Jul 01, 2012, 01:10 PM
Malaysia, Selangor, Kajang
Joined Jun 2009
With some fuse yes. Because the fuse can potentially provide lift and should be considered as part of the wing. But this should only affect "flat" fuses like the real life SR 71 Blackbird or the StuntCat RC model.
For your fuse it shouldn't affect CG. However, you are adding quite a lot of side area ahead of the CG while having very little side area behind the CG (your tip fins). This reduces lateral (yaw) and spiral stability. From the point of view of the pilot, the plane flies perfectly well in a straight line but try to turn or roll it and it misbehaves badly to the point that controls feel "mushy". That's basically your plane wanting to enter into a spiral dive.
I suggest increasing the size of your fins and extending it back a little beyond your wing's trailing edge.
