Old Jul 06, 2012, 10:19 AM
PittSpecial is offline
Find More Posts by PittSpecial
Right Rudder
PittSpecial's Avatar
USA, FL, Orlando
Joined Nov 2010
PittSpecial is offline Find More Posts by PittSpecial
Old Jul 08, 2012, 05:35 PM
Marked is offline
Find More Posts by Marked
Marked's Avatar
United States, FL, Titusville
Joined Jan 2001
Here is a close up of the real frame,,,I am not going to make the controls move...too much work
Here is the almost finished gear....more to go
Marked is offline Find More Posts by Marked
Old Jul 11, 2012, 03:04 PM
Marked is offline
Marked's Avatar
Joined Jan 2001
The elevator pivot/attach point is slid into place,second pic its installed.The pull-pull cables will keep it in place.
The vertical stab/tailwheel support. The original on both mechanisms is on the inside of the tube,I didnt want to make it that small,so everything is outside.
All controls ans surfaces,along with the rear pivot/attach points are removable,like the full size one.
Old Jul 12, 2012, 07:26 AM
Keenan smith is offline
Find More Posts by Keenan smith
was geht , müssen unten kommen
Keenan smith's Avatar
United Kingdom, London
Joined Dec 2010
subbed big time!
Keenan smith is offline Find More Posts by Keenan smith
Old Jul 12, 2012, 09:04 AM
Right Rudder
USA, FL, Orlando
Joined Nov 2010
Very nice work Mark!
Can't wait to see it in the air!
Old Jul 12, 2012, 09:08 AM
Marked is offline
Marked's Avatar
Joined Jan 2001
Here is my attempts to make the wing folding mechanism. Will change out the wood joint for a better laminated piece.
Old Jul 14, 2012, 01:44 PM
Marked is offline
Marked's Avatar
Joined Jan 2001
I took dimensions from the seat in the plane...the base is 3/16 balsa,the curved back is thin roofing aluminum. I was trying to figure out something for the edge...any suggestions? How about cushions?
Old Jul 15, 2012, 08:16 AM
Right Rudder
USA, FL, Orlando
Joined Nov 2010
Old Jul 15, 2012, 06:01 PM
Marked is offline
Marked's Avatar
Joined Jan 2001
Tail surfaces are done,I still have to fit the folding hinge pins and the surface hinges....THEN interface it with the fuselage,and have it work
The brass square at the top of the stab is where the flying wire attach bolt goes thru...probably overkill....
Old Jul 19, 2012, 05:17 PM
Marked is offline
Marked's Avatar
Joined Jan 2001
I've been working on the vertical stab and rudder. Again,the fittings from brass,scaled close to the original. No folding requirement,the horizontal surfaces are the only part that folds up.
These have been apart and together dozens of times to assure a proper fit. Some fittings needed modification or replaced.
Old Jul 23, 2012, 02:46 PM
Marked is offline
Marked's Avatar
Joined Jan 2001
Here is the horizontal stab/elevator in a folding test. A little tweaking will be in order because SOMETHING is always not lined up
Old Jul 24, 2012, 03:33 PM
Marked is offline
Marked's Avatar
Joined Jan 2001
Covered the tail surfaces..they need some shrinking. Covering is my least favorite thing in modeling,I would build a lot more if Monocote wasnt involved
Hid the servos as best as I could. Cut up several old fuel tanks to see which would fit the best. I may use the other end since it doesnt have the hole in top,or may run ESC wires out to look like fuel lines. Seems like I bolted everything together,not much is glued except the basic frame.
Old Jul 30, 2012, 10:46 PM
Marked is offline
Marked's Avatar
Joined Jan 2001
Tail sort of complete...folded and unfolded
I have been re-doing a lot of small items,had to re do ALL the crimps on the tail and controls. I didnt have the proper tool..I.DO NOW
Old Jul 30, 2012, 11:07 PM
Robert R is online now
Find More Posts by Robert R
It's a fine fiddly business.
Robert R's Avatar
United States, WA, Marysville
Joined May 2009
Nice progress.
Robert R is online now Find More Posts by Robert R
Latest blog entry: Hidden Kit Built Projects
Old Jul 30, 2012, 11:20 PM
challenger_i is offline
Find More Posts by challenger_i
OCD: Old, Cranky and Disgusted
challenger_i's Avatar
United States, TX, Fisher County
Joined Mar 2005
I'm watching this, closely!
I have had the pleasure of flying an Ultra Star, and have an untouched
kit waiting for me to pick up, in Tennessee, once I get the chance.
I have been tempted to build a 1/3 scale model, using an AXI 4130, and
a belt drive.
challenger_i is offline Find More Posts by challenger_i
Build Log Peter Rake 1/6 scale Fokker DR.I build hammerd Scale Kit/Scratch Built 367 Oct 29, 2015 12:54 AM
Discussion 1/6 scale WW2 pilots coming soon! Need input from you guys! helifann Fuel Warbirds 6 Jun 30, 2012 08:02 PM
Sold FW190 D-9 1/6 scale needacheaphobby Aircraft - Fuel - Airplanes (FS/W) 3 Jun 27, 2012 11:30 PM
Sold Pilot 1 Waco YKS-6 1/8th Scale 400xp Aircraft - Electric - Airplanes (FS/W) 4 Jun 20, 2012 09:06 AM
Sold Sig 1/4 scale Spacewalker,Pica 1/6 scale Spitfire joedoan Aircraft - Fuel - Airplanes (FS/W) 2 Jun 03, 2012 12:45 AM
