My first V911 had a bad motor. Aside from that, I never had a motor wear out on me. The cheapest motors are at aliexpress, just do a search on V911 motor. Going brushless on a V911 takes a lot of effort and is a total waste of money.
@mrmarc: More info regarding brushless motors & tail rotor shaft drives
Custom Shaft-Driven Tail – Brushless Concentric Version HeliVenom: http://helifreak.com/showthread.php?t=427367 Custom Shaft-Driven Tail – Non-Concentric Version HeliVenom: http://www.helifreak.com/showthread.php?t=396439 |
![]() I have both, by the way. Quote:
You and EQMODS have given me a LOT to read about for the next few days.
United States, NY, Binghamton
Joined Jul 2010
I appear to have been very lucky, she has her battle scars but not a single break, the spare blades are still sitting in the box even. Until recently I had almost as many crashes as take offs and much of them into pavement or walls.
Joined Apr 2013
V911 Brushless
For those that like to tinker, just seeing how a brushless motor on the V911 would perform can be a very interesting concept.
I have been doing some research and it appears the diameter of the main v911 motor is 0.8 cm. The blade mcpx has a main and tail motor brushless upgrade. It just so happens the tail motor on the blade brushless upgrade is 8 mm. Hey guess what? That's the same size! Has anyone tried this yet? Sources: Blade MCPX BL Tail motor is an 8mm 8100kV inrunner! http://www.rcgroups.com/forums/showthread.php?t=1812982 |
Tucson, Az
Joined Feb 2007
A brushless conversion to V911 would be a total waste of time and money. Why would someone do this as $20.00 heli ? conversion would be at least twice the cost of heli. V911 motor failure is not comon. I have a couple flown over a hundred flights and still fly fine.
The best things you can do to prolong the life of these little brushed motors is don't run them too long and don't turn them (manually) backwards. It used to take many hours of very hard use before you needed to oitl bushings, but I guess anything is possible these days.
Latest blog entry: Some stuff
| Thread Tools | |
| For Sale WL TOYS 3.5-Channel iPhone/ iPad/ iPod / iTouch RC Helicopter with 0.3 MP Camera! | Santoyo | Aircraft - Electric - Airplanes (FS/W) | 3 | Jun 13, 2012 11:36 AM |
| Question EC Declaration of Conformity for WL-V911 2.4G 4-CH RTF Micro Helicotper | nick007shadow | Electric Heli Talk | 1 | Dec 23, 2011 04:50 AM |
