Old Nov 07, 2012, 03:14 PM
pdawg is offline
Find More Posts by pdawg
Need 4 Speed!
pdawg's Avatar
United States, OH, Dayton
Joined Apr 2004
Hoeby,
Aerodynamic advantages are possible in the twin configuration...
pdawg is offline Find More Posts by pdawg
Old Nov 07, 2012, 05:49 PM
RCLurker is offline
Find More Posts by RCLurker
Joined Feb 2012
pdawg,
I doubt that efflux speed was a limiting factor in a J-58 in afterburner mode.
Just saying.
Now, back to my cave.
RCLurker is offline Find More Posts by RCLurker
Old Nov 07, 2012, 06:11 PM
pdawg is offline
Need 4 Speed!
pdawg's Avatar
Joined Apr 2004
Every design has limiting factors! Its all a compromise and lessons are learned after doing numerous speed airframes. The 25mm twin speed airframe design that Hoeby pasted into this thread was designed with fan efficiency in mind. These tiny fans have limited power so minimizing intakes and thrust tubes has a big advantage to maximize efficiency and top speed. This is a way to maximize efflux...not limit it. Long ducting and fans located in turbulent regions near the back of a fuselage are a great way to prevent a fan from reaching its peak potential. Once again...its all a compromise.
Old Nov 07, 2012, 06:42 PM
RCLurker is offline
Joined Feb 2012
I'm afraid my response was a bit vague.
I was merely echoing Erik v. Schaik's comment that efflux speed will be a limiting factor in the ultimate speed of an EDF, and with this in mind, gram for gram and watt for watt, a twin power plant will be less efficient than a larger single power plant.
That the fastest 1:1 jet was a twin has no bearing on what the fastest configuration for a small scale EDF would be. Efflux speed was not the limiting factor to the SR71's top speed.
Old Nov 07, 2012, 08:51 PM
pdawg is offline
Need 4 Speed!
pdawg's Avatar
Joined Apr 2004
Rclurker,
Your comments suggest you have not taken an airframe in to account? With a draggy airframe the efflux is no longer the limiting factor...drag is. While I would choose a large fan over a small one...given the choice I would happily use two large ones. Once again...it's all a compromise.
Old Nov 08, 2012, 04:50 AM
Hoeby is online now
Find More Posts by Hoeby
Holland
Joined Apr 2003
It is not only efflux what you need, also thrust.
Look at some of those turbine jets. The efflux of most turbines is almost the same.
When they put a 8 kilo thrust engine on a plane, and want to go faster they put a 16 kilo thrust turbine on it, and it goes faster. The efflux is almost the same.
Hoeby is online now Find More Posts by Hoeby
Old Nov 08, 2012, 09:25 PM
Rocketboy1030 is offline
Find More Posts by Rocketboy1030
Rocketboy1030's Avatar
Canada, ON, Mississauga
Joined Nov 2011
Okay , so is there any 'rule' or optimal calculation about the length of a thrust tube compared to FSA? What would be considered too long for a 70mm HET with an 80% exit nozzle?
Rocketboy1030 is offline Find More Posts by Rocketboy1030
Old Nov 09, 2012, 06:24 PM
Lt599 is offline
Find More Posts by Lt599
Lt599's Avatar
United States, WA, Shelton
Joined Feb 2012
I am no expert but I do know that when dealing with friction loss in fluid dynamics that the longer the run, or tube in this case the greater the friction loss experienced. By necking down the flow we increase velocity, hence the 85% FSA, however if we lengthen the tube we must increase power (thrust) to compensate for the friction loss to maintain exit velocity. It is very interesting
Lt599 is offline Find More Posts by Lt599
Old Nov 10, 2012, 06:34 AM
space 1 is online now
Find More Posts by space 1
USA
Joined Apr 2007
taper should be no more than 10deg so 70mm to 60mm you need to draw on paper to see what ever it come's out is what you need
space 1 is online now Find More Posts by space 1
Old Nov 10, 2012, 07:17 AM
Hoeby is online now
Holland
Joined Apr 2003
Isn't that only whit the inlet? To prevent air comming loose from the wall.
Old Nov 10, 2012, 10:18 AM
Erik v. Schaik is offline
Find More Posts by Erik v. Schaik
My project: FAIREY DELTA 1
Erik v. Schaik's Avatar
Uden Volkel, Netherlands
Joined Dec 2003
Nope, If the thurst tube is too short it is more likely you'll compress the air instead of increasing efflux. Fans do stall when air gets compressed thus efficiency will get bad.
Have a read in the sm110-52 manual. Great tutorial! My Fd1 has been designed around that manual. Note the vid shown here is made at very close distance from intake and thrusttube.
fearey delta1 testrun#1.MP4 (5 min 58 sec)
Erik v. Schaik is offline Find More Posts by Erik v. Schaik
Old Nov 13, 2012, 09:41 AM
scousethief is offline
Find More Posts by scousethief
scousethief's Avatar
United Kingdom, England, Redcar
Joined Jan 2006
What is that small twin ? is there a link to the thread please ?
ty
scousethief is offline Find More Posts by scousethief
Old Nov 13, 2012, 01:37 PM
pdawg is offline
Need 4 Speed!
pdawg's Avatar
Joined Apr 2004
Here you go. The airframe is currently in Australia getting a pair of custom built 25mm fans. The airframe and power system are both custom built strictly for speed. Looking forward to seeing how it performs with this new set of fans...rpms will exceed 100k. We expect this design to destroy the current 25mm edf speed record.
http://www.rcgroups.com/forums/showthread.php?t=1513465
Old Nov 13, 2012, 02:06 PM
Joined Jan 2006
Nice ty Pdawg
Old Nov 17, 2012, 09:59 AM
Hoeby is online now
Holland
Joined Apr 2003
I made the first steps for the twin design.
As whit the other design i first start in 2D. When the drawing is how it needs to be, i will converted it to 3D to see if everything fits where i thought it needs to go.
The design is based on the next setup.
2x wemotec minifan
2x HetRC 2W20
2x 4S1P 3000mAh
2x Brushless controller, robbe roxxy 80A
I also thought about changing the fan to a wemotec HW505. This is a 66mm minifan rotor. So efflux will be a little higher. Also about the motors i am not sure if they will be the 2W20. Maybe i switch to the 2W18. It is for sure, when i am going for the HW505, that the motors switch to 2W18.
The fuse will not be round, but square. This to get a tight fuse around the lipo's.
The lipo's are now projected on there site. But the lipo in front of the wing also can be routated. When doing that, it can move forward a few cm's (the get the CG right).
For the wing design, i took the wing of a pylon racer called zwoadrittl. Why?
I know where the CG is for this wing. And the wingprofile is also designed for speed.
What you guys think about the first design. Need to change something, otherwise i start to redraw it in 3D
( you guys think, why first in 2D and than in 3D. That's because i am not that good in 3d cad)
Discussion How do you guys feel about Nitroplanes? (The company) rckatz Nitro Planes 36 Nov 29, 2012 04:33 PM
Question Question about flying wing CG and how it might be affected by adding a fuse daronj Foamies (Scratchbuilt) 2 Jul 01, 2012 01:10 PM
Contest Hobby Lobby Lynx Speed Contest!!!! CONTINUED NEW Current top speed is 139.6 mph! dpowellmeii Pusher Prop Jet Models 7 May 21, 2012 11:52 AM
Rave How about a Tiger Moth gliding contest? swooper GWS (Grand Wing Servo) 3 Nov 08, 2003 03:09 PM
