Old Aug 11, 2012, 05:58 AM
space 1 is offline
Find More Posts by space 1
USA
Joined Apr 2007
slow
all most don 30'' wing 55mm fan
space 1 is offline Find More Posts by space 1
Old Sep 04, 2012, 04:59 PM
space 1 is offline
USA
Joined Apr 2007
done
done ready to fly 55mm 3500kv 1600 25c 14oz thrust 14oz auw battery little big 1300 be better
Old Sep 05, 2012, 10:19 AM
Erik v. Schaik is offline
Find More Posts by Erik v. Schaik
My project: FAIREY DELTA 1
Erik v. Schaik's Avatar
Uden Volkel, Netherlands
Joined Dec 2003
Looking fast!!
Last weekend I ordered a ds glider. should be fun bashing some edf oompf in it.
Erik v. Schaik is offline Find More Posts by Erik v. Schaik
Old Sep 05, 2012, 03:33 PM
space 1 is offline
USA
Joined Apr 2007
need more power bigger motor 3790 kv may work. Wing may be to small for auw. high stall speed ill see tomorrow
Old Sep 05, 2012, 03:36 PM
Joined Dec 2003
Ět is a delta concept. No stall
Old Sep 06, 2012, 05:30 AM
space 1 is offline
USA
Joined Apr 2007
more power
new fan set up. stall I just think it need's speed for take off. Not enough wing for hand launch need's speed to fly. I see to day
Old Sep 06, 2012, 02:09 PM
space 1 is offline
USA
Joined Apr 2007
will not fly
Old Sep 06, 2012, 02:51 PM
Joined Dec 2003
That's too bad!
Have you some more new ideas for a new project?
Erik
Old Sep 06, 2012, 05:20 PM
space 1 is offline
USA
Joined Apr 2007
may try again or little biger
Old Oct 03, 2012, 04:48 PM
space 1 is offline
USA
Joined Apr 2007
It fly's
got it to fly after some add on's looks good in air need to make bigger tail fins has wing wabble bad' fast down wind though auw 18.5 oz 30''in wing
Old Nov 06, 2012, 11:48 AM
Hoeby is online now
Find More Posts by Hoeby
Holland
Joined Apr 2003
Just did some thinking whit the tips posted in this thread.
i started whit this. But got the tip to look at the thrust line whit the wing-line.
I looked at it. But didn't got the look right. Just not that i would say, that's what i would like.
Got some design what looks like a mig15 whit a tale of the vampire (twin booms).
But it was not what i was looking for, not sexy enough.
The twin boom was not the thing where i was looking for, so need a single fuselage. But then the thruseline could be a problem. After looking in the micro edf sector, i found some pictures. Sorry for copying them to here, but like to know what you guys think about it, before starting the design of my own. not twin boom, but twin edf. And i like it, its sexy
It has a longer fuse, which those speed planes also have (like Erik tipped).
It could be build whit one pease wing, fuse needs a little tweek to get batteries in, but no big changes. Will be for twin 70mm.
Only disadvantage would be, that it needs twin 70mm. But for me is not a problem. Price will be almost the same as one 90mm 8S plane. But the twin setup has the advantage that thrustline is in line whit the wing.
Please post your thoughts about it. Like i said, the one disadvantage i could think about would be the twin setup which is needed. Other than that, i think only advantage. But please, think whit me.
Hoeby is online now Find More Posts by Hoeby
Old Nov 06, 2012, 11:52 AM
Hoeby is online now
Holland
Joined Apr 2003
And for me, i like 90mm planes. But for the speed the 70mm is better, because the higher exflux. Getting a twin 70mm, it could not be that small as the uriah, as Erik designed. Also think it is easier to build, not a pain in the @ss as the uriah was
Old Nov 06, 2012, 04:20 PM
Joined Dec 2003
Hi Hoeby,
1st of all, I like to read you have still good thoughts for high speed edf!
For high speed, I doubt that a twin would be the ticket because of additional weight of anextra drive train. On the other hand, you could reduce thrust tube dia to gain efflux.
Perhaps you could redesign the A10 for high speed. At VTH you can order the Heino dittmar drawings for sp400. There would be good space in the fuse for cells. For simplicity you could make a straight wing. even a clipped wing Reno style wouldlook nice.
nacelles positioned like on my Jetmach60 will have minimal wiring:
I even converted a sig King Kobra "Hammerhead shark" style.
If you really like simplicity you need to build a turbine Cri-cri. It took me 4 years to fine a decent 3-view to work with but never found a good route to pull the canopy.
http://airtoimedia.nl/web/upload/Emi...28sept2008.wmv
Old Nov 06, 2012, 11:41 PM
Hoeby is online now
Holland
Joined Apr 2003
Originally Posted by Erik v. Schaik View Post
Hi Hoeby,
The extra drive train is not just dead weight , like putting in a big battery which is not needed. It is extra weight , but the fan pushes it own weight and extra.
Old Nov 07, 2012, 03:02 PM
Joined Dec 2003
I don't think you will have a record breaker with twins. You double the thrust (=acceleration), not the efflux speed which makes a twin low efficient in high speed perspective.
Discussion How do you guys feel about Nitroplanes? (The company) rckatz Nitro Planes 36 Nov 29, 2012 04:33 PM
Question Question about flying wing CG and how it might be affected by adding a fuse daronj Foamies (Scratchbuilt) 2 Jul 01, 2012 01:10 PM
Contest Hobby Lobby Lynx Speed Contest!!!! CONTINUED NEW Current top speed is 139.6 mph! dpowellmeii Pusher Prop Jet Models 7 May 21, 2012 11:52 AM
Rave How about a Tiger Moth gliding contest? swooper GWS (Grand Wing Servo) 3 Nov 08, 2003 03:09 PM
