Old Jul 01, 2012, 11:35 AM
webgeek is offline
Find More Posts by webgeek
Joined Sep 2004
Steampunk Quad Copter Build
I'm making a new show copter along with my amazing modeler father. After a fair bit of research, we decided to go with a steampunk airship theme. The design will be based on two pictures we liked and felt were most achievable. This first image from Final Fantasy shows the basic idea for propulsion:
Ignore the deck props, we will be skipping those in favor of some elements from this next image:
Specifically, we are going to put a boiler + smokestack arrangement on the deck along with some lines to hold some sun shade "tent" type covering to add detail.
The main hull of the ship is from this model:
This ship is actually a rip off of the Black Pearl from Pirates of the Caribbean - in fact this same company has a Black Pearl model that's identical with a different figurehead. Here is someone else's standard hull image in progress to see what it looks like plain:
Here is how the interior hull looks from someone elses build:
The current plan for hardware is this:
HobbyKing v3 KKMulticopter Board in x4 mode
DT-750 Motors (cause I have a ton already)
Turnigy Plush 30 Amp Speed Controllers
APC 10x4.7 SF props
Actually mounting things is going to be tricky. The ship has it's lower hull, then a gun deck, then the main deck. The battery will have to sit above the flight controller and receiver but below the main deck. Both the gun deck and main deck will have to have removable access panels to access components. I really don't want to make it so no parts can be replaced. The biggest problem right now is that it looks like the arm supports for the motors might actually have to be built in-place into the hull. Better not have a bad crash
Anyways, I figure I could get away with posting this as we've already started putting things together. I'll keep this updated as I go as well. Thanks!
-Mike
Updates
07/03/2012 - Turbine and fin landing gear
http://www.rcgroups.com/forums/showp...8&postcount=20
webgeek is offline Find More Posts by webgeek
Old Jul 01, 2012, 11:46 AM
Balr14 is online now
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
Cool! Steampunk stuff is awesome. Looking forward to seeing this.
Balr14 is online now Find More Posts by Balr14
Old Jul 01, 2012, 03:12 PM
heli-yeah is offline
Find More Posts by heli-yeah
Flying Monkey
heli-yeah's Avatar
Lexington, KY
Joined Aug 2010
You are a Genius, I love it!
Can't wait to see more!
heli-yeah is offline Find More Posts by heli-yeah
Old Jul 01, 2012, 03:36 PM
dutchcommando is offline
Find More Posts by dutchcommando
making crashing a lifestyle!
dutchcommando's Avatar
The Netherlands, UT, Soest
Joined Feb 2012
cool! i like steam punk, amazing stuff is build..
i like the idea of a SP quad!
dutchcommando is offline Find More Posts by dutchcommando
Old Jul 01, 2012, 03:53 PM
kad is offline
kad
Find More Posts by kad
kad
Quad Crasher
kad's Avatar
United States, NY, Poughkeepsie
Joined May 2012
-Mike
Steampunk rules! Thread subscribed!
-K
kad is offline Find More Posts by kad
Old Jul 01, 2012, 04:25 PM
acetech09 is offline
Find More Posts by acetech09
I think I'm inverted. Maybe.
acetech09's Avatar
United States, CA, Pacifica
Joined Apr 2012
When it comes to steampunk, you ALWAYS need to have 3+ bags of these lying around.
I have used them to make really neat steampunk-looking control horns and linkages. And for reinforcement. http://www.rcgroups.com/forums/showthread.php?t=1673866 . The control linkages are in post 2 I think.
acetech09 is offline Find More Posts by acetech09
Old Jul 01, 2012, 04:33 PM
nicnaimless is offline
Find More Posts by nicnaimless
nicnaimless's Avatar
United States, MI, Jenison
Joined Jun 2008
StreamPunk Quadcopter Pig!?!?
subscribed !
Grand Rapids, MI has a huge art contest each year. A couple years ago a friend of mine created a huge steam punk piece. This is Parsifal better know as Steam Pig. At 1:18 in the video you can see a quick shot I did with an original QuadPowered quad and rigid mount GoPro HD.
Steam Pig is cool because he's a MultiRotor flying pig! He has 4 turbine engines. QuadPig!
SteamPunk FTW!
Oh! He is for sale! Let me know if you are interested.
SteamPig KS (2 min 20 sec)
nicnaimless is offline Find More Posts by nicnaimless
Old Jul 01, 2012, 06:13 PM
derk is offline
Find More Posts by derk
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
either use wood props, or paint yours to look like wood with brass hub reinforcing on it
sounds awesome!
derk is offline Find More Posts by derk
Old Jul 01, 2012, 06:15 PM
Deet_aus is offline
Find More Posts by Deet_aus
I have a video for that
Australia, SA, Adelaide
Joined Apr 2012
this may also give you a few ideas
http://www.archeli.com.au/forums/sho...d.php?t=151767
Deet_aus is offline Find More Posts by Deet_aus
Old Jul 01, 2012, 06:36 PM
webgeek is offline
Joined Sep 2004
Thanks for all the kind words. Anyone have a suggestion for some smaller 3-blade props and motors to drive em that I can use? I think the DT750 + 10x4.7 are a bit big in all regards. I'd like the 3-blade props as they are smaller.
Old Jul 01, 2012, 06:50 PM
Mortimer is offline
Find More Posts by Mortimer
Mortimer's Avatar
Joined Apr 2010
They're smaller but they don't give much thrust.
See, for example, this test of GWS 9x5x3 with DT700 motor : showpost.php?p=20828138
225g at mid-throttle and 680g WOT.
I don't think it would be enough for the weight of your flying boat.
10x4.7 are much better.
Mortimer is offline Find More Posts by Mortimer
Old Jul 01, 2012, 06:53 PM
smallcirrus is offline
Find More Posts by smallcirrus
smallcirrus's Avatar
Joined Aug 2004
And Heres another take on Steampunk, the last post in this thread shows it in its Final form,
http://www.archeli.com.au/forums/sho...eampunk&page=2
regards,
Alexis
smallcirrus is offline Find More Posts by smallcirrus
Old Jul 01, 2012, 06:55 PM
webgeek is offline
Joined Sep 2004
Ha, thanks Mortimer - that's EXACTLY what I was looking for. Looks like the DT750 + 10x4.7 + Turnigy Plush 30a is where it will stay. Not quite as nice scale looking as it means the motors have to be a bit far from the hull, but we will make it work
Old Jul 01, 2012, 07:11 PM
webgeek is offline
Joined Sep 2004
Tiny and hard to see, but that's the basic idea with the props. Looks like we will be using .415" carbon fiber tubes for the arms. These are very heavy to be basically unbreakable as they will be a pain in the butt to replace:
http://www.dragonplate.com/ecart/pro...ID=4106&cID=79
sjgusmc21 is offline
Find More Posts by sjgusmc21
sjgusmc21's Avatar
Lorton, Va
Joined May 2004
SWEET idea and way to go for thinking out of the box! Can't wait to see it and thanks for sharing!
sjgusmc21 is offline Find More Posts by sjgusmc21
Build Log Building a palm size quad-copter & Introducing a new simple flight controller thanhTran Mini Multirotors 1393 Sep 16, 2014 03:40 PM
Help! 1st Arduino nano quad copter build need help programming thorek Multirotor Talk 6 Mar 26, 2012 03:54 PM
Help! Good first time tri or quad copter build design? flitelab Multirotor Talk 2 Jun 05, 2010 11:05 AM
Build Log a disaster site Quad copter build sketchillus Coaxial Helicopters 12 Jul 27, 2009 01:33 PM
Help! Need advice – wants to build a quad or kocto copter for the first time jonasnielsen Aerial Photography 0 Jan 30, 2009 03:28 PM
