Old Jul 01, 2012, 11:49 AM
Goanna is offline
Find More Posts by Goanna
United States, NY, New York
Joined Oct 2006
Heavy Lift xAircraft Hexacopter in-flight video
So I finally got some video of my xAircraft powered heavy lifter in flight. Video is from a panasonic HDC-SD9 1080p camcorder mounted on the x468HD frame/gimbal.
Keyport NJ Radio Control Hexacopter Flight by Waterfront (5 min 20 sec)
My observations from this test flight:
  • Camera gains still need adjusting, camera is not leveling quick enough.
  • Altitude hold also needs gain adjustment. craft seems to bob up and down a good 4-5 ft in altititude hold mode.
  • Although not shown in this video, I did try Carefree mode, which worked very well
  • Heading lock mode also works very well
  • GPS Hold seems to work for a little while when first initialized but then the craft begins to wander and climb. Still have to address this.
I will be updating firmware tonight and replacing all my blades with new, balanced ones as a few are a bit beat up now from some tip-overs on asphalt . Should be able to mess around with it some more on the 4th
Goanna is offline Find More Posts by Goanna
Site Sponsor
Discussion My heavy-Lift HexaCopter kapteinkuk Multirotor Talk 110 Jan 01, 2015 04:36 AM
Build Log DAC-1 Build Log: Heavy Lift Hexacopter for AP/FPV, *VIDEOS Grips Multirotor Talk 322 Nov 29, 2013 03:04 AM
Discussion HEXA SUPER HEAVY LIFT TESTING Video! - Maiden flight, 10lb payload test & GPS PH wac Multirotor Talk 23 Oct 15, 2012 07:34 PM
Discussion EDIT: Finished my Heavy Lift xAircraft based Hexacopter! Goanna Multirotor Talk 10 May 04, 2012 01:28 PM
Discussion Aerial Video of kayaking and motocross - Heavy lift hexacopter wac Multirotor Talk 7 Jun 18, 2011 05:07 AM
