Old Aug 31, 2012, 07:20 PM
blueprint is offline
Find More Posts by blueprint
FPV Pilot
blueprint's Avatar
Joined Sep 2007
Holy crap the black tape on the naza side worked for me. I thought this was crazy lol. My altitude issues in yaw have disappeared.
blueprint is offline Find More Posts by blueprint
Old Aug 31, 2012, 07:28 PM
Xnaron is offline
Find More Posts by Xnaron
Xnaron's Avatar
Joined Feb 2003
Well I am glad this thread has helped people out. I have 4 nazas now and they are all covered. I haven't experienced any further issues with altitude drops since covering them.
Xnaron is offline Find More Posts by Xnaron
Old Aug 31, 2012, 09:41 PM
imagebuff is offline
Find More Posts by imagebuff
imagebuff's Avatar
United States, TX, Tomball
Joined Jan 2011
Can you just tape up the whole left side or do you have to be concerned about airflow into the naza's baro? I'm not sure where there is an air port in the case or not.
imagebuff is offline Find More Posts by imagebuff
Old Sep 01, 2012, 11:50 AM
FPV Pilot
blueprint's Avatar
Joined Sep 2007
Thanks for the tip!
Old Sep 02, 2012, 09:07 PM
marcelog is offline
Find More Posts by marcelog
marcelog's Avatar
Australia, QLD, Brisbane
Joined Oct 2011
Some months ago, I noticed that when covered, the naza keeps the altitude better, not only on yawing, but hovering either, but i thought it was because of the windy hitting the nazathat wasn't perfectly sealed, not the sun!
marcelog is offline Find More Posts by marcelog
Old Sep 02, 2012, 10:59 PM
SCVJeff is offline
Find More Posts by SCVJeff
Joined Mar 2009
Same issue here. I posted this problem today, so it's not all me. This is not a sun/ raidiant heat problem as it drops the same at 10PM as at 1
SCVJeff is offline Find More Posts by SCVJeff
Old Sep 03, 2012, 03:29 AM
pbw is offline
pbw
Find More Posts by pbw
pbw
arachnida
pbw's Avatar
Belgium, Flanders, Antwerp
Joined Aug 2008
My NAZA is now on a QAV500 frame and I sticked my Rx on the left side of the NAZA box. Flys great! Please send me some sunshine!
pbw is offline Find More Posts by pbw
Old Sep 03, 2012, 03:32 AM
pbw is offline
pbw
pbw
arachnida
pbw's Avatar
Joined Aug 2008
Originally Posted by NinjaRobot View Post
Hi folks,
I am assuming that its not the sun light but more the heat changing the micro environment of the Naza unit and affecting what the Baro is detecting. does that sound right?
-NinjaRobot
Once more for the non believers, it is bright (sun)light that affects the baro, not heat! I assume heat will also have an effect on a baro, but not way as much as light.
Old Sep 03, 2012, 05:35 PM
SCVJeff is offline
Joined Mar 2009
Well, I'll revise what I said... It happens the same at 10PM as it does at 1:00... WHEN I HAVE A 300w SPOT ON IT!!
Covered the left side of the FC and problem gone! in fact on a hard 100% R or L Yaw, it actually climbs a few inches.
Xnaron: How did you stumble across this?
Old Sep 04, 2012, 04:26 PM
The Recursion is online now
Find More Posts by The Recursion
q {bld(); fly(); brk(); q();}
The Recursion's Avatar
Canada, ON, Mississauga
Joined May 2012
I have the entire top/sides taped up with electrical tape, with no ill effect.
The Recursion is online now Find More Posts by The Recursion
Old Sep 11, 2012, 08:52 AM
Kloner is offline
Find More Posts by Kloner
Aerial DP
United States, CA, Lakeside
Joined Apr 2010
a closeup video of it happening
you can see the little white box in the middle of the frame on the bottom pate. the first 15 seconds was manual, then i yawed into the light, you see the box light up like a bulb and it falls like a rock
naza sun on the barometer bit (1 min 14 sec)
that's not me landing it,,,
Kloner is offline Find More Posts by Kloner
Old Sep 12, 2012, 05:25 AM
dennyrowland@mac is offline
Find More Posts by dennyrowland@mac
Joined Aug 2005
I have seen this and thought about another reason why this may be happening. The Naza does not have a vent hole. It relies on the fact that the case is not a sealed unit. Seems pretty much sealed to me, and thus temperature sensitive in the extreme. So I took it apart and found a good place to drill a very small hole on each side of the top case. Since I did this I have not had any problems.
dennyrowland@mac is offline Find More Posts by dennyrowland@mac
Old Sep 12, 2012, 07:06 AM
brettskermetzger is offline
Find More Posts by brettskermetzger
United States, KY, Cold Spring
Joined Jul 2012
Is it possible street lights could give the same effect? I've been trying to trouble shoot a problem with my quad dropping in forward flight when the throttle is at 50%
I have been messing with gains, batteries, props, and still nothing has worked...I came across this post yesterday while searching the multirotor forums...I don't remember my quad specifically falling when yawing, it's mainly when im in forward flight.
Thanks!
brettskermetzger is offline Find More Posts by brettskermetzger
Old Sep 12, 2012, 09:10 AM
Xnaron is offline
Xnaron's Avatar
Joined Feb 2003
In my opinion its not a good idea to drill extra holes in the case. Barometers are very sensitive to wind. The best solution is just to tape the left side with electrical tape.
It is a fact that barometer sensors are sensitive to light. Look at page 25 of this document http://www.bosch-sensortec.com/conte...5-DS000-05.pdf
This is a common pressure sensor used on may multirotor controller boards.
Old Sep 12, 2012, 09:27 AM
Joined Jul 2012
What about the LEDs that are inside of the naza case? Can those have an effect to?
Build Log Talon Hexa 625 with NAZA GPS and Arris CM2000 Brushless Gimbal chuenwe Multirotor Talk 227 Feb 13, 2014 09:41 AM
Discussion How do I show MSL GPS altitude on OSD Pro? bleakandobscure Eagle Tree Systems 12 Oct 03, 2012 01:32 PM
Question NAZA's GPS add on. Need help! Please- Genetics101 FPV Talk 4 Jul 05, 2012 03:18 PM
Sold PRICE DROP!!! FY-91Q Like New Navigation Ed. GPS Altitude and Position Hold. $300 NYPD0524 Aircraft - Electric - Multirotor (FS/W) 2 May 28, 2012 10:49 PM
Discussion YAW overshoot, altitude loss while yawing, GPS oddities cicadafx Hoverfly Technologies 9 Oct 27, 2011 10:22 AM
