Old Aug 06, 2012, 12:58 AM
Lt599 is online now
Find More Posts by Lt599
Lt599's Avatar
United States, WA, Shelton
Joined Feb 2012
Nice!! What power system do you have in your Mirage? Next time out I will get some altitude and check its stall characteristics, see if I can get it into high alfa. Greg
Lt599 is online now Find More Posts by Lt599
Old Aug 06, 2012, 07:17 AM
Waltjg is offline
Find More Posts by Waltjg
Waltjg's Avatar
Crystal River Fl.
Joined Jul 2008
That's right Greg, get it up there and slow it down pull that nose up, it will slow way down, I have a mirage and I can almost set it on the ground landing. W
Waltjg is offline Find More Posts by Waltjg
Old Aug 06, 2012, 09:47 AM
bwoollia is offline
Find More Posts by bwoollia
bwoollia's Avatar
United States, CO, Colorado Springs
Joined May 2008
You'll be able to high alpha no problem. If you can, set your throws as high as you can (I use a lot of expo on the Mirage, no dual rates). You'll need lots of throw when the airspeed gets slow. I've actually slowed the Mirage down enough that I've lost aileron control - I needed to goose the power to be able to turn!
For power in the Mirage, I'm using the WM400 Mk2 with a 3850kv Velocity-RC motor on 4S for about 1500W. They've got a bunch of fan/motor combos on sale now, but you might have to upgrade your ESC and batteries... http://www.velocity-rc.com/cgi-bin/v...on=list&cid=12
bwoollia is offline Find More Posts by bwoollia
Site Sponsor
Latest blog entry: Crash Compilation
Old Aug 06, 2012, 08:10 PM
Lt599 is online now
Lt599's Avatar
Joined Feb 2012
Thanks for the input guys, This is the first EDF delta I have ever flown so I will get out there and practice with it I can crank my throws up if needed, I already am running 60% expo. bwoolia, out of curiosity what capacity 4s in the Mirage and how many amps are you pulling at 1500W?
Old Aug 06, 2012, 08:43 PM
bwoollia is offline
bwoollia's Avatar
Joined May 2008
I have a 4000mAh battery, my flights are 3:00 to 3:30. I figure I'm drawing 110A or so.
Site Sponsor
Old Aug 06, 2012, 08:46 PM
Lt599 is online now
Lt599's Avatar
Joined Feb 2012
Thank you
Old Aug 06, 2012, 09:03 PM
bwoollia is offline
bwoollia's Avatar
Joined May 2008
No problem. I've never actually measured it, but I have measured my 5S combo at 3200kv, it's a bit of an extrapolation.
Site Sponsor
Old Sep 14, 2012, 11:32 PM
bamiller is offline
Find More Posts by bamiller
bamiller's Avatar
United States, CO, Castle Rock
Joined Dec 2009
This is a great design Greg. Very nice model. I am impressed how fast that guy is. Good work. - Brent
bamiller is offline Find More Posts by bamiller
Old Sep 15, 2012, 12:37 AM
Lt599 is online now
Lt599's Avatar
Joined Feb 2012
Thanks, I am still playing with it. I need to redo the mains or just go back to a belly lander. The wing is to thin for retracts (they where an after thought)
Old Sep 15, 2012, 01:32 AM
bwoollia is offline
bwoollia's Avatar
Joined May 2008
Have you tried the high alpha yet?
Site Sponsor
Old Sep 15, 2012, 09:50 AM
Lt599 is online now
Lt599's Avatar
Joined Feb 2012
bwoollia, yes, with some practice I was able to get it to slow nicely I am not sure if I like the landing gear. Now that I have learned how to fly it belly landing in the grass would not be bad.
Old Sep 15, 2012, 10:38 AM
bwoollia is offline
bwoollia's Avatar
Joined May 2008
Yeah, belly landing a 70mm jet is no problem. With the Mirage, I just harrier it into the ground, it plops down no issues. Landing gear can be unsightly and draggy on a jet.
Site Sponsor
Old Feb 17, 2013, 03:51 PM
rslegge is offline
Find More Posts by rslegge
rslegge
Joined Jun 2008
wrong spot
rslegge is offline Find More Posts by rslegge
Old Feb 17, 2013, 03:53 PM
rslegge is offline
rslegge
Joined Jun 2008
nice facilities
I hope I do this right, thanks for the posting instructions Joe. I put fixed gear on her and this is the first ground take off. It is a short flight. I was dealing with some wind again..no surprise My landing was hot and long. There is a chainlink fence at that end of our run way, I should have brought her around and landed the other direction. I need to figure out how to slow her down. Oh well I have a better mount now for the front strut.http://www.youtube.com/watch?v=YQnrkiWEF9A
I am so envious of your huge paved runway. Our's is about 1- feet wide only.
Old Feb 21, 2013, 05:45 PM
DoubleOne is offline
Find More Posts by DoubleOne
DoubleOne's Avatar
United States, MD, Annapolis
Joined Jul 2012
She looks and flew great! Let me know if you figure out how to slow down the landing, that's my greatest fear when I go flying....running out of runway! High alpha testing at altitude sounds like a good idea.
CG looks spot on, awesome!
DoubleOne is offline Find More Posts by DoubleOne
For Sale Wattage Sea Vixen Wings & Booms Jcopter Aircraft - Electric - Airplanes (FS/W) 1 Jul 21, 2012 03:49 PM
Sold E-Flight 70mm Delta V15 w/ BL32 Brushless Motor & CS 10 Blade fastjetadic Aircraft - Electric - Jets (FS/W) 0 Apr 16, 2012 08:44 AM
Sold Two NIB E-Flite Delta-V 15 70mm Fans lavochkin Aircraft - Electric - Jets (FS/W) 5 Mar 27, 2009 11:48 AM
Discussion E-flight delta v 70mm edf any good? superinstaller Electric Ducted Fan Jet Talk 2 Jan 22, 2009 04:20 PM
Discussion This is the new E-flite Delta-V 15 70mm fan... lavochkin Electric Ducted Fan Jet Talk 10 Oct 17, 2008 09:25 PM
