Espritmodel.com Heli Air
Closed Thread
This thread is privately moderated by chadew, who may elect to delete unwanted replies.
Old Jun 29, 2012, 09:03 PM
chadew's Avatar
USA, IN, Underwood
Joined Jun 2007
Trader Rating: 5
Turnigy Trust 45 ESC With hexTronic BEC and Program Card
I have a used Turnigy Trust 45 ESC with a hexTronic BEC and program card for sale. They were used in a Skywing foam airplane with no crashes. When setting it up once it got hot and melted the heat shrink on the back. Other then the heat shrink I never had any problems with it. They are wiredfs with an EC3 connector and ready to go. I am asking $25 OBO shipped CONUS.
Turnigy TRUST SBEC ESCs have a very flexible and broadly capable MCU, able to run all types of brushless motors. The large heat sink and simple PCB layout make heat dissipation consistent, enabling the ESC to be run at its limit, without failure. The ESC is program-card and transmitter programmable with clear and easy to understand instructions included.
Default factory settings:
Brake: off
Battery: LiPo Auto Detect
Low Voltage: 3.2v (power down motor)
Spec.
Max Motor Current: 45A
Max BEC Current: 3A
BEC Voltage: 5.5v
LiPo: 2~6S
NiMH:5~12cells
Weight: 31grams
Programming Options.
Battery Type
Forward/Reverse
Soft Start
LV Setting (Ignore, Reduce Power, Stop Motor)
Timing (Auto, Med, High)
Switching (8,16kHz)
Factory Restore
hexTronik UBEC.
Will supply a solid 5v or 6v to your reciever with a 2 to 5S Lipoly pack.
Specifications;
Output: 5v/3a & 6v/3a (Selectable via jumper)
Ripply: <50mVp-p(@2A/12V)
Input: 5.5v~23v (2 to 5s)
Weight: 12.5g
UBECs are used by connecting the input wires to the battery and the output to the receiver. This allows your Speed Controller to run cooler, and safer as you now have an external circuit to power your receiver. Should the Speed Controller be overloaded and fail, you still have control of your plane.
chadew is offline Find More Posts by chadew
Old Jun 30, 2012, 08:10 AM
Getting better everyday
Albuquerque
Joined Feb 2005
Trader Rating: 22
PM sent
tandemssafetyguy is offline Find More Posts by tandemssafetyguy
Old Jun 30, 2012, 09:44 AM
Albuquerque
Joined Feb 2005
Trader Rating: 22
Paypal sent
Closed Thread
Discussion Programming an ESC with the Turnigy card programmer Sport Flyer Power Systems 4 Jun 24, 2012 05:28 PM
Sold Proboat 45a esc with extra cap and program card HYDROJERRY Boats (FS/W) 3 Jun 14, 2012 12:27 PM
Sold Turnigy Trust 70 AMP ESC + program card kayvannouri Aircraft - Electric - Power Systems (FS/W) 1 Mar 31, 2012 08:29 PM
Sold Hobbyking 60 amp ESC with 5.5V BEC + programming card kayvannouri Aircraft - Electric - Power Systems (FS/W) 2 Mar 17, 2012 02:01 PM
Sold 80A Hobbywing (Turnigy Plush) ESCs with BEC - Quantity of 7 + Programming Card BC_guy Aircraft - Electric - Power Systems (FS/W) 12 Jul 02, 2011 12:38 AM
