Old Jul 02, 2012, 03:02 PM
rimshotcopter is offline
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
Build Log
Duct Fan efficiency and safety & (Tilt Rotor Build).
I read over the following Wikipedia page on Duct fans and it seems to me, they would be more efficient on a Multi-rotor copter (MRC) because unlike an fast moving aircraft, the thrust required for MRC is mostly static.
http://en.wikipedia.org/wiki/Ducted_fan
  • By reducing propeller blade tip losses, the ducted fan is more efficient in producing thrust than a conventional propeller, especially at low speed and high static thrust level (airships, hovercrafts).
  • By sizing the ductwork appropriately, the designer can adjust the air velocity through the fan to allow it to operate more efficiently at higher air speeds than a propeller would.
  • For the same static thrust, a ducted fan has a smaller diameter than a free propeller, allowing smaller gear.
  • Ducted fans are quieter than propellers: they shield the blade noise, and reduce the tip speed and intensity of the tip vortices both of which contribute to noise production.
  • Ducted fans can allow for a limited amount of thrust vectoring, something normal propellers are not well suited for. This allows them to be used instead of tiltrotors in some applications.
  • Ducted fans offer enhanced safety on the ground.
I would like to ask your thoughts on this topic. I know the general debate has been, Duct-Fans are less efficient but I think this argument was based upon the EDF with a very small OD. I believe the largest I have seen is a 90mm.
rimshotcopter is offline Find More Posts by rimshotcopter
Last edited by rimshotcopter; Nov 28, 2012 at 05:03 PM. Reason: Changed the Title.
Old Jul 02, 2012, 03:15 PM
jy0933 is offline
Find More Posts by jy0933
James not bond
jy0933's Avatar
Joined May 2012
nice brought it up...
i think the adv/disadv is pretty much based on research on large vehicle( airplane, ships) and a very fast speed( comparing to multirotor)..
since it is a new dedicated post....i'll move my discussion from the other thread
this is my point in respond to chaosdestro0
Less efficient than a propeller at cruise (at lower thrust level).
if you scale down the weight/shape/volume down to multirotors, the thrust level we have is relative high .. thus the efficient should still be at a good level
jy0933 is offline Find More Posts by jy0933
Old Jul 02, 2012, 03:28 PM
chaosdestro0 is offline
Find More Posts by chaosdestro0
Quad lover.
chaosdestro0's Avatar
Joined Dec 2011
This is the video that made me think it was less efficient
mwc quad // flying saucer [2] (2 min 8 sec)
What you also have to factor in is drag caused by the frame. In my opinion the best idea would be to use a wire cage around the propellers, very low drag and weight.
chaosdestro0 is offline Find More Posts by chaosdestro0
Old Jul 02, 2012, 03:36 PM
Joined Aug 2009
In the video, the drag is from the poor aerodynamic of the frame and not the ducts.
Old Jul 02, 2012, 03:39 PM
Quad lover.
Joined Dec 2011
Originally Posted by rimshotcopter View Post
In the video, the drag is from the aerodynamics of the frame and not the ducts.
I think you are right, I think there should be some testing on this. Wire cages is probably an easier method to protect people from props but I think just proper safety methods would be better for most people.
Old Jul 02, 2012, 03:43 PM
Joined Aug 2009
happens, we can not always plan for that.
Old Jul 02, 2012, 03:54 PM
jy0933 is offline
James not bond
jy0933's Avatar
Joined May 2012
that is not a duct fan ..... OMG... all the flat surface results in drag (esp the top)
the dust has to be like a thin layer cylinder..
like this
but we are looking for at least maintain the trust w/o duct... i wonder if there is plastic bottle having 5"~10" D... they are just barely weighted
Old Jul 02, 2012, 03:58 PM
Quad lover.
Joined Dec 2011
like this
Yes I was wrong and didn't think about that when making that comment.
Anyway, has anyone got any ideas about how you would mount a duct to most multirotors?
Old Jul 02, 2012, 03:59 PM
Joined Aug 2009
like this
I like this and have lots of Master Airscrew props. I wanted to work with fiberglass, maybe it is time to check that one off on my todo list.
Thanks for sharing.
Edited: Looking at this picture, I am sure I can make this duct adaptable to my present bicopter.
Old Jul 02, 2012, 04:03 PM
jy0933 is offline
James not bond
jy0933's Avatar
Joined May 2012
well
mounting is not really a problem
we can just cut it from foam just like the ones for AR
foam is light weight. easy to obtain. and you can cut it in one part with fc protector...
Old Jul 02, 2012, 04:04 PM
Quad lover.
Joined Dec 2011
well
foam light weight.. and you can cut it in one part with fc protector...
Yes but I was thinking about people who already have multirotors. We need a solution that people can add to their existing fleet.
Joined Aug 2009
The foam has to be ridged enough to withstand an impact, that is why I am not using foam now.
Old Jul 02, 2012, 04:09 PM
MCrites is offline
Find More Posts by MCrites
I never finish anyth
United States, TX, Houston
Joined Jan 2012
Added weight = less efficient. Plain and simple.
The simplest way to be safe is to not fly near people. Also know your limits, both mechanical and skill.
MCrites is offline Find More Posts by MCrites
Old Jul 02, 2012, 04:12 PM
jy0933 is offline
James not bond
jy0933's Avatar
Joined May 2012
enhance it with some strong plastic ring... cut the ring from button of prot and implant it...
cf is the best.. but customization cost a lot..
the best efficient comes where the load matches the output (correct me, i might be wrong).. the lighter is always better but the weight of the prot wont even be 10% of your batt weight... which is not a big contribution
yes and no for the 2nd part.... not to fly near ppl.. but accident happens sometimes just not a human error.. like rim said... you can never prep for that/see that coming
Quad lover.
Joined Dec 2011
Actually in some areas of throttle, ducted fans can increase efficiency.
For Sale HK Stinger ducted fan Vacaville CA ecoliburger Aircraft - Electric - Jets (FS/W) 0 Jun 11, 2012 03:20 PM
Question Are there any efficient ducted fan motors ? Dennis Everett Power Systems 13 Apr 20, 2010 06:26 AM
Discussion Efficiency of a ducted fan Texas Buzzard Electric Ducted Fan Jet Talk 19 Feb 02, 2008 01:32 PM
I am a bit confused about ducted fan efficiency der Oberflügel Electric Ducted Fan Jet Talk 8 Sep 03, 2005 01:56 PM
