SS 1000.....Sorry, Styrospray 1000 is the 2 part polyurea made by Polymer Industries out of Houston..The same stuff that Wow Planes sells as Liquid Sheeting. I never thought about the Bobcat....just wanted to build a twin boom
Well the paint is setting just fine now. I have the white and orange sprayed. Tomorrow I will do the black accents, Im still thinking about the black. I just weighed the air frame and it is 536 grams. I am still on my 1200 gram goal.
Well I started this build with every intention of doing a quick (1 week or so) build of a delta EDF. But as the build has gone on I have been putting more and more detail into it, I have a habit of doing that
Anyway I started out today to try and finish the paint, but I got side tracked and decided I needed to put some detail into the cockpit. I did shoot some more black but I have more to do. I ran across a set of gear I had in a parts drawer, funny how we forget we have things, along with the gear I have a set of servoless retracts...just thinkin Here are some picks of where I ended up this evening. I am talking about possible retracts but right now I am still on track for my targeted AUW. But my 1200gram weight is based on running a 4s, Im gonna run a 5
Check out the F-86 in the video. About 1:50 min in. Utah National Guard.
http://www.rcgroups.com/forums/showthread.php?t=1696071 |
Greg, looking great here nice progress. So if it has no gear, will it be hand launch(almost all of my planes are).. If you use the retracts, is your wing thick enough? This is the problem I always run into with the retracts, that is why they are still sitting in my cabinet! W.
Walt, I had planned on just hand launching it but after looking at the gear I have I thought hum, maybe. If I did alter it for gear I would need to add thickness to the underside of the wing in the sections I was going to bury the retracts. Plenty of room in the nose. I could do it, I would built the retracts in a box outside the aircraft complete, then decide the area for mounting, tape that area off , cut through the SS1000 and the paint (you can peel the SS1000 off of the foam like really strong tape) Then take a piece of 1/2" blue foam shape and taper the edges so that it blnds in with the underside of the wing, epoxy it down then cut clean holes to sink the retract boxes in, repaint those areas, run the wires,then do the same to the nose. I know I would have sections of the wing thicker than the rest but I believe I could do it and have it look like it was "meant to be" I just dont know about the added weight or if I want to go through all the trouble. The little twin boom got some modifications, I extended the tail booms. Its waiting for another coat of filler, LWS and Durhams...I like it too
GregIf I do use gear I would either make these a single wheel/tire or order a different set. The duallys would be to thick when retracted.But they look cool! |
| Thread Tools | |
| For Sale Wattage Sea Vixen Wings & Booms | Jcopter | Aircraft - Electric - Airplanes (FS/W) | 1 | Jul 21, 2012 03:49 PM |
| Sold E-Flight 70mm Delta V15 w/ BL32 Brushless Motor & CS 10 Blade | fastjetadic | Aircraft - Electric - Jets (FS/W) | 0 | Apr 16, 2012 08:44 AM |
| Sold Two NIB E-Flite Delta-V 15 70mm Fans | lavochkin | Aircraft - Electric - Jets (FS/W) | 5 | Mar 27, 2009 11:48 AM |
| Discussion E-flight delta v 70mm edf any good? | superinstaller | Electric Ducted Fan Jet Talk | 2 | Jan 22, 2009 04:20 PM |
| Discussion This is the new E-flite Delta-V 15 70mm fan... | lavochkin | Electric Ducted Fan Jet Talk | 10 | Oct 17, 2008 09:25 PM |
