Old Jul 01, 2012, 12:03 PM
alioth is offline
Find More Posts by alioth
Joined Jun 2012
Apogee
Im new in HLGs.
I saw ELF and like it very much. But I knew that it was an update from Mark Drela's Apogee.
So I thougt I could build an Apogee, and if I like it, buy and more complex 1.5m ship later.
Info link http://www.charlesriverrc.org/articl..._apogeehlg.htm
carbon capstrips and trailing edge
It wants to fly!
Lipo 2S 240milis. rx 6004 futaba. servos dymond d47
weight. 110grm. Im happy
Tomorrow it will fly (or not..)
alioth is offline Find More Posts by alioth
Old Jul 01, 2012, 12:43 PM
bwill6 is offline
Find More Posts by bwill6
United States, CA, Tehachapi
Joined Jun 2011
Nice! That's completely from scratch? It looks awesome! And 110g is very good for a first attempt. My first micro hand launch came in at about 145g.
bwill6 is offline Find More Posts by bwill6
Old Jul 02, 2012, 11:50 AM
alioth is offline
Joined Jun 2012
Yes, from scratch!
Im uploading a youtube vid with the maiden flight today!
It flies very very well! Im very happy!
A member has asked me about the ribs plans. I made my own wing plans in AutoCad. Airfoil Ag03, and top view of the wing in two parts. I have them in PDF. Print in A4 and join later.
Here it is.
Old Jul 02, 2012, 01:04 PM
alioth is offline
Joined Jun 2012
Here it is the vid!
Apogee DLG (4 min 23 sec)
Old Jul 02, 2012, 09:54 PM
skorski is offline
Find More Posts by skorski
No conspiracy in theory
skorski's Avatar
Oak Ridge, Tenn.
Joined Aug 2004
A good day!
Looks like you had fun!
Mike.
skorski is offline Find More Posts by skorski
Old Jul 02, 2012, 10:34 PM
bwill6 is offline
Joined Jun 2011
Looks like it flies great! Congrats on a successful maiden! A subfin would help a ton with the tendency to roll on launch and you'd get much higher, but it would add weight too. It looks like a blast to fly though! Good work!
Old Jul 04, 2012, 01:38 AM
Edwinzea is offline
Find More Posts by Edwinzea
the answer 42 is
Switzerland, AG, Lenzburg
Joined Jan 2006
MArco it flights great, and again you brake all the DLG rules :P (just kidding) in theory one could not launch a V tail plane DLG but you did it. The apogee was actually designed before the DLG era, so it is in fact a HLG or javelin launched glider.
You are tot the first one thought if you take a look on the "bring the bug back" thread some guy is also doing it.
For better launches you could make a standard DLG tail with sub fin
regards
EZ
Edwinzea is offline Find More Posts by Edwinzea
Old Jul 04, 2012, 05:10 AM
krisch is offline
Find More Posts by krisch
Hamilton New Zealand
Joined Apr 2005
Hi Alioth does your wing have a solid leading edge/dbox???
Chris
krisch is offline Find More Posts by krisch
Old Jul 04, 2012, 05:22 AM
orrinade is offline
Find More Posts by orrinade
Joined Nov 2010
Gents,
I've seen someone using a x tail where it works like a v-tail but is extended below to form a x-tail, and it launched well and has the benefits of a v-tail.
The control surface was done either above or below the boom.
Regards,
Oz
orrinade is offline Find More Posts by orrinade
Old Jul 04, 2012, 06:13 AM
alioth is offline
Joined Jun 2012
Chris
Yes. "dbox" is very light solid balsa. Leading edge is made with a 2mm harder strip balsa. Carbon spar 10x0.5mm
Old Jul 04, 2012, 06:24 AM
daveagain is offline
Find More Posts by daveagain
Joined Mar 2012
Looks great! Just curious though, how many times did you glue your fingers to the ribs putting on those carbon cap strips?
daveagain is offline Find More Posts by daveagain
Old Jul 04, 2012, 06:31 AM
alioth is offline
Joined Jun 2012
At first, twice per rib
Later... with a lot more of practice, only once
Old Jul 04, 2012, 08:19 AM
marctrudeau is offline
Find More Posts by marctrudeau
West Boylston, MA
Joined Feb 2003
regards
EZ
As I recall, Mark Drela's Apogee was a tip-launch (underhand) design, more like DLG than javelin. Could check on the CharlesRiverRC.org site, but I'm almost certain.
Marc
marctrudeau is offline Find More Posts by marctrudeau
Old Jul 04, 2012, 09:22 AM
Joined Mar 2012
Marc
I just looked again yesterday at the plans. It had a built-in finger notch on the bottom of the fuse.
Old Jul 04, 2012, 10:43 AM
alioth is offline
Joined Jun 2012
As I know reading apogee article, first it was developed as a javelin HLG.
This is why There is a finger notch.
Here it is the standard (javelin) 40" Molded Apogee Plan http://www.charlesriverrc.org/articl...e40_molded.pdf
Here it is the Tip Launch Rated http://www.charlesriverrc.org/articl...apogee40Mb.pdf
Diference is about wing spar. But same fuselage and tail.
Later.. it was developed an "squat fuselage" and it says "Why a "squat fuselage"? There were basically two reasons for developing the squat fuselage design. The first is that the finger hole can be much more spacious, which is an advantage if you have "significant fingertips" The second is that it takes the side loads of tip-launch better. Now you know!"
So.. It is a fuselage than can be used for javelin version (this is the reason of the finger hole), or tip launch version of the wing.
But tail, is the same in both versions..
