Old Jun 30, 2012, 08:05 PM
hallstudio is offline
Find More Posts by hallstudio
Pilot not Drone Operator
hallstudio's Avatar
Marietta Ga.
Joined Apr 2005
Hobbyking KK2 board setup for gain and auto level with flight video
took me awhile to get the board super smooth but here is the results. also remember to mount the board centered as possable. I am not very techey so everything is basic.
Hobbyking KK2 board setup for gain and auto level with flight video (11 min 30 sec)
hallstudio is offline Find More Posts by hallstudio
Old Jun 30, 2012, 10:31 PM
signal15 is offline
Find More Posts by signal15
Atomic Playboy
United States, MN, Inver Grove Heights
Joined Jun 2012
You mention that you're not quite sure how I works. In a PI loop:
- P is the correction rate for the current deviation from the setpoint
- I is the correction for slow drift over time
You should increase P until you get oscillations and then back it off a bit. You should reduce I until drift becomes unacceptable, and then put it back up a little. Clearly whatever you're doing is working for you, but for others wondering exactly what the heck they are messing with when changing these values, this is what you're doing.
Are you building an army of these things? Should we all be worried?
signal15 is offline Find More Posts by signal15
Old Jul 01, 2012, 08:48 AM
hallstudio's Avatar
Marietta Ga.
Joined Apr 2005
thanks for the info. my hopes for my family of tri's is to program them to fly around and clean up my messy garage and yard.
Old Jul 01, 2012, 12:11 PM
signal15 is offline
Atomic Playboy
Joined Jun 2012
Get them all tuned the same, put all receivers in bind mode and bind them all to the same model memory in your transmitter. Then, fly all three in unison.
Old Jul 01, 2012, 10:08 PM
hallstudio's Avatar
Marietta Ga.
Joined Apr 2005
will spektrum recevers do that? if so i will give it a try, i only have 2 of the new boards but that would still be worth a shot.
Old Jul 01, 2012, 10:54 PM
Brainanator is offline
Find More Posts by Brainanator
Joined May 2011
uh...please post a video of it if you try. Sounds scary.
Thanks for the video, goes over quite a bit. I got a KK2 coming in the mail, still working on getting my KK tuned correctly.
Brainanator is offline Find More Posts by Brainanator
Old Jul 01, 2012, 10:58 PM
The Recursion is offline
Find More Posts by The Recursion
q {bld(); fly(); brk(); q();}
The Recursion's Avatar
Canada, ON, Mississauga
Joined May 2012
Don't do this by the way, it's a bad idea *does it*
The Recursion is offline Find More Posts by The Recursion
Old Jul 01, 2012, 11:27 PM
signal15 is offline
Atomic Playboy
Joined Jun 2012
I don't see why they wouldn't do it. It's a one way connection with Spektrum. The receivers are just picking up the ID when you turn on the transmitter in bind mode.
If you do this, you must post a video, no matter how disastrous the results. Auto level mode should make things a little better though, and should prevent them from getting too out of sync.
Old Jul 08, 2012, 10:11 AM
MIDNCOCO is offline
Find More Posts by MIDNCOCO
United States, CT, Glastonbury
Joined Feb 2010
So I got mine in last Friday and placed it on my tri and the motor layout is reading all motors CW? Is anyone else seeing this?
MIDNCOCO is offline Find More Posts by MIDNCOCO
Old Jul 08, 2012, 10:13 AM
hallstudio's Avatar
Marietta Ga.
Joined Apr 2005
dont worry about it just use the rotation u have in the past all will be fine.
Old Jul 18, 2012, 09:59 AM
capjlp is offline
Find More Posts by capjlp
Kentucky
Joined Sep 2002
I can't get my auto level to work from a switch
Whats the trick?
CapJLP
capjlp is offline Find More Posts by capjlp
Old Jul 18, 2012, 10:11 AM
capjlp is offline
Kentucky
Joined Sep 2002
Answering my own question..
RTFM read the frieken manual
have to go into Mode Settings menu an enable the switch function for the AUX channel...
CapJLP
Old Aug 07, 2012, 10:35 AM
Knighthawk517 is offline
Find More Posts by Knighthawk517
Joined Jul 2010
Hi Signal15,
Do you know what is P limit and I limit are for?
Knighthawk517 is offline Find More Posts by Knighthawk517
Old Aug 07, 2012, 01:06 PM
signal15 is offline
Atomic Playboy
Joined Jun 2012
P controls how hard it tries to return to position from existing change, I is for drift over time, and D is resistance to predicted change (e.g. Inertia)
Old Aug 07, 2012, 02:05 PM
AcroFPV is online now
Find More Posts by AcroFPV
we dont NEED roads!
AcroFPV's Avatar
United States, CA, Rocklin
Joined Aug 2012
Thanks Hall for this video! This is going to help alot of folks with their KK2 boards for sure Expecially me
AcroFPV is online now Find More Posts by AcroFPV
Discussion The Hobbyking KK2 Flight Controller sg1anubis Multirotor Electronics 165 Oct 06, 2013 10:47 AM
Discussion What is a good auto leveling control board penz83 Multirotor Electronics 66 Jul 17, 2012 12:21 AM
Discussion new hobbyking KK2 board flight video hallstudio Multirotor Talk 7 Jul 02, 2012 11:27 AM
Discussion KK2 control board flight footage dhdsracer Multirotor Talk 5 Jun 30, 2012 05:01 PM
Question Auto level setup, there must be an easier way? michael f Hoverfly Technologies 13 Jun 27, 2012 10:08 AM
