Old Jul 02, 2012, 11:06 AM
hawleaboy is online now
Find More Posts by hawleaboy
USA, CA, San Diego
Joined Feb 2001
A60 motor shaft broke on bench?
Hi guys,
I thought I'd reach out for some assistance and advice.
I just woke up to find a problem with my new Hacker A60 18L, just installed in a ESM pilatus PC21. (It sat in the box for 8 months while I've been building.) Now I'm worried.
I ran it up on sat night (12s, 5200 lipos and a castle HV120), then removed the prop to re-install the cowl. after re-installed the prop I put the the fuselage back on the workbench and woke up to find this. Literally, the prop was on the bench and had fallen off in the middle of the night!
Only put 56A/2300w in it for 2 minutes as a test. With a very expensive ( 5 bladed varioprop and spinner) setup- I'm a bit nervous.
Does you have any advice or a similar experiences? I don't think I over tightened the prop as the aluminum varioprop hub is in perfect condition.
hawleaboy is online now Find More Posts by hawleaboy
Old Jul 02, 2012, 08:01 PM
FL62 is offline
Find More Posts by FL62
Average Joe 2 Semi-Pro n Back!
FL62's Avatar
United States, AZ, Queen Creek
Joined Feb 2004
I am sorry to see this problem, although fortunately it happened on the bench, rather than in flight.
This is definitely a case of too much tightening, causing a fracture at the C-Clip groove. The tell-tale sign is the groove in the front plate of the motor from the c-clip. This happens when too much prop adapter clamping pressure is applied back against the clip, which deforms it and pushes it into the front plate when you run it.
Please send it in to us at Aero-Model, and we will replace the shaft, as well as make sure everything is cleaned up and fits together properly. An electric doesn't need as much tightening on the prop as a gas engine does!
If you have any questions, please PM me, or give me a call at the office (480) 726-7519
FL62 is offline Find More Posts by FL62
Old Jul 02, 2012, 08:08 PM
USA, CA, San Diego
Joined Feb 2001
Thanks Mike! I didn't think i was adding that much torque- I've had electrics for a while now (20 years) but I'm sure it's possible with such a large prop/plane (this size motor is new to me). I'll reach out to you tomorrow.
In the meantime is there a specified torque setting I should be using when setting the prop adapter?
Old Aug 15, 2012, 11:48 AM
aeromodel is offline
Find More Posts by aeromodel
Hacker Brushless USA
United States, AZ, Tempe
Joined May 2009
As a (late) update to this question.
Hacker sent over some torque specs on there larger motors:
A60: 15Nm
C50: 15Nm
Q80XS and S : 15Nm
Q80-M and L : 20Nm
I will also post this as a sticky at the top of this forum.
aeromodel is offline Find More Posts by aeromodel
Old Aug 16, 2012, 02:48 AM
USA, CA, San Diego
Joined Feb 2001
Thank you Mike! I appreciate the attention to detail in following up to my post and the fact that Hacker provided this great information!
This confirms one of the reasons I chose Hacker in the first place- quality, performance, parts and support. After investing so much time a project- details like this are critical to safety and success of a new project. This adds to my confidence in Hacker and aeromodel.
Discussion Motor shaft BROKE! 300HDX motor for HBFP/Compy Slyster Micro Helis 7 Jul 21, 2008 06:47 AM
Help! Shaft snapped off while on the bench!!?? finishman2000 Hitec/Multiplex USA 7 Jun 16, 2006 10:52 AM
Broke shaft on E FLite 400 mexico Power Systems 2 Jun 23, 2005 11:40 AM
Tail drive shaft broke on my Zoom Rudy Ackerman Mini Helis 4 Sep 26, 2004 05:19 PM
broke prop,saver and shaft on SS/motor options? richphoto Parkflyers 9 May 10, 2003 03:49 PM
