
Old Dec 10, 2012, 11:39 PM
kahloq is offline
kahloq's Avatar
Joined Dec 2005
According to that calculator, my three fan/motor setups will produce 16 pounds of total thrust.
Old Dec 11, 2012, 06:50 AM
Joined Aug 2009
I do not know total weight nor am I close to having an idea....but probably around 9 to 10 pounds. The total size of the vehicle will be roughly 8 feet wide and similar length long. Because of the size of the vehicle, if the 3 duct/fan rotors is not enough to lift it, there is plenty of space in the wing/pylon areas to add in additional thrust producers and hide them.
It would appear, you are right on the money with the 1.5 to 1 thrust to weight ratio. From personal experience (and I have built some heavy copters ), I would not go any lower than the 1.5.
Old Dec 11, 2012, 10:36 AM
kahloq is offline
kahloq's Avatar
Joined Dec 2005
The 9 - 10 pound estimate was just that...a guess. I really hope it comes out around there given the total thrust I SHOULD see from the three fans.
With my luck though....it will come out more like 14 pounds and obviously that would require additional motors/fans to make it fly.
Old Dec 11, 2012, 10:39 AM
Joined Aug 2009
The major part of the AUW is the batteries, second are the motors. Adding more just complicate the problem in my opinion, I want to strongly emphasize, my opinion.
Old Dec 11, 2012, 10:05 PM
kahloq is offline
kahloq's Avatar
Joined Dec 2005
In my case, the 5 gal buckets weight more then the motors do. I will have to use a decent amount of wood to brace the wings with the weight of the buckets/motors hanging way out at the edges.
I might be on a losing path, but somehow, someway...it will fly.
For Sale HK Stinger ducted fan Vacaville CA ecoliburger Aircraft - Electric - Jets (FS/W) 0 Jun 11, 2012 02:20 PM
Question Are there any efficient ducted fan motors ? Dennis Everett Power Systems 13 Apr 20, 2010 05:26 AM
Discussion Efficiency of a ducted fan Texas Buzzard Electric Ducted Fan Jet Talk 19 Feb 02, 2008 12:32 PM
I am a bit confused about ducted fan efficiency der Oberflügel Electric Ducted Fan Jet Talk 8 Sep 03, 2005 12:56 PM
