Old Jun 30, 2012, 08:53 AM
Lt599 is offline
Find More Posts by Lt599
Lt599's Avatar
United States, WA, Shelton
Joined Feb 2012
Build Log
70mm Delta "Vixen XD1"
I decided to start another build. I was inspired by flyboykens scratch built creation the "Mantis or Mako" awesome bird! not sure which name he decided on?...I threw out "Vixen" just came to my mind, anyway I have a name for my creation What makes this type of building fun is there are no limitations. The only plans are in your head.
The Vixen XD1 (X stands for expiremental, D stands for delta, 1 because it is the 1st and only...plus I thought it sounded cool This is what the plan is so far.
Detrum 70mm EDF
60 amp ESC with 3 amp BEC
Sky lipo 5s 2200 (975 watts at 56 amps)
HK 6 channel orange Rx with sat.
2, 9 gram servos ( maybe more if I go with operational rudders
Primary construction material is the Dow 1/2" blue foam.
W.S. 30"
Length 33"
Here are some pics of what I got done so far. I have never built a Delta so any input or comments would be great.
Lt599 is offline Find More Posts by Lt599
Old Jul 01, 2012, 12:19 PM
Waltjg is offline
Find More Posts by Waltjg
Waltjg's Avatar
Crystal River Fl.
Joined Jul 2008
Looks like a great project! I'll be interested to see how the Detrum fan does on 5 cell packs, and the longevity of it... w.
Waltjg is offline Find More Posts by Waltjg
Old Jul 02, 2012, 10:52 AM
kingkyle is offline
Find More Posts by kingkyle
United States, NJ, Kinnelon
Joined Jan 2011
Nice! I just built a similar carbon delta and the CG should be calculated by the delta only, dont factor in the fuse at all... I made the mistake of factoring in the fuse as some lift and its not.
kingkyle is offline Find More Posts by kingkyle
Old Jul 02, 2012, 07:54 PM
Lt599 is offline
Lt599's Avatar
Joined Feb 2012
Thanks, I have been running a 5s on another Detrum in a F35. The 5s really wakes these fans up over 4s. On 5s getting 975 watts at 56 amps. Hasnt burnt up yet
Old Jul 02, 2012, 07:58 PM
Lt599 is offline
Lt599's Avatar
Joined Feb 2012
Do you have any pics on here? Id love to see it. Thanks for the info on the CG. Right now I am trying to decide if I want to put functioning rudders on my vertical stabs? Not sure I would need them accept for stall turns or knife edge...any input?
Old Jul 03, 2012, 06:46 AM
Waltjg is offline
Waltjg's Avatar
Crystal River Fl.
Joined Jul 2008
Looking good, nice progress w
Old Jul 05, 2012, 04:20 AM
space 1 is online now
Find More Posts by space 1
USA
Joined Apr 2007
Look's good you could add thrust tube
space 1 is online now Find More Posts by space 1
Old Jul 05, 2012, 01:49 PM
Lt599 is offline
Lt599's Avatar
Joined Feb 2012
I am going to role a tube out of either very thin alum. or plastic sheeting. I will attach it to fan then shape the inside of the nacelle to fit around it. It will extend aprox. 2 inches out the back. On these fans 90 percent opening seems to wok well. Good thrust and speed.
Old Jul 05, 2012, 01:58 PM
Lt599 is offline
Lt599's Avatar
Joined Feb 2012
Anybody have any input on whether I should have operational rudders. Since it is going to be a hand launch with no gear that rudders would really only be good for stall turns or knife edging? Anybody else out there with deltas have any input.
Old Jul 05, 2012, 03:00 PM
USA
Joined Apr 2007
rudders
rudders are nice but lots work on twin fin's not neede on deltas
Old Jul 05, 2012, 03:52 PM
Lt599 is offline
Lt599's Avatar
Joined Feb 2012
Yeah I was trying to decide. I put them on my F35 I used one servo per rudder. But on this build I am trying to keep the weight down. If I was going to do it I was thinking about using one servo and then a linkage set up. I think I will design the stabs so that I can come back later and add them if I want.
Old Jul 06, 2012, 12:33 AM
Lt599 is offline
Lt599's Avatar
Joined Feb 2012
Here are some pics of the fan mount. I hope to pick up some 1/2" thick elevon balsa tomorrow. My 3/4oz FG cloth came I need to decide if I am going to use WBPU or Epoxy resin. I know that WBPU would be lighter but the epoxy would be stronger....I just dont know yet, any suggestions?
Old Jul 07, 2012, 06:25 AM
kingkyle is offline
Joined Jan 2011
Sure do http://www.rcgroups.com/forums/showthread.php?t=1672531
I dont think you need a rudder. Cant hurt to have one. I find with delta's like these, they tend to nose down a little when you use rudder, inherent to delta design. I go with bank and yank.
Kyle
Old Jul 07, 2012, 12:33 PM
Lt599 is offline
Lt599's Avatar
Joined Feb 2012
Very Nice! have you maidened her yet? I have some 3/4 oz cloth, I also have some SS1000 on order. I need to decide how I am going to finish her. I am going to take your advise and skip the rudders. It will save some weight and keep it simple. Id love to see your carbon fly!
For Sale Wattage Sea Vixen Wings & Booms Jcopter Aircraft - Electric - Airplanes (FS/W) 1 Jul 21, 2012 03:49 PM
Sold E-Flight 70mm Delta V15 w/ BL32 Brushless Motor & CS 10 Blade fastjetadic Aircraft - Electric - Jets (FS/W) 0 Apr 16, 2012 08:44 AM
Sold Two NIB E-Flite Delta-V 15 70mm Fans lavochkin Aircraft - Electric - Jets (FS/W) 5 Mar 27, 2009 11:48 AM
Discussion E-flight delta v 70mm edf any good? superinstaller Electric Ducted Fan Jet Talk 2 Jan 22, 2009 04:20 PM
Discussion This is the new E-flite Delta-V 15 70mm fan... lavochkin Electric Ducted Fan Jet Talk 10 Oct 17, 2008 09:25 PM
