Old Jul 02, 2012, 11:02 AM
OuBallie is offline
Find More Posts by OuBallie
Joined Jan 2012
Dismantle Hoover motor (Filing machine)
Hello all,
The one that came with my Excel table top filing machine.
I'm stripping the machine as it's plastered with paint, and in any case, wish to check it over & give it a clean set of clothes.
Cannot find any reference number or any indication of model etc. on any of the castings or parts except the Excel name cast on the base.
The base dimensions:  370x260mm
I wish to dismantle the motor, again due to layers of paint, but not sure how to proceed, so need advise please.
The end bearing caps have what appear to be 'C' spanner slots on their circumferences.
Have got the long bolts out holding the end covers in place, but apart from the covers coming off of the case recesses, no further, hence my request.
Hope someone can help.
Motor details:
Aluminium frame.
Hoover A.C. Motor
Made in Scotland
Type: 738811BF1309C (the 11 could be an H)
Ser. No. 70379XJ
B.S. Frame (no details)
H.P. 1/2
PH. 1
R.P.M. 1425
Regards
Geoff - only 55% humidity, 80% last week!
Norfolk
OuBallie is offline Find More Posts by OuBallie
Old Jul 02, 2012, 01:26 PM
Bob Minchin
Bob Minchin
Guest
n/a Posts
Re: Dismantle Hoover motor (Filing machine)
OuBallie wrote:
> Hello all,
> circumferences.
> request.
> Motor details:
> Aluminium frame.
> Hoover A.C. Motor
> Made in Scotland
> Ser. No. 70379XJ
> H.P. 1/2
> PH. 1
> R.P.M. 1425
> Regards
> Norfolk
I would advise you not to proceed with this idea.
These motors are quite old now and the internal wiring gets very brittle
and the insulation can fall off.
The wires go between the central portion of the motor to the back of the
terminals in the rear cover. More wires go to the centrifugal switch and
all are vulnerable. Treat the motor as a single unit cleaning and
painting - if you must.
Bob
Old Jul 03, 2012, 03:48 AM
OuBallie is offline
Joined Jan 2012
Thanks Bob.
Will do as you suggest and leave well alone.
Was just worried about bits of paint getting into the works, but should be able to shake them out.
Been using Biostrip to get the paint off of the parts.
It works very well with no smell and best of all water based.
Will be using it on my Austin Seven soon.
Regards
Geoff
For Sale aj machine nitro/gas 30cc motor AdamG1180 Aircraft - Fuel - Engines and Accessories (FS/W) 1 Jul 06, 2012 09:39 AM
For Sale aj machine nitro/gas 30cc motor AdamG1180 Aircraft - Fuel - Engines and Accessories (FS/W) 1 Jun 21, 2012 11:49 AM
Sold Extremely rare Bridi "Bob Hoover" P-51 kit nero1156 Aircraft - Fuel - Airplanes (FS/W) 2 Apr 28, 2012 07:56 PM
Question Need a PDF File of a 6mm Motor Mount ? bombardierJay Foamies (Scratchbuilt) 0 Mar 03, 2012 02:48 PM
Sold LPU WI World Models P51 Hoover Colors with Motor ESC and servos planebldr Aircraft - Electric - Airplanes (FS/W) 10 Feb 04, 2012 10:16 AM
