Duncanville, TX
Joined Sep 2010
Don |
No, unfortunately, the Ares 6 channel radio that comes with the RTF version is very basic with only servo reversing. No program ability, no features. Just basic. It works fine , but once you move up to a "real" transmitter you're ability to learn to fly is exponentially improved.
United States, CA, Oceanside
Joined Apr 2011
Definately a pro. I am flying my Gamma 370 using a Spektrum DX6i and an AR400 Spektrum RX. I am getting my Gamma Pro this Friday and plan on using an Orange 6 channel RX in that one in tandem with my DX6i; I might just buy a DX7s this weekend too since I am out of model memory on my DX6i.
So you succumbed to the Orange Rx. I have 12 of those things. One of them browned out and totalled my T28. But the rest have been flawless. One word of advice for the Orange Rx: once bound to the Tx and you've selected the model, you may need to reset the Tx by shutting it off and switching it back on before plugging in the battery in the plane. On occasion, when I didn't do that, the Rx would blink instead of staying constant. All the functions still worked but I don't feel comfortable with a blinking Rx. I cut out a tiny window in the fuselage so i can see the Rx. So by habit I've always turned off then on the Tx before plugging in the battery. Enjoy your Gamma Pro. You'll love it! |
Joined Apr 2011
Only because my I ran out of my supply of Spektrum RXs. I do have 2 Tactic receivers that I am not using and I also have the AnyLink. I may use one of those for the pro. Rumor is, I am also getting a new DX7s for Xmas so that will also influence which RX I use in the Gamma Pro. I am flying two of my planes on the Orange RXs now. I fly my Tower Hobbies F4U Corsair and my Parkzone Spitfire Mk IX on them. I have not had an issue yet. I have never seen them blink either. Maybe I got some good ones.
United States, NE, Lincoln
Joined Oct 2012
I did the flap mod to the trainer wing and have flown it twice. Tight and fast barrel rolls required using the rudder whereas with the standard aileron Ares wing it will roll tight without rudder, although this make sense, more wing area plus that dihedral which I didn't want to screw with trying to remove.
I butchered the wing and left way too big of channels on the underside, I was in a hurry and did it all with out using a straight edge. Oh well. I was worried to take it off the first time but it works GREAT. With the flaps in the "half" position it takes off in a matter of feet. I just love having the flaps, I have them set up for 2 positions. I don't have a mix set up as I like to have the full control. If you pop the flaps down while flying at a decent speed it goes nose up instantly. But the flaps shine at low speed, as they should. What I like is that I can fly this plane at less than 1/4 throttle, possibly 1/8 throttle and it just floats in the air, so slow yet controllable enough to do loops around the landing area. If you guys like projects (as I'm sure most here do) go for it, its fun to add it that extra channel. I pretend its my little Cessna 182 with the flaps on it now. This is still my only plane except an EDF F18 which I won't be flying for a while. I think I want a P51 or T28 before I try that. ![]() ![]() ![]() ![]() ![]()
Well, Cubieman,
You've inspired me. I've never been to keen in my flaps wing but I think that it's because I have a high speed setup on my Gamma. She cooks pretty well in the air with the sport wing, outside loops and all of that, but the really slow stuff, it's not her forte. When I made the mods to the stock dihedral wing, my hinge joints were quite sloppy and annoyed me to no end so I have since forgone it for the sport wing which is an excellent, albeit different, alternative. Later this winter I will try to re-hinge my surface controls to tighten everything up and see what happens. At the same time I should probably slow down the prop to a 7x4 instead of the 8x6 that I'm currently using. She won't be as fast but hopefully she'll be more manageable at low speed. |
Joined Oct 2012
Chino...
Hell, I used the the du bro hinge tape instead of hinges and some pretty damn big control arms for the size of the ares. This wing seems very forgiving, not to mention how many gaps where left on the underside of the flap wing. I would love to be able to take the dihedral out of the stock wing, but even in current from I am still pulling(slow) barrel rolls. Just go with the hinge tape, that is how me and the other guy in this thread that I got the idea from had done it as well. |
| Thread Tools | |
| Found Sky babies are ready for shipping. | icharus | Aircraft - General - Miscellaneous (FS/W) | 3 | Jun 30, 2012 08:34 PM |
| Found Sky babies are ready for shipping. | icharus | Aircraft - Electric - Airplanes (FS/W) | 0 | Jun 24, 2012 09:45 PM |
| Found WTT Receiver ready Raptor 30V1 for RTF or receiver ready Trex 450 Sport/Pro | conefree | Aircraft - Electric - Helis (FS/W) | 2 | May 21, 2012 08:28 AM |
| Cool RFR (Ready For Receiver) | Smashed_Toad | Scale Sailplanes | 18 | Mar 18, 2005 07:50 PM |
| Cool RFR (redy for Receiver) Planes Good or Bad? | Smashed_Toad | Thermal | 10 | Mar 04, 2005 05:13 PM |
