Old Jul 30, 2012, 05:58 PM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
Cant be done. The case is too long and mounts on 2 tabs with 4 screws.
If fantom replaced the case, motor and fan it leads to the board being at fault?
Being his first flight - I wonder if he recharged the lipo first. That could explain the drop in power ? Also, the board and servo's would have had to have been removed to move into the new fuse. I wonder if the antenna is folded back onto the ESC section?
I'm sure someone posted about setting the throttle end point on here but I have not searched it out.
Flying blind here.....
NitroCharged is offline Find More Posts by NitroCharged
Old Jul 30, 2012, 07:58 PM
fantomwar is offline
Find More Posts by fantomwar
Joined Jun 2011
I did get the antenna out before securing the board down. The power loss is from the crash. Good power til crash, lowered power 30 seconds after on same battery. I didn't check voltages but will ASAP to make sure, but both batteries give same low power so I don't think it's them. I have tried test flights after each repair and get the same results. A hand launch goes in a 5 foot dive down, even with elev up. Gear launch just rolls along. I guess I'll have to wait til new boards are available. Thanks to all for the info!
fantomwar is offline Find More Posts by fantomwar
Old Jul 30, 2012, 08:24 PM
kalmon is offline
Find More Posts by kalmon
Parkzone junkie
kalmon's Avatar
United States, MI, Grand Traverse
Joined Oct 2008
Out of curiosity what TX you using?
You've basically ruled out every single option other than the brick or TX. When I said AS3X disabled I meant before advancing the throttle for the first time. All the surfaces will work but AS3X is not Armed until the throttle is advanced.
-Brian
kalmon is offline Find More Posts by kalmon
Old Jul 31, 2012, 03:30 AM
NwRcFlight is offline
Find More Posts by NwRcFlight
EDF Junkie
Pacific Northwest
Joined Oct 2007
Mig Safety note
Here's something to think about if you crash your Mig and crunch the nose. I was lucky. I work in an industrial environment, have bad eyes and consequently wear safety glasses all the time.
When my elevator servo died and I crashed I started a post crash checkout. I peered in the nose to see how bad the damage was, then I looked in the tail end and like a dummy hit the throttle to see if the fan turned OK. It did and the bits of foam from the nose that had been knocked loose in the crash were rapidly shot out of the tail into my right eye which was luckily covered with the safety lense. I should have been thinking clear enough to avoid sticking my eye there and starting the motor but I was a bit shook up after the crash. I haven't had that helpless out of control aircraft feeling in a long time.
Hopefully my mistake saves someone else from doing the same.
Happy flying.
NwRcFlight is offline Find More Posts by NwRcFlight
Old Jul 31, 2012, 07:51 AM
Eastcoast78 is offline
Find More Posts by Eastcoast78
Dixie Normious
Eastcoast78's Avatar
Can A da....Ehh!!
Joined May 2010
Happy flying.
I did the same thing with my Shotgun...bad move!!
Eastcoast78 is offline Find More Posts by Eastcoast78
Old Jul 31, 2012, 10:26 AM
EDF Junkie
Pacific Northwest
Joined Oct 2007
Ouch!
Old Jul 31, 2012, 10:40 AM
Freddie B is offline
Find More Posts by Freddie B
Addicted to building...
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
Ouch is right! And that is a great safety tip too, BTW. A EDF fan is just like a propeller, but has a barrel to direct it's path in the event of a failure (or direct debris). We should all remember that. My old FB once sucked an RX through a fan doing some bench testing during a build. The shrapnel was awesome, but nasty!
Fred
Freddie B is offline Find More Posts by Freddie B
Old Jul 31, 2012, 12:00 PM
topforce is offline
Find More Posts by topforce
USA
Joined Feb 2002
Has anybody decided that this little mig is a bit too easy to fly? Its cool looking and impressive to onlookers,,, but! theres no challenge. It flies easier and more stable than some larger edf jets. Its a non event. I have not read through this whole post,, but is there a way to dis able the as3x?
topforce is offline Find More Posts by topforce
Old Jul 31, 2012, 12:35 PM
turboparker is offline
Find More Posts by turboparker
I'd rather be flying!
turboparker's Avatar
Joined Jul 2009
It is very easy to fly. That was the whole point with this bird. Well....that - plus the larger-scale 'feel' and the ability to handle wind & turbulence that would ground many larger ships.
The topic has been discussed in this thread ad nauseam. The short version: There is no AS3X off switch. Unless someone comes up with a hack, you'll need to change the brick if you want to fly without AS3X.
Joel
turboparker is offline Find More Posts by turboparker
Old Jul 31, 2012, 12:46 PM
tracknoob is offline
Find More Posts by tracknoob
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
If you are looking for a challenge, and the thing is 'easy to fly' then that just means you need to do lower, slower, sharper, more frequent, etc maneuvers.
Trust me, if you get froggy enough, you'll be able to pack it in!
tracknoob is offline Find More Posts by tracknoob
Old Jul 31, 2012, 01:42 PM
Fish99 is offline
Find More Posts by Fish99
Flying addicted and lovin it!
Fish99's Avatar
Canada, AB, Edmonton
Joined Jun 2010
Agreed on both counts. I find this plane very easy to fly if you are in a big open field. BUT, I have flown it on the front steet dodging light poles and trees and keeping away from house roofs, well, let's just say it seems plenty fast there and I appreciate the control of the AS3X with the gusty / swirly / uneven winds you get from all those houses ... j
Fish99 is offline Find More Posts by Fish99
Old Jul 31, 2012, 02:03 PM
RealGambler is offline
Find More Posts by RealGambler
Way to many airplanes!
Canada, QC
Joined Oct 2009
Hmmm, I didn't like the Mig at all when I first got it. But it's growing on me simply because I find it somewhat challenging. Flying inverted, 2 or 3 feet from the deck, give me goose bumps because I know the elevator won't save me and rolling back up will be VERY tricky. Stalling it while going up, doing the backflip, 15 to 20ft in the air, from a slow straight line, is absolutely great, but you have only once chance to get it back because the ground is coming in quick. Getting a smooth 2 point landing is very challenging (and rewarding!). Even simply landing it on a short runway or a narrow bike path is fun since it does land hotter than any other UM. I have a huge fleet but it's little things like that, which are easy to do on other airplanes, that make me come back to the Mig. Have to admit that otherwise, it's so stable, just flying it around in circle is very boring.
RealGambler is offline Find More Posts by RealGambler
Old Jul 31, 2012, 04:52 PM
pugsam is offline
Find More Posts by pugsam
LiPo-Sucker & Airframe EMT
pugsam's Avatar
Charlottesville, Virginia, USA
Joined Aug 2010
Following in the tracks (i.e., copying the ideas) of some of the great airmen on this thread (Eastcoast78 is the greatest of all!!! all hail Eastcoast!!!) -- and being acutely aware of my own stick-and-rudder limitations -- I've made a few protective mods.
With the extra tape, plastic, and CF (but no battery and landing gear), this bird weighs 62 grams. Anyone know how that compares to the naked, out of the box weight?
Dave
pugsam is offline Find More Posts by pugsam
Last edited by pugsam; Aug 20, 2012 at 12:19 PM. Reason: Credit -- in pink ink!!! -- to Eastcoast 78 for the ideas of the spoon servos covers and the spar across the hor stab!!!!
Old Jul 31, 2012, 05:26 PM
Joined Jun 2011
Mig-15 crash
-Brian
I have a spectrum dx6i and all my other planes respond fine with it. On the mig all functions are fine, full throw on all surfaces. I'm not sure what the brick is but I'm guessing something on the board. I even called HH tech support, only choices are send it in for service or wait for boards and do it myself. Boards are due out in Sept or I wait while in the mail, either way it won't see air for a month at least. Sigh
Old Jul 31, 2012, 05:53 PM
Boofhead is offline
Find More Posts by Boofhead
That will simply buff out
Boofhead's Avatar
Australia, NSW, Kareela
Joined Jul 2001
Maiden this morning - nice!
Had the maiden of the MIG-15 this morning
Had 2 flights on the 800mm P-51 first to warm up, and then got the MIG out of the box.
Usually on the maiden (especially with the EDFs) it mean getting the plane up and away and then some circuits and figure 8 and land (and a sigh of relief)
However with the MIG it was away and after a couple of circuits, then some loops, barrel rolls and passes low on the deck. Definitely the easiest of my EDFs to fly (I have the 35mm MIG-29 on 3S and F-15 on 2S) and really makes the pilot look good
Will get the additional batteries sorted out and get her out again - best maiden yet!
Bring on the next UMX EDF - what about a twin F-15
Boofhead is offline Find More Posts by Boofhead
Discussion Official Eflite UMX Beast Owners thread! darksiede Micro Ready-to-Fly 19423 Aug 15, 2016 09:37 PM
Discussion Hobbyking Lancaster official owners thread Tartago Electric Warbirds 982 Sep 04, 2015 02:49 PM
Discussion E-flite UMX MiG 15 DF SNEAK PEEK! D PAYNE Micro EDF Jets and Power Systems 2291 May 07, 2015 06:50 PM
Discussion UMX Mig-15 DF Mod Thread NitroCharged Micro EDF Jets and Power Systems 1141 Apr 02, 2015 04:42 PM
Sold Eflite F-86 Sabre 15 DF NIB! blue7.62 Aircraft - Electric - Jets (FS/W) 1 Apr 05, 2012 01:35 PM
