Old Aug 27, 2012, 07:40 PM
PittSpecial is online now
Find More Posts by PittSpecial
Right Rudder
PittSpecial's Avatar
USA, FL, Orlando
Joined Nov 2010
PittSpecial is online now Find More Posts by PittSpecial
Old Aug 31, 2012, 09:52 PM
Marked is offline
Find More Posts by Marked
Marked's Avatar
United States, FL, Titusville
Joined Jan 2001
WELL....I hope this doesnt look too goofy looking.....
I had to make the motor look sort of real,so I spent about 12 hours on this part..again ....never thought it takes this much time,but everything is scratch built...
The intake is made from 1/4" wood dowel ,exhaust is from a thin plastic container and some Plastistrut tubes.
I had to paint the motor to match,and added the end screens so the ESC will get some cooling(its hidden in the cylinder head area)
I used thin stiff wire to hold the intake and exhaust assemblies to the case,twisted inside and glued. Holds well.
Marked is offline Find More Posts by Marked
Old Sep 01, 2012, 05:12 AM
Right Rudder
USA, FL, Orlando
Joined Nov 2010
Old Sep 01, 2012, 09:01 AM
Deuce is offline
Find More Posts by Deuce
Übung macht den Meister..
Deuce's Avatar
United States, OR, Fairview
Joined Jul 2006
Not at all! Looks pretty damn spiffy!
One subject I'd like to model has an exposed engine that probably wouldn't be big enough to hide a motor, and your efforts have given me some inspiration.
James
Deuce is offline Find More Posts by Deuce
Old Sep 01, 2012, 04:22 PM
Marked is offline
Marked's Avatar
Joined Jan 2001
The first pictures have the real motor in view somewhat. I need to post pics of the cuyuna so you can see my attempt to copy it. Crude....but effective.
I just didn't want to stick an outrunner on the back and call it even. But I didn't think it would take this long just to make a dummy. I guess Williams brothers decided not to model the Cuyuna UL2.....
Old Sep 06, 2012, 09:03 PM
Marked is offline
Marked's Avatar
Joined Jan 2001
Here are 2 views of the real engine. Yeah...it looks used..and it is...287hrs in 3 years,getting my fun out of it
Old Sep 06, 2012, 10:48 PM
Deuce is offline
Deuce's Avatar
Joined Jul 2006
Despite the real thing using a belt drive, I think your approximation is pretty good for the purpose. Throw a couple hoses, pipes and wires stuck all over it and it'll look even better!
James
Old Sep 30, 2012, 05:12 PM
Marked is offline
Marked's Avatar
Joined Jan 2001
I added a few things..since you pressured me...added a coil and wires,may add a few more. Might even start the wings this week,been busy flying the real one
Old Oct 10, 2012, 09:10 PM
Marked is offline
Marked's Avatar
Joined Jan 2001
Well.....I finally got around to the wings. I have both sides done.
Old Oct 10, 2012, 10:36 PM
Deuce is offline
Deuce's Avatar
Joined Jul 2006
Structure looks pretty lightweight. Are the spars spruce?
James
Old Oct 11, 2012, 07:28 AM
Marked is offline
Marked's Avatar
Joined Jan 2001
Spruce spars,,,probably could have used hard balsa. As a result,it is a little heavier than I wanted. I still have to add a few braces,and figure out how to do the wingtip.
Old Oct 11, 2012, 12:08 PM
Right Rudder
USA, FL, Orlando
Joined Nov 2010
Old Oct 11, 2012, 10:29 PM
Marked is offline
Marked's Avatar
Joined Jan 2001
Originally Posted by PittSpecial View Post
What? No Ailerons?
They are added to the wing trailing edge after covering. They are not built into the wing.
Old Oct 13, 2012, 03:32 PM
Right Rudder
USA, FL, Orlando
Joined Nov 2010
Old Oct 13, 2012, 03:40 PM
Marked is offline
Marked's Avatar
Joined Jan 2001
I will wait for better weather ..even if it means waiting an extra month or two. I have too much time in this to be in a hurry to fly. I still have a long way to go....lot of fitting of the wing folding mechanisms..may have to re do the ones i have.
Build Log Peter Rake 1/6 scale Fokker DR.I build hammerd Scale Kit/Scratch Built 367 Oct 28, 2015 11:54 PM
Discussion 1/6 scale WW2 pilots coming soon! Need input from you guys! helifann Fuel Warbirds 6 Jun 30, 2012 07:02 PM
Sold FW190 D-9 1/6 scale needacheaphobby Aircraft - Fuel - Airplanes (FS/W) 3 Jun 27, 2012 10:30 PM
Sold Pilot 1 Waco YKS-6 1/8th Scale 400xp Aircraft - Electric - Airplanes (FS/W) 4 Jun 20, 2012 08:06 AM
Sold Sig 1/4 scale Spacewalker,Pica 1/6 scale Spitfire joedoan Aircraft - Fuel - Airplanes (FS/W) 2 Jun 02, 2012 11:45 PM
