Old Oct 13, 2012, 05:10 PM
PittSpecial is online now
Find More Posts by PittSpecial
Right Rudder
PittSpecial's Avatar
USA, FL, Orlando
Joined Nov 2010
PittSpecial is online now Find More Posts by PittSpecial
Old Oct 13, 2012, 07:44 PM
trumps is offline
Find More Posts by trumps
What's 3D?
trumps's Avatar
Australia, WA, Ellenbrook
Joined Feb 2008
You really ought to build something your self before making demands on those that are working on their own projects.
Craig
trumps is offline Find More Posts by trumps
Old Oct 14, 2012, 04:40 AM
trumps is offline
What's 3D?
trumps's Avatar
Joined Feb 2008
Have been quietly lurking, cool project bud! What is your estimated flying weight at this point of the build?
Cheers
Craig
Old Oct 23, 2012, 07:29 AM
Marked is online now
Find More Posts by Marked
Marked's Avatar
United States, FL, Titusville
Joined Jan 2001
Got the wings mostly done....now have to figure out the attach fittings
Marked is online now Find More Posts by Marked
Old Oct 23, 2012, 07:46 AM
Marked's Avatar
Joined Jan 2001
Here is the test wing panel..I have to make sure the C/G is correct,so I am moving the wing back a little. My work on the tail added 3/4 oz to the back of the plane,not helping the balance any
Having to figure out how to do the unconventional is taxing....1/4 of my build time or more is trying to work out problems. The wing has been challenging.
BTW...I have scratch built 60+ planes from plans,all balsa. That has helped a little,maybe my age is catching up. Should hve been done by now...or so I think...
Old Oct 23, 2012, 08:57 AM
Deuce is offline
Find More Posts by Deuce
Übung macht den Meister..
Deuce's Avatar
United States, OR, Fairview
Joined Jul 2006
But wouldn't it be boring otherwise?
James
Deuce is offline Find More Posts by Deuce
Old Oct 23, 2012, 09:04 AM
Marked's Avatar
Joined Jan 2001
Cheers
Craig
I weighed it,less wings, and it came out to 22oz with battery and all other things to make it fly. Wings will be about 13oz for the pair
Old Oct 24, 2012, 04:58 PM
Marked's Avatar
Joined Jan 2001
The rear attach points are finally aligned and on the frame...still a little off,but not enough to cause any problems.
top view....looks like a plane finally.
I had to beef up the inboard wing rib,since it would be supported by the aft point all the time. Didnt think the balsa rib would take much abuse.
I went through several ways to do this,decided to sleeve the ends so I dont have to make 1 piece and drill both ends perfectly. .....When both sides are aligned,then I can solder the ends in place. Makes it easier to keep both wings at the same angle. Keep in mind,they are independent of each other,making the process a pain in the
Old Oct 24, 2012, 06:58 PM
trumps is offline
What's 3D?
trumps's Avatar
Joined Feb 2008
very nice work mate, love these design on the fly builds, they bring out the inventive spirit!
Cheers
Craig
Old Oct 24, 2012, 08:48 PM
Greg D is offline
Find More Posts by Greg D
Aircraft Part Separator
Greg D's Avatar
United States, IA, Tabor
Joined Aug 2003
I used to fly Ultralights,
T-Bird single seat, T-Bird TBT (tandem 2 seat), and a Quicksilver!
Always wanted an Airbike.
VERY COOL project!!!!!
Greg D is offline Find More Posts by Greg D
Old Oct 24, 2012, 11:13 PM
Marked's Avatar
Joined Jan 2001
The Quicksilver weight shift was my first ultralight..taught myself how to fly it. Had that before I had a car...in 1982...
Old Oct 26, 2012, 06:13 PM
Marked's Avatar
Joined Jan 2001
A long day of getting the struts and upper attach points done. Hurricane Sandy discouraged any flying
testing the upper fitting,used a brass tube inside the strut,slit and drilled to fit the wing fitting.
The lower fitting was a steel wire with a Z bend to the fuse frame. Used 5 layer ply sanded to fit inside the strut. The other end has a 90 bent into the wood and glued.
Fittings were tight and glued in place after everything was aligned. I then drilled and bolted each fitting with 2 screws. Dont think it will break easily..
Old Oct 26, 2012, 09:22 PM
Marked's Avatar
Joined Jan 2001
Cheers
Craig
I weighed everything it would need to fly,39oz 540 sq/in wing area...10.5 oz/sqft loading
Old Oct 26, 2012, 09:48 PM
trumps is offline
What's 3D?
trumps's Avatar
Joined Feb 2008
Very good, a floater at that wingloading, hope you can get enough weight forward so as to not need any ballast.
Cheers
Craig
Old Oct 26, 2012, 10:29 PM
simano is offline
Find More Posts by simano
Jungmeister 55
simano's Avatar
Orlando Herndon, Florida, United States
Joined Sep 2002
Mark,
I finally got to look at the thread...wow...it looks amazing!!
I really like the level of detail you're putting into it so far. It is a lot of work but well worth the effort at the end!!.
Gerry.
simano is offline Find More Posts by simano
Build Log Peter Rake 1/6 scale Fokker DR.I build hammerd Scale Kit/Scratch Built 367 Oct 28, 2015 11:54 PM
Discussion 1/6 scale WW2 pilots coming soon! Need input from you guys! helifann Fuel Warbirds 6 Jun 30, 2012 07:02 PM
Sold FW190 D-9 1/6 scale needacheaphobby Aircraft - Fuel - Airplanes (FS/W) 3 Jun 27, 2012 10:30 PM
Sold Pilot 1 Waco YKS-6 1/8th Scale 400xp Aircraft - Electric - Airplanes (FS/W) 4 Jun 20, 2012 08:06 AM
Sold Sig 1/4 scale Spacewalker,Pica 1/6 scale Spitfire joedoan Aircraft - Fuel - Airplanes (FS/W) 2 Jun 02, 2012 11:45 PM
