Old Jul 08, 2012, 01:27 AM
Lt599's Avatar
United States, WA, Shelton
Joined Feb 2012
I got some more done on the Vixen tonight. I was looking at the airframe yesterday and I decided to build a small scaled down pusher jet to check the C.G and try to get an idea of the flight characteristics. I threw it together out of DS foam and some electronics I had sitting around. I paid close attention to the shape of the Vixen except I increased the sweep to 60 degree from 50. I flew it this afternoon and it flew great. So back to the main build. I know that there will be significant differences in the aircraft, but it satisfied my curiousity about the design.
Lt599 is offline Find More Posts by Lt599
Old Jul 10, 2012, 03:59 AM
sloperjoe's Avatar
United States, WA, Vancouver
Joined Mar 2012
thats lookin like its gonna be a bullet! nice very nice
Joe
sloperjoe is offline Find More Posts by sloperjoe
Old Jul 10, 2012, 11:00 AM
Lt599's Avatar
Joined Feb 2012
Maybe it will be gettin that 6s? Haha. I really want it to "fly on rails" . I have some concerns about using the 3/8th's aileron material that I have because the TE at the hinge point is 1/2" thick. My concern is having that "step" from TE to elevon. Its only 1/16th's top and bottom and I can taper it to match. I just am not sure what type of air disturbance that would cause? (if any) maybe I am over thinking it.. I am going to look one more time and see it I can find any 1/2" material that might work ,I could always cut my own out of 1/2" balsa, but that would be a pain. Any thoughts on that?
Old Jul 10, 2012, 11:08 AM
sloperjoe's Avatar
Joined Mar 2012
make them out of foam then skin them with balsa sheet.
Joe
Old Jul 10, 2012, 12:08 PM
Waltjg's Avatar
Crystal River Fl.
Joined Jul 2008
lookin good Lt
Waltjg is offline Find More Posts by Waltjg
Old Jul 11, 2012, 01:08 PM
Lt599's Avatar
Joined Feb 2012
Thanks guys! I thought about doing what sloperjoe suggested with the foam and slins. Even know I could not find pre cut airleron material in 1/2" I did find a piece of balsa at the LHC 1/2"x6"x36" so I decided when all else fails build your own. I decided since I was going to shape my own elevons out of this block of balsa I might as well try the "hidden hinge" or "slotted hinge" system with Robart pins. I have never done them before and always wanted to try. I increased the elevons to 1 3/4" instead of 1 1/2". After about 4 hours in the shop last night here is what I came out with.
Old Jul 11, 2012, 03:57 PM
Waltjg's Avatar
Crystal River Fl.
Joined Jul 2008
LT, great looking job!! Really nice. w
Old Jul 12, 2012, 04:18 AM
USA
Joined Apr 2007
very nice
did this in cad. PS YOU you got CG yet
space 1 is offline Find More Posts by space 1
Old Jul 12, 2012, 04:19 AM
Joined Jan 2011
pin hinge
grease or AfterRun oil on the hinge pin prior to gluing will stop it sticking,
medlockaj is offline Find More Posts by medlockaj
Old Jul 12, 2012, 08:37 AM
Lt599's Avatar
Joined Feb 2012
Thats cool! I have done some preliminary measurements with the delta calc. But I have not got the exact CG yet. I have one in the ballpark.
Old Jul 12, 2012, 08:38 AM
Lt599's Avatar
Joined Feb 2012
Thanks for the info.
Old Jul 17, 2012, 12:23 AM
Lt599's Avatar
Joined Feb 2012
I spent the last couple of days doing finish work. I wanted to try both SS1000 and a product I found called MagiKote. So I used the SS1000 on the fuse. and wings and the Magikote on the vertical stabs, vents, hatch/canopy area and the nacelle. The LS1000 I brushed on with foam brush. It was very hard to keep an even coat. I applied 2 coats and sanded..alot! Next time I will borrow a pack from work and spray it. The Magicote is not as hard as the SS1000 but it is easier to apply. It seals, fills and sands out great. It is also about half the weight. I did a new product thread in scratch built foamies on it.(dont know if its new or not? but new to me)
Old Jul 17, 2012, 09:11 PM
Waltjg's Avatar
Crystal River Fl.
Joined Jul 2008
Looks great LT! W
Old Jul 22, 2012, 01:46 PM
Lt599's Avatar
Joined Feb 2012
Well I had an interesting thing happen. I used the SS1000 on the fuse and wings. I used the Magikote on the vertical stabs and of course just primer on the elevons. I painted my first color (white) I used the Krylon fusion. The vertical stabs dried within minutes and so did the elevons. The area that I used the SS1000 and then primed it has taken 6 days to completely dry! I have no idea what happened. Both the SS1000 and the primer where dry enough before paint that I was able to do the final sanding. Some kind of weird reaction I guess. Anyway thankfully it cured I thought for awhile that I may have ruined my build. I will be finishing the paint over the next couple of days.
For Sale Wattage Sea Vixen Wings & Booms Jcopter Aircraft - Electric - Airplanes (FS/W) 1 Jul 21, 2012 03:49 PM
Sold E-Flight 70mm Delta V15 w/ BL32 Brushless Motor & CS 10 Blade fastjetadic Aircraft - Electric - Jets (FS/W) 0 Apr 16, 2012 08:44 AM
Sold Two NIB E-Flite Delta-V 15 70mm Fans lavochkin Aircraft - Electric - Jets (FS/W) 5 Mar 27, 2009 11:48 AM
Discussion E-flight delta v 70mm edf any good? superinstaller Electric Ducted Fan Jet Talk 2 Jan 22, 2009 04:20 PM
Discussion This is the new E-flite Delta-V 15 70mm fan... lavochkin Electric Ducted Fan Jet Talk 10 Oct 17, 2008 09:25 PM
