Old Aug 02, 2012, 01:55 PM
unclecrash is offline
Find More Posts by unclecrash
unclecrash's Avatar
white lake michigan
Ah yes the finger tool. The guy who designed combat models f16, a10,f15, used what he called the sanding glove,or hand. He would put a latex glove on and trace his hand onto the back of the sandpaper,then he cut it out and sprayed it with adhesive and would stick it to his gloved hand. He would wetsand his planes after glassing throwing a bit of lite weight spackle onto the plane while wet sanding to fill the weave and sand all at once. Works great. Plane is looking sweet.
unclecrash is offline Find More Posts by unclecrash
Old Aug 02, 2012, 01:56 PM
p901P901 is online now
Find More Posts by p901P901
p901P901's Avatar
United States, CA, Lancaster
Joined Jan 2009
Ive used this method before, but used Fomica. It has a pain to cut and edges kept breaking. So this time I will try to use Mat board. This is the material that is used for picture frames.
From past experience I had to make registration marks to keep the sections square. One thing that I will do differently is to cut the templates in half horizontally so I can have a square edge on the foam cores. Then assemble the bottom half sections over the plans and assemble the top sections on to the bottom assembly.
p901P901 is online now Find More Posts by p901P901
Old Aug 02, 2012, 02:01 PM
unclecrash's Avatar
white lake michigan
Some of the very contoured shapes can be difficult to cut. Problem being you cannot see both templates at the same time to follow the patterns, seams you are getting better at it. I had a problem on the chimera with a few so I would take the bigger of the two templates and have it facing me. and make the first cuts away from the templates leaving some foam for a second and third run sometimes.
Old Aug 04, 2012, 09:32 AM
D_FAST is offline
Find More Posts by D_FAST
D_FAST's Avatar
Denver CO
Joined Apr 2008
CoG calulations
I imported my cad into illustrator at real world size and drew out what i think the calculator wants. Does this look correct as far as my drawings?
The Green is my Canards
The Red lines are the Wing
I used 15% Static margin for the calculations.
Thanks in advanced.
D_FAST is offline Find More Posts by D_FAST
Old Aug 04, 2012, 07:54 PM
p901P901's Avatar
Joined Jan 2009
Use the 15 - 20% MAC of the main wing without the canard. Then CG should be about right. Remember this is a delta wing airplane so use calculations for this type of plane. .The canard AOA can contribute to how effective the other control surfaces are. And depending on how you fly, then the plane should be tail heavy . Some canard planes the CG is actually at the wing root. If your unsure build yourself a "chuckie" and see where CG should be.
Old Aug 05, 2012, 08:50 PM
D_FAST is offline
D_FAST's Avatar
Denver CO
Joined Apr 2008
Went out and flew this weekend had a great time flying the chameria! Everyone drools on it, when i bring her out. Quite a speed demon, and flys like on rails!
Back to the build,
CG glider was tested at real size, My calculations were pretty close to dead on!
Made easy 20ft glides with it. broke a few inches off the nose nothing major.
Got a few more hrs into the edf build as well.
Old Aug 08, 2012, 07:50 AM
D_FAST is offline
D_FAST's Avatar
Denver CO
Joined Apr 2008
I think its time for some weight calculations and power plant considerations
Air frame glassed&primed - 14 oz
WemoTec Micro Fan x2 - 1.2 oz
Wicked 4800 kv x2 - 4.7oz
Pentium 40amp esc x2 - 2.3 oz
Spectrum AR600C receiver - 0.27 oz
3amp Bec - 0.35oz
Hitec HS-45HB servo x3 - 0.85 oz
2250 nano 60-135c 4s - 12.38 oz
Wire/extensions/linkage etc- 4.0 oz
Total 40oz OUCH!
I was hoping for something lighter as Im hand tossing this bird
Given dons wicked/wemo combo specs at about 480watt each for a total of 960watts. i should be some where around 380 watts per lb.
Old Aug 08, 2012, 08:58 AM
Waltjg is offline
Find More Posts by Waltjg
Waltjg's Avatar
Crystal River Fl.
Joined Jul 2008
Oh man, gettin heavy, like the Mig, but it may have more power, don't know the fan output power and wing fuse will lift more... w
Waltjg is offline Find More Posts by Waltjg
Old Aug 08, 2012, 12:28 PM
frank40 is offline
Find More Posts by frank40
frank40's Avatar
Denmark
Joined Sep 2005
Hey D
40 oz is not bad at all....
What airfoil are you using, If I remember correctly you live at high elevation, this will not help you. But you do have a lot of surface and with a airfoil whit some lift, you should be OK.
frank40 is offline Find More Posts by frank40
Old Aug 08, 2012, 06:26 PM
D_FAST is offline
D_FAST's Avatar
Denver CO
Joined Apr 2008
Originally Posted by frank40 View Post
Hey D
Mile High, and the heat wont let up, which wont help either.
I used a naca2088 that i slimmed down in my prints, got carried away with the build and ended up being sanded to a generic airfoil.
Flew the chimera last weekend in 100 degree temps, it was still moving, and its sitting at 320watts per lb.
Old Aug 16, 2012, 05:31 PM
D_FAST is offline
D_FAST's Avatar
Denver CO
Joined Apr 2008
Here she sits waiting for me to start sanding down more filler to begin the glassing of the top and bottom.
Pretty damn happy at this point. 10.8 oz as is, including the tape, glassed and primed surfaces you see next to her.
I just might come in under that 14oz for the air frame i guess on earlier.
Old Aug 17, 2012, 02:01 PM
frank40 is offline
frank40's Avatar
Denmark
Joined Sep 2005
Looking good D, can't wait to see it in the air.
Discussion 1/6 scale WW2 pilots coming soon! Need input from you guys! helifann Fuel Warbirds 6 Jun 30, 2012 07:02 PM
Discussion BEC questions and need input for my project tsymonds Electric Plane Talk 6 Jun 30, 2012 01:18 PM
Poll Fightercat issue.............need input scorpion1 Racing Boats - Electric 63 Jun 21, 2012 03:59 PM
Question Need input on AP build rgoins21 Multirotor Talk 12 Mar 15, 2012 01:27 PM
Question ARF FPV plane design - I need your input IBCrazy FPV Aircraft 26 Mar 10, 2012 11:34 AM
