Old Jun 30, 2012, 09:08 PM
cneuhauser is offline
Find More Posts by cneuhauser
Joined Jun 2012
FMS Focke Wulf Newbie Question (please help)
My question is...
Is the motor supposed to be angled down and slightly to the left of center?
cneuhauser is offline Find More Posts by cneuhauser
Old Jun 30, 2012, 09:18 PM
gnats82 is offline
Find More Posts by gnats82
Coy, peruser of worlds
gnats82's Avatar
Augusta, KS USA
Joined Dec 2007
Originally Posted by cneuhauser View Post
My question is...
For this and most all WWII fighters, the motors are set up with some down thrust and right thrust (as viewed from behind). This a a technique that offsets the tendency to pull to the left under high power settings, especially at take-off where that reaction can result in damage to the model if the pilot doesn't give adequate corrections to keep the model's take-off straight and it wrecks.
It also helps offset the tendency to climb more than desired when a high power setting is given in flight.
gnats82 is offline Find More Posts by gnats82
Old Jun 30, 2012, 09:20 PM
Joined Jun 2012
Kind of like torque steer in a car....nice...awesome!
Old Jun 30, 2012, 09:24 PM
gnats82 is offline
gnats82's Avatar
Augusta, KS USA
Joined Dec 2007
Well, kinda, yeah..! No stranger here to torque steer, used to drive two-stroke SAABs and DKWs, waay (??) back in the day..
Old Jul 02, 2012, 03:58 PM
HoosierGuy is offline
Find More Posts by HoosierGuy
HoosierGuy's Avatar
United States, IN
Joined Jan 2012
Is that only for WW2 fighters or do most R.C. planes have that down and right (viewed from behind) angle? What about R.C. electric gliders and planes with the motor on top like a pusher glider?
HoosierGuy is offline Find More Posts by HoosierGuy
Old Jul 02, 2012, 08:36 PM
gnats82 is offline
gnats82's Avatar
Augusta, KS USA
Joined Dec 2007
Yes, it's a pretty standard practice to have the down/right thrust angles built in on tractor prop installations of R.C.planes of most types. However, the smaller the prop is in relation to the wingspan and fuselage length, the less offset is needed and none at all is present or needed on some planes.
Pusher installations can have thrust adjustment angles built in also, according to the prop rotation and how far above the wing center line it is.
It often gets some attention on the warbird threads because the prop diameter is larger in relationship to the wing span and with appearance being a big part of the attraction to warbirds, it's easier to notice. Some thrust angle offsets were used on the full scale planes though I can't think of a fighter that used offsets to the side.
Also, most WWII fighters had positive wing incidence on the order of 1.5 to 2 degrees, a few with a tad more. This effectively causes down thrust on it's own though added motor down thrust can be seen on some like the Merlin powered P-51s and the F6F Hellcat.
For Sale FlyZone Focke Wulf Parts Scar223 Aircraft - General - Miscellaneous (FS/W) 6 Jul 08, 2012 12:09 AM
Discussion Scratchbuilt Focke Wulf 190 - proof of concept makind Foamies (Scratchbuilt) 2 Jun 19, 2012 10:55 AM
Sold Unknown Motor from focke-wulf 190 jeb6684 Aircraft - Electric - Power Systems (FS/W) 3 Jun 14, 2012 10:24 AM
Download New FMS 2.8 ParkZone Focke-Wulf 190 ggunners Simulators 1 May 25, 2006 12:57 PM
