This thread is privately moderated by Bombay, who may elect to delete unwanted replies.
Old Jun 30, 2012, 08:41 PM
Bombay is offline
Find More Posts by Bombay
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
Cool
Night Flying Accessories for Sale (LEDs, controllers)
Stuff you might find useful...
If interested, please make a post or send me a pm. Do not be afraid to ask "stupid" questions. There is alot of information here and you might not be familiar with some of the items or how they work. I am happy to answer any questions.
PRICES:
Regular LED Strips:........................................... .....$4 per meter
- Green, Blue, Red, Cool White, Warm White.....$4 per meter
- Pink.............................................. .....................$5 per meter
Waterproof LED Strips:..................$5 per meter
- Green, Blue, Red, Cool White, Warm White.....$5 per meter
- Pink.............................................. .....................$6 per meter
Mini Regular LED Strip Controllers:.......$5 each
RGB 3528 LED Strips:...................$4 per meter
RGB 5050 "300" LED Strips:..........$6 per meter (limited quantity)
RGB 5050 "300" LED Strips (black pcb)....$7 per meter (limited quantity)
RGB Mini LED Strip Controllers:...................................... $5 each
RGB 24-Key Wireless IR LED Strip Controllers:..............$5 each
RGB Extension Wire (4 strand):...............................75 cents per foot
RGB 4-pin Adapter w/ extension wire:......................$1.50 each
RGB Solderless 4-pin Adapter w/ extension wire:....$2.50 each
Receiver Controlled On/Off Switch (Turnigy)............$12 each
*All prices include gratis shipping in the continental USA with a $10 minimum order.
**All LED strips will be cut 1 meter long. If you need strips longer than a 1 meter (uncut), please let me know ahead of time.
***I supply the parts listed above and below. You will need to supply your own power connectors, shrink tube, and soldering skills to complete the project
LED STRIPS
Regular LED Strips
-Superbright 3528 SMD LED
-Strip is approx 8mm wide
-Non-Waterproof
-60 LEDs per meter
-White vinyl face
-Self-adhesive back
-Can be cut at every 3rd LED (approx 2")
-Flexible
-Input volts: DC 12V
-Current per meter: 400mA
-24 watts/5 meter
-Viewing Angle : 120°
-Life Span: 50,000+ hours
-approx. weight per meter: 13 grams
The regular LED strips can be cut and solder-joined to each other in any combination. In other words, on a wing, you could have a 2" strip of blue...joined to a 12" strip of white...joined to a 4" strip of green at the wing tip.
BLUE Regular (item: 0001B)
GREEN Regular (item: 0001G)
RED Regular (item: 0001R)
COOL WHITE Regular (item: 0001CW)
WARM WHITE Regular (item: 0001WW)
Notes: Depending on the manufacturer, the LED strips may have different types of solder points. In either case, the solder points function the same way. You cut them down the middle and one point becomes positive and the other negative (see picture 1). Before you solder the strips, please test the polarity. You can do this with a 9-volt battery and two short pieces of insulated wire (see picture 2). Do not worry about getting the polarity wrong when testing, reverse polarity from the 9-v will not damage the strips.
Solder Points (picture 1)
Simple 9-v Tester (picture 2)
The waterproof strips contain the same LEDs as above, but are encased in silicone. Due to the silicone covering, they are a little heavier and just a tiny bit dimmer. The strips are waterproof, but any new solder joints or connections must be treated/covered with silicone or some other waterproofing material to maintain the "waterproofness" of the circuit.
The waterproof LED strips can be cut and solder-joined to each other in any combination. In other words, on a wing, you could have a 4" strip of blue at the wing root...joined to a 12" strip of white...joined to a 2" strip of green at the wing tip.
-Waterproof (encased in silicone)
-60 LEDs per meter
-White vinyl face
-Self-adhesive back
-Flexible
-24 watts/5 meter
-Approx. weight per meter: 30 grams
BLUE Waterproof (item: 0002B)
GREEN Waterproof (item: 0002G)
RED Waterproof (item: 0002R)
WARM WHITE Waterproof (item: 0002WW)
COOL WHITE Waterproof (item: 0002CW)
YELLOW Waterproof (item: 0002Y)
COOL WHITE Waterproof with Black background (pcb) (item: 0002CWB)
(SOLD OUT)
RGB LED STRIPS
RGB SMD 3528 LED Strips (item: 0003RGB)
RGB 3528 LED strips are similar to Regular (single color) 3528 LED strips (see specs and dimensions). RGB 3528 strips contain 9 to 12 leds per cuttable section. On a 5-meter roll, some sections may contain 9 leds and other sections may contain 12 leds (it depends on the manufacturer). Each cuttable section is either 6" or 8" long, depending on the number of leds per section. Each section contains alternating red, blue, and green single-color chips. (Because of this, some of the controller color options are not "true". For instance, in dynamic mode #10, the controller attempts to create "white" by combining all three colors. The result is all 3 colors being activated, but the result is not white.) Each section, when cut, contains 4 solder points (+,r,g,b). All RGB strips (3528 and 5050) require a controller to operate. They cannot be plugged directly to a battery or other power source (due to them having 4 leads (+,r,g,b).
-Superbright 3528 SMD RGB LED
-Non-Waterproof
-approx 60 LEDs per meter
-White vinyl face
-Self-adhesive back
-Can be cut at every 9th or 12th LED (approx 6" to 8")
-Flexible
-Current per meter: ~400mA
- ~4.8 watts/meter or ~24 watts/5 meter
RGB SMD 5050 150 LED Strips (item: 150RGB)
RGB 5050 "150" LED strips are similar to RGB 5050 "300" LED strips (see specs and dimensions). RGB 5050 "150" LED strips contain fewer LED chips per meter (30 vs 60) and thus require less power. RGB 5050 "150" LED strips contain 3 leds per cuttable section. Each cuttable section is 4" long. Each section contains 3 tri-color chips (red, green, and blue on a single chip). Each section, when cut, contains 4 solder points (+,r,g,b). All RGB strips (3528 and 5050) require a controller to operate. They cannot be plugged directly to a battery or other power source (due to them having 4 leads (+,r,g,b).
-Superbright RGB 5050 "150" SMD LED
-Color: RedBlueGreen (RGB)
-Strip is approx 10mm wide
-Non-waterproof
-30 LEDs per meter
-White vinyl or copper-colored face
-Self-adhesive back
-Can be cut at every 3rd LED (approx 4")
-Flexible
-Current per meter: 600mA
-7.2watts/1 meter or 36 watts/5 meter
-Working Tempreture:-20 to 50° c
RGB SMD 5050 300 LED Strips (item: 300RGB)
RGB SMD 5050 "300" LED strips are similar to RGB 5050 "150" LED strips (see specs and dimensions). RGB SMD 5050 "300" LED strips contain more LED chips per meter (60 vs 30) and thus require more power. RGB SMD 5050 "300" LED strips contain 3 leds per cuttable section. Each cuttable section is 2" long. Each section contains 3 tri-color chips (red, green, and blue on a single chip). Each section, when cut, contains 4 solder points (+,r,g,b). All RGB strips (3528 and 5050) require a controller to operate. They cannot be plugged directly to a battery or other power source (due to them having 4 leads (+,r,g,b).
-Superbright RGB 5050 "300" SMD LED
-Non-waterproof
-60 LEDs per meter
-White vinyl face
-Self-adhesive back
-Flexible
-Current per meter: 1.2A
-14.4 watts/meter or 72 watts/5 meter
CONTROLLERS
REGULAR LED STRIP CONTROLLERS (item: C-REG)
Take your strip leds to the next level with this micro controller. Easily change the dynamic mode, speed, and brightness of your led strips by pressing 3 keys on the controller interface.
- Size: 1/2" x 1 5/8" (not including wires)
- Weight: 7.5 grams (including wires)
- 12v DC input (~8-16 working voltage)
- Max load current: 5 amps
- Max output current 12 amps
- Max output power 114 watts
- Static power consumption: < 1 watt
- Dimmable 10% to 100% using Pulse Width Modulation
- 4" power input and controller output wire leads
- 5 dynamic modes (MODE key)
- Static mode (LIGHT key)
- 8 brightness levels (SPEED/BRIGHT key)
- 6 speed levels (SPEED/BRIGHT key)
- auto-memorize function (returns to last used mode when reconnected)
Simple to use.
- Press "Light" key to activate static mode.
- Press "Speed/Bright" key (after "light" key) to incrementally dim down thru 8 levels.
- Pressing the "Mode" key enters the dynamic (flashing patterns) mode.
- Press "Mode" to cycle through the 5 different patterns.
- Press "Speed/Bright" key (after "mode" key) to incrementally decrease speed thru 6 levels.
Here is an example of the regular LED controller (not my video)
LED Mini Dimmer with Dynamic Modes - MCB-LD5 (1 min 16 sec)
RGB LED STRIP CONTROLLERS (item: C-RGB)
Take your RGB strip leds to the next level with this micro controller. Easily change the dynamic mode, speed, brightness, and color of your led strips by pressing 3 keys on the controller interface. Several static colors (including white) and dynamic color changing modes are selectable and adjustable using the 3 keys on the controller.
- Weight: 5 grams (including wires)
- 3 channel RGB (4-pin port)
- In theory, can control up to a maximum of 30 meters of flexible RGB LED Strip.
MODES
- 39 total (20 static and 19 dynamic)
- 19 dynamic modes (MODE key)*
- 20 dimmable color modes (COLOR key)
- 5 brightness levels (SPEED/BRIGHT key)
- 5 speed levels (SPEED/BRIGHT key)
*Note: The 3528 LEDs have a cool "chase" effect when used in modes #11 and 12. The 5050 LEDs do not "chase" since all 3 colors are on a single chip.
Simple to use key functions.
Press the “MODE” key to enter dynamic color changing modes. Press “MODE” again to cycle thru 19 dynamic modes. While in this mode, the “SPEED/BRIGHT” key can be used to adjust the speed thru 5 levels.
Press "Speed/Bright" key (after "mode" key) to incrementally decrease speed thru 5 levels.
Press the “COLOR” key to enter static color modes. Press “COLOR” again to cycle thru 20 colors. While in this mode, the “SPEED/BRIGHT” key can be used to adjust the speed thru 5 levels.
Static Colors ("COLOR" key)
1. Blue
2. Green
3. Red
4. Ultra-violet blue
5. Light blue
6. Indigo
7. Purple
8. Light purple
9. Magenta
10. Coral
11. Orange
12. Yellow
13. Lime green
14. Aqua
15. Sky blue
16. Pure white
17. Cool white
18. Super cool white
19. Blue white
20. Deep blue
Dynamic Color Changing (“MODE” key)
1. Random
2. 7-color fade
3. Tri-color crossfade
4. 7-color crossfade
5. Blue fade in/out
6. Aqua fade in/out
7. Green fade in/out
8. Yellow fade in/out
9. Red fade in/out
10. White fade in/out
11. Tri-color instant change
12. 7-color instant change
13. Blue strobe
14. Aqua strobe
15. Green strobe
16. Red strobe
17. White strobe
18. 7-color strobe
Here is an example of the RGB LED controller (not my video)
Mini LED RGB Controller Demo- MCB-RGB4 from superbrightleds.com (3 min 35 sec)
OTHER ITEMS
RGB 4-pin Adapter: $1.50 each (item: A-RGB)
You will need 1 adapter to connect one end of the 3528/5050 RGB strip to the controller. You will need to solder the 4-strand wire to the 4 solder points on the LED strip.
RGB 4-pin Solderless Adapter w/ extension wire: $2.50 each (item: C-RGB)
You will need 1 adapter to connect one end of the 3528/5050 RGB strip to the controller.This one is solderless, so all you need to do is line up the solder points on the LED strip to the 4-pin connector and snap it shut. No solder. The other end plugs into the controller using the 4-pin male connector. This one is solid white.
RGB Extension Wire (4 strand): $.75 per foot (item: W-RGB)
If you cut the RGB LED strips to space them or to "jump" to another part of the plane/car/copter, you will need to connect them by soldering connection wire to the 4 solder points on each strip. Any thin wire will do, but this 4-strand wire is specifically made for the purpose. Of course, you could also strip off one or two of the strands to make 2 or 3-strand wire.
RGB 4-pin Solderless Adapter w/ extension wire: $2.50 each (item: B-RGB) - SOLD OUT
You will need 1 adapter to connect one end of the 3528/5050 RGB strip to the controller. This one is solderless, so all you need to do is line up the solder points on the LED strip to the 4-pin connector and snap it shut. No solder. The other end plugs into the controller using the 4-pin male connector. This one has the multi-color flat wire.
REFERENCE
Definitions:
SMD 3528
•Surface Mounted Device
•consists of one light-emitting chip
•dimensions of chip : 35 x 28 mm
SMD 5050
•consists of three light-emitting chips
•dimension of chip : 50 x 50 mm
Theoretically, SMD5050 is 3 times brighter than SMD3528.
Summary
The 3528 SMD is a single-chip medium-output LED. The 5050 SMD is a larger, three-chip high-output LED that has approximately 3X the brightness of the 3528.
For the purpose of a RC night flying setup, 3528 SMD LED strips powered at 11.1v/12v are plenty bright and can be powered directly from the main 3s lipo flight pack. This includes the single color and rgb 3528 strips.
For all RGB LEDs, and any LEDs powered by a controller, I recommend powering them from a separate battery (3s lipo), and not the main flight battery.
Tables
Additional reference links
-http://www.ledlightsworld.com/led-strips-c-1.html
Bombay is offline Find More Posts by Bombay
Old Sep 18, 2012, 11:23 PM
Timtreo is offline
Find More Posts by Timtreo
Click my name for night blades
Timtreo's Avatar
United States, PA, Warminster
Joined Nov 2011
Hi Bombay, can you PM me about the LED strips and controllers, I can't seem to be able to PM you for some reason. Thanks, Tim
Timtreo is offline Find More Posts by Timtreo
Old Sep 19, 2012, 06:27 PM
FLAME747 is offline
Find More Posts by FLAME747
Static Model Collector LOL
Katy, TX
Joined Dec 2009
Where can I buy the LED Controller??
FCA
FLAME747 is offline Find More Posts by FLAME747
Old Sep 21, 2012, 09:53 PM
Bombay is offline
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
Timtreo:
got your pm. returned.
Rob
Old Sep 21, 2012, 09:54 PM
Bombay is offline
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
FCA
Here. $5 each.
Old Sep 25, 2012, 11:03 AM
Bombay is offline
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
Tim and Flame:
Thanks for the nice orders. You both should receive them shortly.
You guys put me out of stock on one item and low on another. :-)
Rob
Old Sep 25, 2012, 12:50 PM
FLAME747 is offline
Katy, TX
Joined Dec 2009
Hey Bombay – I’ll post up some pic’s and video once I have the RGB LED’s installed, Plan on adding this to my existing night flyer
So it will be a combination of Always on LED’s, and flashing RGB
Thanks again for the fast shipping
FCA
Old Sep 26, 2012, 03:01 PM
Timtreo is offline
Timtreo's Avatar
Joined Nov 2011
Got my order from you today Bombay and WOW that was fast! Everything looks great. Bombay has great prices and communication, don't hesitate to buy from him! Thanks again Bombay.
Old Sep 27, 2012, 02:55 PM
FLAME747 is offline
Katy, TX
Joined Dec 2009
I also received my order from Bombay, I am extremely happy with his service, he answered all my question, and shipped my items faster that expected
Looking forward to installing some of these RGB LED's on my existing night flyer
Will post pics or video ASAP
Thanks again Bombay,
FCA
Old Sep 27, 2012, 03:00 PM
Nin3rsAllDay is offline
Find More Posts by Nin3rsAllDay
Nin3rsAllDay's Avatar
United States, NV, Las Vegas
Joined Jun 2012
Here is my night flyer still under construction at the moment but i'm using one of the regular LED strip controllers from BOMBAY to control the strobes on the wingtips and tail.
Night flyer (0 min 33 sec)
Nin3rsAllDay is offline Find More Posts by Nin3rsAllDay
Old Oct 06, 2012, 04:12 PM
KC Flyer is offline
Find More Posts by KC Flyer
KC Flyer's Avatar
Lee's Summit, MO USA
Joined Jan 2001
Awesome Lights!
Just got some lights from Bombay. They are great! Quick shipping too.
I got 4m: 2m of 150s, 1m of 300s and 1m of 3528. And I got 3 controllers.
I connected them all up and put them in various strobe and colored changing modes. The cool thing about the 3528s is that the LEDs chase during a couple of modes. The LEDs don't chase with the 5050s. The controllers are pretty awesome.
With all 4m hooked up using 2 contollers, I was typically using less than 10W. 7W on the last batch of settings (varies with mode) so definitely able to pull from my main batts (4400 mah).
Will post a video of my UFO Quad after I get it flying.
Thanks Bombay!
KC Flyer is offline Find More Posts by KC Flyer
Old Oct 22, 2012, 05:00 PM
Bombay is offline
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
4-strand connection wire and adapters back in stock.
Old Feb 08, 2013, 12:48 PM
rcrich is online now
Find More Posts by rcrich
When pigs fly rc
rcrich's Avatar
USA, NY, Chester
Joined Apr 2008
Just got my order from Bombay! Fast shipping and great products.
I tried the single color led controller and the rgb led controller and both work great.
Now its time to build a new night flyer.
rcrich is online now Find More Posts by rcrich
Old Feb 08, 2013, 06:27 PM
Bombay is offline
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
Thanks, Rich.
The weekend is here...get your LEDs right here!!!
Check out my itrader feedback.
No, seriously, I have to be seen by my wife taking a few more packages to the mailbox before I am allowed to bring any more packages home.
Old Feb 27, 2013, 03:01 PM
Vapor Trails is offline
Find More Posts by Vapor Trails
DFC~ We Do Flyin' Right
Vapor Trails's Avatar
USA, GA, Atlanta
Joined Nov 2008
I am considering another couple of LED projects, nothing to the extent I did with Burned Retina, but will be needing a good amount of LEDs.
I was curious, do you take credit card? I was not sure if you are a retailer or not... I am hoping so
Vapor Trails is offline Find More Posts by Vapor Trails
Latest blog entry: Pin-ups
Discussion Spartan RC NFX... The worlds best night flying LED controller (naturally) yogz Night Flying 15 Dec 23, 2013 10:18 AM
